22-08-2009, 04:22 PM | #1 | ||
Hi all
Just admiring my daughter's new zetec and noticed the rear tires wearing on the inside tread more than outside. 195/45R16 fitted. On closer inspection it seems the rear wheels have excessive negative camber i.e. the wheels are leaning in at the top. Is this normal for this model? Your comments would be appreciated. |
22-08-2009, 06:28 PM | #2 | ||
I stand corrected but as far as I know the fiesta does NOT have independant rear suspension and thats the only way you will get negative camber on the rear, I would get it checked. My tyres wear dead even.
22-08-2009, 07:38 PM | #3 | ||
Nope. Not on mine.
CURRENT: 2017 Escape Titanium 2.0L EcoBoost with Technology Pack in White Platinum PREVIOUS 2015 Fiesta ST / 2012 Focus Titanium / 2009 Fiesta Zetec / 2004 Fiesta Zetec |
22-08-2009, 07:42 PM | #4 | ||
Or mine and ive done just short of 5,600k's
http://www.facebook.com/pages/Steve-...861161?sk=wall http://www.ambient-aperture-photography.com (PLEASE DONT HESITATE TO PURCHASE MY WORK) http://www.flickr.com/photos/stevemack |
23-08-2009, 09:16 AM | #5 | ||
Done near on 25,000ks here and still got more than half way to go on the front tyres let alone the rear and there's no camber on the back (it's a beam axle)
23-08-2009, 03:40 PM | #6 | ||
Hi guys thanks for your comments.
Now I'm worried. I used a spirit level..pressed it against the bottom side edge of the tyre (no tyre bulge) and adjusted the top for vertical (air bubble) - definately lean in. I guesstimate 1-1.5 deg negative. Here's some photos I did the same of the front wheels & they are very close to vertical. Last edited by jafa4rd; 23-08-2009 at 03:48 PM. |
23-08-2009, 06:10 PM | #7 | |||
Fixing Ford's **** ups
Just because it doesn't have IRS, doesn't mean you can't have camber issues. Onto the issue at hand. How does the strut in the rear bolt up, as I can't remember? If it bolts up the same as the fronts, loosen off the 2 nuts and bolts that hold the strut to the stub axle assembly and wedge a screw driver between the strut housing and the stub axle. Make sure you pull the stub axle assembly towards the outer of the car. Then do the bolts back up. Re check the camber and see if that makes a difference. If it doesn't, go to Pedders with one of those nuts and bolts from the stub axle assembly and get a camber bolt (or camber pin). Fit that up and see how you go. If you don't have a similar set up on the rear, like the front, I'd be hazarding a guess you may have a bend stub axle. See how you go with these suggestions and let us know how you get on |
23-08-2009, 06:23 PM | #8 | ||
Ok i had a closer look at mine today and i have got camber on the rear wheels leaning into the verchile but i dont have uneven wear of the tyres.
24-08-2009, 12:15 PM | #9 | ||
I believe that the WS Fiesta has a torsion-beam-type rear suspension setup (i.e. it is semi-independent) - however, I have not got under the car to have a look. The factory settings should provide a small amount of negative camber and, in my opinion, 1 to 1.5 degrees does not seem excessive. However, the accelerated wear on the inner tread is a concern, depending on how severe it is.
Things to consider: - How many kilometres has the car done? The tyres should be rotated at least every 10,000 kms, and wheel alignment done at around 20,000 km intervals. - Is the wear on both rear tyres? Wear on one side could indicate that the wheel/tyre has been knocked out of alignment on a curb, pothole, etc. A good four wheel alignment should be around $60, either from your dealer or from any reputed wheel and tyre shop. They will have information on the correct factory settings for your vehicle. Also, for your own peace of mind, ask for a print-out of the wheel alignment settings, before and after the job. |
24-08-2009, 07:11 PM | #10 | |||
If they have a beam in the back, you can't adjust them. There is nothing there to adjust. That's unless you want to bend a solid pipe. Even doing that will only solve a toe issue, not the camber issue. So asking for a 4 wheel alignment will make you look like a fool and you'll be ripped off. Sorry for being so blunt, but that's how it is. I'd like to know how the rear strut is bolted up. Is it bolted up with 2 nuts and bolts through the stub axle or is a single nut and bolt through the beam? This will help determine the best way to fix this problem. |
25-08-2009, 12:19 AM | #11 | ||
1.5 degrees doesn't seem enough to do any real inside wear on it's own. My early irs Commodore has some serious camber 2.5 degrees I think is the factory setting, that wears the insides a bit, but not too much
25-08-2009, 11:59 AM | #12 | ||
Hi guys apologies for not posting more pics. Seems i've hit the limit there. Don't know how to get around that.
The car is only 3 weeks old travelled less than 500km. White writing on the tyre tread near the outside edge shows the rubber is not contacting the road at all in that area Will try to take some pics of the suspension setup on the weekend - if she let me close to it _ _2: Last edited by jafa4rd; 25-08-2009 at 12:05 PM. |
25-08-2009, 01:05 PM | #13 | ||
If it is already showing so much wear after only 500 kms, I would take it back to the dealer and ask for them to check the alignment at the rear to see if it is within the factory specs. As svo supporter has said, with the torsion beam rear there is no place for adjustment. (I had a look under there last night... my bad!)
25-08-2009, 07:07 PM | #14 | |||
I can tell you, that ain't a "factory" setting for a Commodore. Early or late. Commodores are a different kettle of fish and I won't get into that with this topic. I will say, you'll have more than a little bit of inside edge wear with it. Instead of pics and waiting until you go to a suspension shop with the car, unbolt a rear wheel. Have a look at how the strut bolts up and tell me whether it has 2 nuts and bolts holding it to the stub axle, or whether it has a single nut and bolt holding it to the rear beam. Then I can tell you whether you can do something with it or not. Otherwise I can see you being slugged for nothing. |
26-08-2009, 11:28 AM | #15 | ||
04 fiesta zetec
I think the point here is that there is definately something wrong if you've only had the car for that amount of time and you're getting that type of wear in the tyres. Take it back!!!
'04 WP Fiesta Zetec moondust-silver. Exterior: 16" MP3. zetec bodykit w spoiler. Red brake calipers. Colour-coded trims. Gun-Metal grey 'ZS' side stripes. Tint. Phillips Diamond Vision beams w white LED parkers + n.p. lights. ST repeaters. Euro wipers. Interior: Colour-coded trims. ST leather gear knob w leather gaiter. Brushed Aluminium pedals. Scuff Plates. Performance: Denso Iridium sparks. CAI. 2" cat-back with Hi-tech stainless muffler & dual chrome tips. Lowered. RSB soon! |
26-08-2009, 03:25 PM | #16 | |||
26-08-2009, 08:46 PM | #17 | |||
I can tell you the specs for a IRS Commodore are very very broad. Minimum is 1/2 neg and maximum is 3 degrees neg. So yeah,I surpose you're Commodore is within "factory specs". (Just so happens I looked them up today) I'm not going to go there with this side of things. Commodores are a different kettle of fish as far as rear end "specs" and tyre wear issues are concerned. So it might be best to leave it there hey? |
26-08-2009, 10:23 PM | #18 | ||
Thanks all
I'll take it back to the dealer and have it checked. They should know - right?? cheers |
27-08-2009, 01:38 AM | #19 | |||
Yeah, but they'll probably tell you it's in "spec", which is a very broad spectrum. |
