Old 25-12-2009, 10:39 PM   #1
FalconXV
FalconXV's Avatar
Default ford v6
help with engine how do i get torque settings and specs related to this engine online for free? ax Telstar V6 5 speed? repair guides etc
FalconXV is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2009, 03:40 PM   #2
FalconXV
FalconXV's Avatar
BUMP any experts in the building?
Old 26-12-2009, 03:52 PM   #3
Falcon Coupe
Clevo Mafia Inc.
Falcon Coupe's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF over an extended period of time. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Your tireless efforts behind the scenes in keeping AFF the place it is.
I don't recall the Telstar ever having 6 cylinders in Australia.
http://en.wikipedia.org/wiki/Ford_Telstar
Falcon Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2009, 04:01 PM   #4
Windsor220
Now Fordless
Windsor220's Avatar
Telstar definitely had a V6. 2.5l same as the Probe. That wiki says only in NZ which is wrong.
Probably going to be difficult to find a complete database for a car like this as they arent that common. Best to just spend some coin on a manual from Repco or similar place.
Windsor220 is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2009, 04:41 PM   #5
cosmo20btt
Fordaholic
cosmo20btt's Avatar
It is the KL motor that Mazda put in the 626 should be an all alloy motor if it is I can supply big End, Mains, & Head bolt torque.
Cyl Head: 1st step 23-26nm 2nd step tighten to 90 degrees 3step tighten a further 90 degrees
Big ends: 1st step tighten to 22-27nm 2nd step tighten to 90 degrees
Mains: Eight inner bolts, 23-26nm Eight outer bolts, 18-21 nm. Number 4 inner bolts (4 stamped on bolt head) tighten to 80 degrees. The remainder of the inner bolts ( 1 stamped on the head)Tighten to 70 degrees. Eight outer bolts, tighten to 60 degrees
Please use this information carefully as it is supplied to you through datatek
cheers.
cosmo20btt is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2009, 05:14 PM   #6
Sprint XR8
Sprint XR8's Avatar
http://forums.probetalk.com/showthread.php?t=1701133388
Sprint XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 27-12-2009, 02:56 AM   #7
FalconXV
FalconXV's Avatar
Legendary stuff. Cheers.
