03-04-2009, 06:44 PM | #31 | ||
Question for those that do work at sea / or on such bloody big boats - why aren't gas turbines used?
Are they too inefficient at sea level?
Out of lease ......... what next? |
03-04-2009, 07:58 PM | #32 | ||
Move, I'm trying to SPEED
Check out the knock nevis.... its 450 odd metres from memory... but is as ugly as
Owner of Winter White BF XR8 2006 Model Difilippo & X-Force Exhaust, BPR CAI and CV Performance Custom tune. ZF Auto 238.5 RWKW "A careful driver is one who honks his horn when he goes through a red light." :evil3:
04-04-2009, 12:55 AM | #33 | |||
Constant annoyance
GT Club - no longer for ford enthusiasts, now for fat old men who need air con and power steering for the maccas drive through. |
04-04-2009, 07:28 PM | #34 | |||
04-04-2009, 07:38 PM | #35 | |||
04-04-2009, 07:42 PM | #36 | ||
Afterburner + skids =
Needs more engine.
05-04-2009, 11:05 AM | #37 | ||
Gunna girlie-man
Very impressive, i wonder what the trade price for a new head gasket from repco would be...
WADE CAMS-- UNLEASH THE POWER!! <INSERT WITTY SIGNATURE HERE> Daily- 05' BA futura... work done. Cruiser- 85' VK berlina... more work done |
05-04-2009, 09:28 PM | #38 | |||
Bseries
His: 2003 BA Fairmont in Arctic White/Mercury Silver Hers: 1999 AU Forte in Amaretto Check it out: http://fordforums.com.au/showthread.php?t=11336211 |
05-04-2009, 09:38 PM | #39 | |||
But we dont have any in stock, can get it overnight from sydney, but its $10,091 for delivery overnight... Cheers
06-04-2009, 10:24 AM | #40 | ||
Not that big! i reckon i could drive that down parramatta river!
i wonder if you can flash tune it :P
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery! Insta@mooneye_ghia White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly |
06-04-2009, 04:33 PM | #41 | ||
Tribal Elder
The sums dont add up. 15'000 container capacity, each container is 21 tonnes gross= 315,000t plus fuel. States load capacity of 123,200t ???May be they allow a loss of containers in transit.
06-04-2009, 06:24 PM | #42 | ||
Gunna girlie-man
is that american or aussie ton/tonne? i dont know what the difference, if any would be.
07-04-2009, 08:31 AM | #43 | |||
doof doof doof doof
07-04-2009, 01:50 PM | #44 | |||
Red is nice Mark.
It really depends what the goods are. I suspect very few containers are shipped at full weight capacity, but i bet they are all full.
Twin T3's TE 50 #72 Blueprint & TS 50 #105 Blueprint : |
07-04-2009, 01:53 PM | #45 | ||
Tribal Elder
We bring in 1-2 per month, all full, all about 21t. Its not economical paying to ship fresh air. But, back to topic-------
08-04-2009, 10:01 AM | #46 | |||
Red is nice Mark.
09-04-2009, 07:09 PM | #47 | ||
EF Ghia
http://www.youtube.com/watch?v=gG0vc...eature=related
it burns too http://www.youtube.com/watch?v=2oRlt...om=PL&index=11 when its not on fire |
09-04-2009, 09:04 PM | #48 | |||
Yes there was quite a serious fire in the superstructure when it was being built. |
01-05-2009, 03:36 PM | #49 | |||
www.argonautica.com.au
Theres a few interesting comments in this thread...I was in the Merchant Navy for 12 years, mostly spent on VLCCs (Tankers) for Shell, and BP. Yes, the ships are this large, the engineroom usually have 4 engineers, of which 1 is the C/E - my background. Used to do 4 month on / off trips...anyway... The engines are generally 2 types - either Sulzer or MANB&W, all built under license by the various yards around the globe - typically Korea and China. These are Slow speed engines, 2 Stroke diesel, utilising scavenge entry ports and a single exhaust valve. They almost always run on HFO (Heavy Fuel oil) anything from 300cst to 500cst on average (viscosity). You need to heat the HFO up to about 140 degrees, filter, purify, and then inject through fuel valves in the cylinder head. Distillate is only ever flushed through the system when going into layup or drydock, you don't normally change over to Distillate on entry into port. The engines have a piston rod and a con-rod, with a cross-head bearing between the two which slides up and down bearing rails within the crankcase, keeping the piston going in a straight line. Very different engineering to that of standard diesels or petrol engines. Gas turbines are costly (CAPEX and OPEX), only really found on some cruise ships, destroyers where speed is critical, or space saving is critical. HFO Slow Speed engines are becoming quite efficient and cost effective compared to the refined fuels needed in GTs. Remember you are trying to propel a large mass through the water...you would need quite a few GTs coupled through gearboxes to a drive system which would prove to be cost prohibitive...only really used where the cargo are passengers - minimise vibrations through the superstructure. I have attached a few pics of some the vessels I worked on, the dodgy looking guy in the photos is me.... (PICS: British Harrier, Switchboard, Cape Horn 1&2, Turbo Filter, VLCCx2, HMD Yard british Tenacity building). Cheers.
2006 F6 Tornado / 2003 Subaru STi / 2004 Subaru STi / Boydster III Rod / 2011 Civic Type R / 1963 Lincoln Continental |
01-05-2009, 09:22 PM | #50 | ||
The marine pilot that guide that thing into port deserves their money. And I thought driving a HR through Newtown (Syd) was hard...
Don't they have those little joystick things to berth? How surreal would that be, using something like you would use playing PlayStation to park a 400m super freighter. Nuts.
93 NC2 Fairlane Ghia Sportsman. Standard Tickford 162kw engine and touring suspension, factory LTD trim option plus EF Ghia wheels. Other rides: Range Rover Sport, Mini Cooper Chilli Cabrio |
02-05-2009, 12:31 AM | #51 | |||
