Old 09-06-2010, 09:05 AM   #1
Cadge
Default E series LSD into AU Diff
I know there was a thread on here at one stage about this, but i cant find it.
if anyone could point me in the right direction or tell me it this is possible, would be awesome.
AUI Ford Fairmont | Lowered with Kings | XR8 Leather Interior | XR6 Tickford Engine and Gear box|
Cadge is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2010, 10:50 AM   #2
KR1STO
Just another mock-up..
KR1STO's Avatar
are you talking about changing the whole rear axle or just the diff centres..?
if you're talking about the whole axle then...
not sure if you can.. but if you use the AU diff cover and watts linkage it should keep the right angle..
the AU and EL diff angles are different...
also, you'll need to find if the EL diff length is the same from end to end..
also, the wheel offsets are different so you'll need to find out if you can change the rear offsets back to AU...
as i said.. not too sure, but there's a few points to think about...
cheers
kris
Desire isn't driven by the heart, the mind or the wallet.
Desire comes from another place.
It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night...
see my car here:
Built my own TL50!!!
[SIGPIC][/SIGPIC]
KR1STO is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2010, 11:36 AM   #3
Stattic
Stattic's Avatar
You can't use the whole diff no. The au diff is longer. Try and find put if the el LSD will fit inside your au housing
Current
Blueprint 03 xr8
5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives
256rwkw
BA manual Typhoon
Fully optioned, 340rwkw@16psi (thanks Bluepower)!
The old ride....
AU Fairmont, cammed beast, R.I.P you made my p plate years bearable!
150.8rwkw courtesy BPR
Stattic is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2010, 11:42 AM   #4
GS608
I was told that EL 3.45 LSD insides will slot into the AU housing, as long as you don't have a 3.08 diff as the housing is smaller than the others.
GS608 is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2010, 06:14 PM   #5
Cadge
Yeah i was just looking at swapping the centres over.
What does having a higher ratio diff do? Im guessing the AU XR lsd were... 3.09?
Oh and this will be going into an AU rally car.
Old 09-06-2010, 06:26 PM   #6
KR1STO
KR1STO's Avatar
au xr's were 3.45:1
gives better take off over the 3.08:1 diffs..
see my car here:
[SIGPIC][/SIGPIC]
Old 10-06-2010, 12:06 AM   #7
SLO AU XR8
You can use the EL diff, but then need E-Series offset wheels. Also, E-Series diff internals DO swap will ALL AU diffs, including IRS.
GT 335
11.3@124.1mph
383rwkw/513rwhp
Forced Performance Tuned
SLO AU XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2010, 12:08 AM   #8
Stattic
Stattic's Avatar
You reach higher rpm at lower road speed so the car is hitting bigger power earlier therfore improving acceleration. 3.45 is a bit nicer an it's a good upgrade from 3.08 but if you wanna change gears and it's for a race car of any sort definitely get 4.11s
if I had a 2nd chance I'd put 4.11s in my street car lol the economy really isn't that bad with my 3.9s and it's actually better around town highway obviously worse
Current
Blueprint 03 xr8
256rwkw
BA manual Typhoon
The old ride....
Old 10-06-2010, 09:41 AM   #9
Cadge
hmmm.... Ive got an XR lsd sitting in a wreck, but im in two minds whether to put it into the race car or the road car. 4.11? whats that from?
