love my eb,s
replacing my head gasket and looking for the head bolt torc seting and eny info i may need lol
Chairman & Administrator
The Duratec 1.8 and 2.0 are as follows:
Tighten the cylinder head bolts (in sequence) in five stages: • Stage 1: 5 Nm. • Stage 2: 15 Nm. • Stage 3: 45 Nm. • Stage 4: 90 degrees. • Stage 5: 90 degrees. The sequence starts from the centre pair of bolts and works outward and on opposite sides. That is to say Centre LH, Centre RH. 1 back from centre (left and right) then 1 forward from centre (left and right) until completed. The earlier 1.6-2.0 Zetec engines are tightened using the same order but to these specs: Stage 1: 20 Nm Stage 2: 40 Nm Stage 3: 90 degrees Please note that in some Zetec applications the Stage 3 tightening is to 105 degrees Cheers Russ
Observatio Facta Rotae
Since its a 1997 Mondeo, the engine would be the silver top (early) Zetec - not Duratec.
love my eb,s
its the 1.6
