29-09-2008, 03:01 PM | #1 | ||
Hi,
My battery died on my remote for my 2004 Fiesta Zetec. I got the battery replaced, but now the buttons arent working. Is there some way i can fix this from home? As i called my ford dealers and they said it will cost $150 'to hook up to the laptop' and a big 2 hour job. I'm sure they are full of it. |
30-09-2008, 11:32 AM | #2 | ||
Lil Henry
dont know if this will work but give it a whirl.
1. Obtain all keys 2. Turn Ignition switch to position 1 3. Wait 10 seconds 4. Ensure clock LED illuminates (for approx 5 seconds) 5. Remove igniton key whilst LED illuminated. 6. Programming mode now enabled for approx 20 seconds proceed as below a,Point key at receiver, (located near interior lamp) b, press and hold UNLOCK button, after 1 second key LED will flash once c, press LOCK button 3-5 times d, release UNLOCK button e, keep key pointed at receiver until LEDs in clock and key have flashed 5 times Repeat above within 20 secs to program remaining keys To exit programming mode, switch ignition ON and OFF and wait approx 20 secs. |
30-09-2008, 01:10 PM | #3 | ||
Finally rollin on 20's
wow, that sounds insane!!! Where did you find that?
Fiesta ST..... Colorado Red...... SOLD Territory Turbo Ghia ..... Winter White SOLD - Good bye my little buddy!!!! K&N, F6 Snorkel, Debung, 20" Enix Turbine in Gunmetal, 7 seat rear springs. |
30-09-2008, 01:26 PM | #4 | ||
Lil Henry
google of course. i dont know if it will work i think it comes off a older model fiesta as aussie ones dont have a led in the key. but it is worth a go
30-09-2008, 01:56 PM | #5 | ||
Thanks guys, i'll give it a whirl tonight
30-09-2008, 08:33 PM | #6 | ||
Lil Henry
Ok it has come to my attn that that was for an ifrared 2 button remote.
my bad, This is for a Fiesta 3 botton W1 key apperently (Radio 3 Button) - Key Remote Programming 1. Insert Key and turn to II, then Turn Key from II to I and back to II four times within 3 seconds 2. The PATS LED should light. Turn Key to Position 0. 3. Press the Unlock button and keep it pressed until the PATS LED flashes 4 times. 4. Add additional fobs the same way. Turn to II and back to 0 to end |
30-09-2008, 08:48 PM | #7 | ||
Lil Henry
I have also looked it up in thee owners manual but that only explains how to code the Keys. not the Keypad.
06-10-2008, 11:31 AM | #8 | ||
Thanks guys, i finally got it working.
I tried the ignition trick and it didn't seem to work for me, but then i pointed the fob at the rear vision mirror and held lock/unlock and it seemed to work. Doing that also switched inbetween different lock cycles (one press driver door, 2 press all doors). Thanks for the help, so much for $200 , a big job and hooking it up to a laptop! (thanks ford dealers lol). |
