Old 27-03-2009, 06:29 PM   #1
zard 302
Default i16 misses under acceleration
Hey guys and girls.I have a problem with the wifes AU II.We filled up with a bad batch of fuel out woop woop way and managed to limp to the nearest ford dealer who replaced fuel pump and filter and took wads of cash.The car still runs like a hairy dog with worms and i have run copious amounts of injector cleaner and replaced fuel filter several times but still runs like crap.Have just replaced injectors,fuel filter,new sock over the fuel pump pickup and cleaned the throttle body.Just took it for a spin and no improvement at all.Any ideas on what to do now,Boy i love my BA even more now !
zard 302 is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2009, 06:44 PM   #2
bloggs24
possibly 02 sensor. Are you sure its fuel, maybe spark plugs/leads?
bloggs24 is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2009, 06:56 PM   #3
zard 302
ah sorry new iridium plugs 5000 k ago, was going to try a new set of leads next but were do you stop.The local mechanic couldnt find a problem with it so went to ultratune for a service and all they did was put more injector cleaner in the tank.
Old 27-03-2009, 06:57 PM   #4
zard 302
any way of checking O2 sensor ?
Old 27-03-2009, 07:04 PM   #5
rag top
rag top's Avatar
Did they remove the injectors and test them individually or did they just run the injector cleaner through the fuel system???
Old 27-03-2009, 07:13 PM   #6
zard 302
They just ran the cleaner through the tank. I replaced them today with new ones but it doesnt seem to have made a difference.
Old 27-03-2009, 07:29 PM   #7
The Monty
Just slidin'
The Monty's Avatar
Id say plug leads, or a plug may have come loose, they do that sometimes. Otherwise, try cleaning your air filter, or get a new one, or Oxy sensor.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 27-03-2009, 08:33 PM   #8
GK
Walking with God
GK's Avatar
What did you replace today?
If you haven't replaced the plugs, I'd just buy a cheap NGK set for $25 odd bucks. Cheap and easy to try.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 28-03-2009, 08:54 AM   #9
Sox
RIP...
Sox's Avatar
You probably still have a bucket load of whatever crap came out of the bowser in your tank. It could be water.
You can try pouring a bottle of metho in your tank, but it more than likely needs draining/cleaning.
It's really unlikely to be anything else if it started when you had the bad fuel issue.
Oval Everywhere...
Old 28-03-2009, 09:12 AM   #10
zard 302
I removed the fuel pump and syphoned the tank and is all clean.The bad batch of fuel was about 6 months ago so i was leaning towards a fuel issue but maybe its electrical ? Its okay when you drive normally but if you give it a bootful to overtake it just dies and misses.
Old 28-03-2009, 09:57 AM   #11
EvilChief
Boost Addict
if u can isolate a cylinder on which the misfire occures, its more than likely an ignition related issue. missing under acceleration (load) normally points towards a weak coil and stuffed leads.
i wouldnt just keep replacing stuff, raother more isolate the problem and diagnose the correct part
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build)
Ford BA XR6T Ute - daily driver
Ford FG XR6T Sedan - cruiser
do you see a general trend? I DO
Can't live with it, can't live without it!
EvilChief is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2009, 01:18 PM   #12
zard 302
wouldnt a missfire or stuffed ignition leads come up on a diagnostic code on the dash when they do a service ??Any way of checking diag codes myself ??
Old 28-03-2009, 02:38 PM   #13
SIKSIX
Its gone V
SIKSIX's Avatar
i have a simular problem and am thinking of coil packs because id doesn't happen to me when the car is cold, rather only when its hot.
i just havent had the time to change them to see if it is that.
SIKSIX is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2009, 02:48 PM   #14
Sox
RIP...
Sox's Avatar
Ok, so let's get this right.
The car was running fine 6 months ago. You then had a bad tank of fuel, and the car straightaway ran badly.
You had things done at Ford straight after the bad tank of fuel, and it didn't solve the problem at the time or it did solve the problem at the time and now the problem has come back?
In any case, if the fuel system is ok, and it seems so from what you've said, then it can only be the ignition side of things.
Oval Everywhere...
Old 28-03-2009, 07:10 PM   #15
JC
JC's Avatar
I had this happen on my AU2 wagon on the way back from Sydney, and it turns out it was a broken high tension lead on no 6 cylinder - at low throttle, it carried the spark fine, but anything more than half throttle induced a misfire.
3 things directly control spark:
1. Spark plugs (at $25 a set easiest to replace first, and if this is not the problem, you put the old ones back and keep the new ones for next service)
2. Leads (at $60 odd a set, next cheapest, and if not the problem can also be used at next service)
3. Coilpack - cost varies depending on supplier, but work on around $100 to $150 for a newie, so replace this last. They typically need replacing around the 150,000 to 200,000km mark.
Ford Performance Club ACT
Old 28-03-2009, 07:14 PM   #16
justa6
justa6
justa6's Avatar
lead's
justa6 is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2009, 12:39 AM   #17
EvilChief
Boost Addict
no, only time it may come up and a engine light is if a misfire causes detonation (ie in high rpm)
N12 Pulsar - sold
Old 29-03-2009, 10:28 PM   #18
toolchick01
Now with an AU XR6
toolchick01's Avatar
How about a leak in the inlet manifold. My partners BA had a similar problem. We changed the spark plugs and ran injector cleaner though it and still nothing. Took it down to knox Ford, they found the problem straight away, changed the gasket and now it's good as new. Just a thought.
Stop chasing me! I don't have any donuts!
1999 AU1 XR6 VCT - Now with a momo steering wheel!
Manual - 18" Koya Race Tek's Black with polished lip - Lowered - Series 2 tail lights - Pioneer P80 Head Unit - Clarion Front 6" Splits - JL 5x7's Rear Coaxials - Clarion 4x90w RMS amp - Clarion DPX1800 800w RMS mono - 2 Clarion PXW1251 400w RMS 12" subs
Team Deck Chair Member ............ Once you sit down, you'll never stand up.
toolchick01 is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2009, 11:39 PM   #19
JC
JC's Avatar
Yep - entirely possible, depends on the misfire and the conditions it's happening under, but if it's only at full throttle, then it's unlikely to be a gasket issue - good thought though.
