Old 27-04-2005, 10:38 PM   #31
brenx
brenx's Avatar
Originally Posted by XRQTOR
Ca someone please explain this cross ply stuff, tailshaft loop what do they do.
Crossply tyres allow the car to sway with slicks (as slicks are crossply). The tailshaft loop is an aftermarket item that stops the tailshaft from pole vaulting your car if it breaks and falls out.
That reminds me. I should fit mine to the new car :Reverend:
Brenden
74 XB Fairmont (street car) 11.07@123.02mph. 08 LV Ford Focus XR5 (daily).
Tuned by Hallam Performance
brenx is offline   Reply With Quote Multi-Quote with this Post
Old 27-04-2005, 10:44 PM   #32
XRQTOR
XRQTOR's Avatar
Brenden
Thought thats what the loop was, whats crossply mean.
What do the nitto 555R's fall under.
XRQTOR is offline   Reply With Quote Multi-Quote with this Post
Old 27-04-2005, 10:46 PM   #33
Chris
AFF.com.au
Grip baby, grip
Drag radials.
Chris is offline   Reply With Quote Multi-Quote with this Post
Old 27-04-2005, 10:58 PM   #34
Tornado
AKA MYTE8
Tornado's Avatar
Thats great times your getting Simon, well done.
Tornado is offline   Reply With Quote Multi-Quote with this Post
Old 27-04-2005, 11:00 PM   #35
brenx
brenx's Avatar
Nitto's are radials. Straight from the dictionary ;) crossply
cross-ply adj : of or relating to an older kind of automobile tire that had a flexible tread and relatively stiff sidewalls
The cross-ply tire is made up of superimposed layers of textile cord running at alternate angles from bead to bead. With this design the sidewalls and tread are not differentiated and this gives the tire structure great rigidity. With a cross-ply tire the maximum width and the height of the tire above the rim are approximately equal. This relationship is known as the aspect ratio and with cross-ply tires is approximately 100%, giving the cross-ply tire its unique "tall" appearance.
Compared to a radial :
The beauty of the radial design is that it separates the functions of the sidewall and crown of the tire, allowing greater vertical flexibility whilst ensuring that there is still as much surface in contact with the road as possible. In classic radial tires the sidewall has a one or two layers of textile cord giving good flexibility, and the tread is made rigid by combining the casing layer with two (or more) layers of steel cord bracing plies. Both these factors give the classic radial tire excellent road holding capabilities and a longer life span when compared to vintage cross-ply tires.
Old 27-04-2005, 11:28 PM   #36
CAMS290
trying to get a leg over
CAMS290's Avatar
Well done Simon, you have come a LONG way in very little time with those times
Cameron
CAMS290 is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2005, 10:57 AM   #37
Boosted
Congratulations Simon, that's certainly one awesome head and cam combo. A credit to all involved.
Makes mine look like a stocker. :
Boosted is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2005, 09:24 PM   #38
SpoolMan
Solution Was Boost 4?, 6 & 8
SpoolMan's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF events and sponsorship. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Everything you do to help this place run smoothly! Technical Contributor: For members who share their technical expertise. - Issue reason: The awesome Technical and Service how to's in the FPV /XR6 /G6ET turbo threads..  and his own build threads that inspire people to have a go... enabling people to save money and realise the dream of working on their own cars as well.
you just need a little more sauce...
[SIGPIC][/SIGPIC]
AUTOTECH TUNED EDELEBROCK CHARGED
2017 GT Mustang Plenty of RWKW
SpoolMan is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2005, 09:35 PM   #39
rodderz
rodderz's Avatar
Is that more sauce, more balls or a combo of the 2? lol
rodderz is offline   Reply With Quote Multi-Quote with this Post
Old 29-04-2005, 04:25 PM   #40
geea
Turbo God
geea's Avatar
Well done Simon, great results.
Will you be heading out to Calder anytime soon? I won't be there tonight but i'll be there the following 4 Fridays, weather permitting. We could have some good runs.
RUMBLE 385rwkw's
10.688@128.28
RIP BOOF 28/02/03-20/08/04 12.24@115.38mph
.....HPF.....
geea is offline   Reply With Quote Multi-Quote with this Post
