Old 10-02-2009, 11:10 PM   #1
R0BD0G
R0BD0G's Avatar
Default Escort mk1 Wiring
what ignition wire is the on? as in like off/acc/on/start.
and what wires go to the brake light sender on the pedal box
1628 Escort Project Thread
67.3 RWHP - Paramount Performance Dyno
DJ Automotive Tuned with proper jets
http://fordforums.com.au/showthread....4&page=1&pp=25
R0BD0G is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2009, 11:56 AM   #2
R0BD0G
R0BD0G's Avatar
anyone?
Old 14-02-2009, 01:59 PM   #3
Puzzlescort
Rally Nut
Puzzlescort's Avatar
I have a couple of work shop manuals for Mk1 Capri & Mk2 escorts, not much changed in the wiring between the capri and Escort, if you let me know what wires are there I will see if the match the wiring diagrams I have, If they are the same i can scan the wiring schematic and upload
Puzzlescort is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2009, 09:27 PM   #4
R0BD0G
R0BD0G's Avatar
yeh ive got a wiring map for the mk1 escort. but it isnt detailed enough. either of them
it doesnt actually say what the "On" wire is
Old 15-02-2009, 09:32 PM   #5
_CRUZ_
Ford Owner
_CRUZ_'s Avatar
check with some wire pieces as you would hoy wire a car mate. youll soon ssee the acc and the wire that needs to be touched to start ignition.
_CRUZ_ is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2009, 08:57 PM   #6
R0BD0G
R0BD0G's Avatar
What Wires??? i just wanna know what wire is the on? is it gonna be the one that the little pink wire goes to
Old 23-02-2009, 07:56 AM   #7
cortina-mk1
Heavy right foot
cortina-mk1's Avatar
do you or can you get a multimeter or test light ?
the workshop manual schematic diagram will tell you which colour wire goes
where
look in the legend to see what the abbreviation of the pink wire is and then
trace it
cortina-mk1 is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2009, 07:50 PM   #8
R0BD0G
R0BD0G's Avatar
well the little pink wire goes to a light on the dash for seatbelts?
Old 24-02-2009, 08:31 AM   #9
cortina-mk1
Heavy right foot
ok so that wire can be excluded then.
can you get out your ignition switch wires ok ?
if so turn the ignition ok and using a test light go through each wire and you will see
which has power ....this will narrow it down for you
use that with the schematic in the workshop manual and you will then know which
color wire is the ignition ON
Old 24-02-2009, 08:32 AM   #10
cortina-mk1
Heavy right foot
theres actually a wiring diagram posted in the thread up from this
Old 24-02-2009, 06:52 PM   #11
R0BD0G
R0BD0G's Avatar
yeah i didnt understand the wiring diagram that well. so according to the back of the ignition barrel the one to cut and join is the black with yellow =
Old 25-02-2009, 09:01 AM   #12
cortina-mk1
Heavy right foot
i spose i should ask what are you actually trying to achieve or do ?
fix or connect or ?
Old 26-02-2009, 09:41 PM   #13
R0BD0G
R0BD0G's Avatar
project thread tells all. installing a tacho =].
Old 02-03-2009, 11:51 AM   #14
spliceMk1
spliceMk1's Avatar
Is this the same colour you are doing your project in? This is mine in the day-glow green, but will be getting a full resto within the next 2 years so colour will be changing to something more original.
I love my Escort.
spliceMk1 is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2009, 05:02 PM   #15
R0BD0G
R0BD0G's Avatar
simla but diffrent:P
real similar colour though...
mine got a full bar on the front, square headlight grill, different blackouts, mk2 Ghia/ RS wheels, no bonnet pins.
thats a sweet little ride but aye. what motor u runnin?
Old 03-03-2009, 09:03 AM   #16
spliceMk1
spliceMk1's Avatar
thanks mate, it's my pride and joy :-)
Running a 2 litre Pinto, twin 40mm webers and genie extractors. Suspension, brakes and box are all Mk2 - 2 litre bits. I'm pretty much aiming to make it a Mk1 Mexico clone.
I'll look forward to seeing more pics of your project
I love my Escort.
