I'm having issues with my 93 kh laser where the engine overheats, and i think it's because the fan is not kicking in. any suggestions on what to do?
Over Thinker
get two wires running from the battery and direct test the fan
replace the resistor /check all the wirin connections fit a new thermostatic operation switch go to a wrecker and buy one that works
My car goes Brumm Brumm |
growing up is optional
Easiest way to check the fan is to unplug the thermo switch near the distributor. It will have a single wire going to it. The fan should run with the wire disconnected and the ignition on.
If it doesnt, you will have to look further for a wiring or fan motor fault. If it does, the wiring is fine and the thermo switch is stuffed. |
