My right hand side washer jet is blocked, does anyone know how to fix this problem because I can't wash my windscreen when its dirty.
2015 MK7 VW GOLF GTI __________________
Previous Cars 2002 AUIII XR6 1995 EF Falcon XR6 2003 LR Focus Zetec 1989 KE Laser TX3 |
Old enough to know better
Adam, try pushing a pin into the hole on the jet. If it is blocked there, that should clean it out
Thanks steve....its both little jets as well
broken washer jet from the inside....have to order a new on tomorrow i think
Did I bugger it up with my pin suggestion???
2007 Ford Focus Zetec
Doubt a pin would stuff it up.
You're meant to use a pin to adjust them. |
no where the rubber hose connets to the plastic jet under the bonnet is broken and water just sprays on my engine. So i will fix it up. Don't know how to get the broke plastic that is stuck in the hose out....any suggestions
hahaha my old ute used to blow hoses off under there all the time.
#9 | |||
Well I bought the plastic elbow to replace the broke one. Only $2.25 so cheap and nasty. Still had trouble with the plastic in the rubber hose. So I crushed it with my hand and broke up the plastic and put washer on and the pressure of the water took all the bits of plastic out...great job by me once again
You never cease to amaze us all Adam!!!!!
I think you will amaze everyone at SFS next year Steve.....
#13 | ||
Zoom Zoom
Jeez will you two get a room already?
2012 Mazda3 MPS
#14 | |||
#15 | ||
Because I have a 03 LR Focus and it is out of warranty.
#16 | ||
ah yes, it is 2007! lol
#17 | ||
Non-Regular Member
Does the warranty start counting from build date or delivery date?
#18 | ||
Delivery date
