29-12-2006, 06:36 PM | #1 | ||
can the bearings in the idler pulleys on the tensioner be replaced or do you have to replace the whole tensioner. One of mine has become very squelly and it's annoying the crap out of me. Just hoping I don't have to replace the whole tensioner.
Cheers, Damo |
29-12-2006, 06:43 PM | #2 | ||
rofl copter
ull probly find its wear in the tensioner puller wear the bearing is. u may be able to replace them but not sure if the pully would break before the bearing comes out, a press would be the only way to get it out too id say
GQ patrol.
.... thats all |
29-12-2006, 06:50 PM | #3 | ||
yes damo you can
i have replaced them in the past but there is a trick ti it if you come down in the morning we can pull it off and replace it for you if you want jason
no longer have a ford but a ford man at heart R.I.P 98 EL MAY YOU HAVE A GOOD LIFE IN FALCON HEAVEN [SIGPIC][/SIGPIC]
29-12-2006, 06:55 PM | #4 | ||
bugger. :( Might try source a second handy.
Cheers |
29-12-2006, 07:36 PM | #5 | ||
Thanks for the offer Jason, but I don't have a new bearing and i'm broke and won't be attending tommorrow. Can you tell me the trick, and do I need a press to replace it ?
29-12-2006, 07:41 PM | #6 | ||
yes you need a press to do it you also need a die grinder to release outer lip
its not that easy i would get secondhand one to tie you over then when we get a chance ill show you how to do it jason
29-12-2006, 07:54 PM | #7 | ||
cheers, i'll price up a new one and a second hand one and go from there.
29-12-2006, 08:59 PM | #8 | ||
- BOOYEH -
I have a second hand one for ya Damo. Its yours if you can get down here and get it.
1993 EBII Fairmont Turbo T04e 7 psi
29-12-2006, 10:40 PM | #9 | ||
Cheap Solution
Take pulleys off the idler Carefully flick out the bearing covers with a sharp knife Clean properly and repack with grease, replace covers Flip pulley over 180 degrees when reinstalling on idler as one edge of the pulley is usually less worn from the belt than the other especially when car has a few kms up. I do this every 30000kms on taxis, pulleys last for about 200000km normally which is when you have to replace idler anyway and when you buy it from Ford (about $120 I think) you get 2 new pulleys A dearer solution and needing more tools is to press out bearing from pulley, go to bearing store and get new bearing for $5 or so. Can also get metal pulleys from bearing stores, these tend to last a bit better I have found as they deal with heat better than plastic, about $30 to $40 from memory. |
30-12-2006, 12:52 AM | #10 | ||
thanks for the advice guys, Gubas I might take you up on that offer. My car will be off the road for 6 months anyway as of late January so not too fussed about it now.
30-12-2006, 01:16 AM | #11 | ||
- BOOYEH -
No worries. I'll bring it up to the next cruise if your going
30-12-2006, 01:56 AM | #12 | ||
likes falcon's
or just buy them premade...lol was around 50-60 for brand newies for mine
www.carhubsales.com.au |
30-12-2006, 11:50 AM | #13 | |||
30-12-2006, 11:55 AM | #14 | |||
