Old 27-08-2007, 10:18 PM   #1
dash007
dash007's Avatar
Talking starting prob's
Well back again,
This time car won't start (click click click ) so bought a new battery and made no difference.
So I'm thinking "starter motor" what do you think :
If it is ? Where's the best place to buy one. Should I go 2nd hand ? Or new ?
Cheers Dash.
I'm in Berwick Vic.
dash007 is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2007, 02:15 PM   #2
dirty hands
Over Thinker
dirty hands's Avatar
reconditioned starters are ok from auto electricians
new ones have a 2 yr warranty depends on how long you want to keep your car
My car goes Brumm Brumm
dirty hands is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2007, 01:17 AM   #3
gwak2007
Piston Broke
gwak2007's Avatar
Cool Wiring issue?
Check your wiring just in case you have a bad earth to the engine block. Also check your positive cable to the starter motor solenoid in case there is corrosion on the connection. :
gwak2007 is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2008, 10:24 AM   #4
steelie
Default Had the same \similiar prob
I had the same problem and took my starter motor of and had the brushes checked and all was ok-mine was not starting when hot-so i checked my wiring harness and found it was getting old-to solve this problem i by-passed the main harness from the ignition to the starter motor with a relay that i fitted onto the firewall and have had no probs since-i had trouble finding starters as mine was a bosch which they dont do for these anymore.
steelie is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2008, 09:58 AM   #5
290v
290v
290v's Avatar
KC KE early model Lasers had an ignition problem ( Common Fault) the contacts inside wore out and also the starter solinoid wire i had to replace the connector on the wire
BA GT 2003 Silhouette
4 Speed Auto
290v is offline   Reply With Quote Multi-Quote with this Post
