Old 26-01-2008, 03:46 PM   #1
chief
FTF Club Moderator
chief's Avatar
Default AU's and rust + How To's (56k beware)
This is a post to warn people about rust on their AU's. We know that cars made of steel will rust. Most of us want to preserve our cars for a long time so its important to do the little things to make our cars last. Unfortunately our cars are not brand new covered by a paint and corrosion warranty any more.
On Thursday I decided to detail the car and inside the doors. I thought I should take the rubbers off the car as it would make the job a lot easier. In doing so I found some nasty rust. Under the rubber that goes from the bottom of the rear door up along the roof line down to the bonnet there is a join of two pieces of sheet metal that has been spot welded. Where the two pieces of metal meet there is no paint between them and being having moisture under the rubber trapped has caused the rust. Here is some photos of the rust I found.
I have written a how to on taking the door surround rubbers, door rubbers and the windscreen cowling off.
First we are going to take the door rubbers off. Weather it be a wagon, ute or sedan the method is still the same. I did this on the 4 post hoist at work as it makes it easier when working a chest height.
How to remove the door rubber.
1. Open door.
2. This is the rubber we are going to remove.
3. To remove the rubber from the top it lifts strait off. It is held on securely but it just squeezes on and off.
4. To remove the bottom half of the rubber, there are clips in the door in the shape of a T. The rubber on the back side has tiny holes in it spaced between 5 to 10cm. The rubber holes are placed on the T. Grab the rubber and pull in one direction along the rubber, then while stretched, pull away from the door. This will stretch the hole and remove it from one end of the T. The other end just slips right off then. Do this repeatedly to remove the rubber
Here you can see all the T clips. You can see there is a few of them, only on the bottom of the doors.
This is the T holding the rubber on.
5. With the rubber off clean any dirt and moisture away.
6. I would recommend adding a coat of wax under the rubber, to help prevent water penetration.
7. To install the rubber, put a hole over the T and pull the rubber to stretch the rubber, so the hole increase in size and place over the other side of the T.
8. Top half slides right back on.
9. Check to see if it is sealed properly by going for a drive and listening for noise.
How to remove the door surround rubber.
Next is the long rubber. This rubber has no clips like the doors do. The rubber slides over the two pieces of sheet metal.
1. The best way to tackle this long rubber is start from one end and work your way to the other end. Easiest place to start is the rear door. This will be different for our 2 door friends but the principal is still the same.
2. There is a part of the long rubber at the top of the rear door that is held on by a channel in the door surround and the rubber sitting in this channel.
3. Slowly take the rubber off. The best way I found was to only take half the rubber off. Clean away any dirt and moisture. Wax the area. Reinstall the rubber, then do the front half. It just made it easier to handle and reinstall the rubber.
4. Reinstalling the rubber is easy. It just slides back into place. The front at the a pillar is a little challenging but is falls back into place. Under this rubber is where I found my rust.
5. If there is no rust, just clean and wax and away you go. If there is, its best remove it. What action to take will depend on the severity of the rust.
How to remove the windscreen cowling.
1. To remove the cowling the wipers need to come off. At the base of the wiper are is a plastic cover. There is a little notch there to help lift the cover off.
2. There is a single 12mm nut and washer. Before you undo it. Mark on the windscreen with some tape where the wiper sits when the wipers are turned off. Reason being is that the bolt that holds the wiper on is a splined bolt.
3. Open the bonnet.
4. Remove the rubber that sits on top of the firewall. Like the other rubbers it slides right off. The rubber is does have a left and right side as it is not symmetrical.
5. Next is to remove the trim plugs holding the cowling down. Just work through them. Being that they probably never been undone, they should come out with out needing to wrestle with them.
6. All that needs to happen is lift the cowling up and take it out. It may need to be wrestled with, just due its design it wants to snag itself on the bonnet.
7. Clean all the leaves, dirt and moisture.
8. Add a coat of wax for good measure.
9. Now that it is clean, time to put it back together. First place the cowling in its position. Then install the trim plugs and firewall rubber.
10. Close the bonnet. Time to do the wipers. Align the wipers with the markings you made. Then slide the base over the splined bolt. Check to see if it is aligned. Tighten the nut tight (I do not have the correct torque setting), don't forget the washer. Click the plastic covers in place.
11. Remove the tape from the windscreen and test wipers.
The other rubbers are attached in the same principal. Be it just sliding on or off, with little T clips or sitting in a channel. I would recommend doing the other rubbers as well.
Albert Einstein:
Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom.
(It is more difficult to alter a preconception than split an atom)
Falcon Tickford FPV (FTF) Car Club of NSW
Fords in the Park 2010
I use and recommend Stingray Car Security.
http://www.stingraycar.com.au/
chief is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2008, 04:19 PM   #2
JMO
JMO's Avatar
Nice right up. I have noticed little spots of rust here and there and this guide sums it up nicely. You might like to add under the scuff plates. I've found moisture under them after rain as well as small rust spots.
Excellent work!
JMO is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2008, 04:22 PM   #3
chief
FTF Club Moderator
chief's Avatar
Working on the scuff plates. The only rubber I didn't take off. I know there is moisture there, especially with the skirts.
Albert Einstein:
Old 26-01-2008, 05:41 PM   #4
poolkeeper
Its Resonating!
poolkeeper's Avatar
I did this, but mine wasnt as bad. You get a quite good feeling after cleaning all that gunk out...
poolkeeper is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2008, 06:54 PM   #5
LPGUTE
LPGUTE's Avatar
my wiper wounldnt come off...
Many Thanks
2001 AUII Factory LPG Manual XL Styleside Box
High series bonnet
Clear Side Indicator
K&N Air Filter
BAXR6T Snorkle
Low Fronts, Super Low Leafs
LPGUTE is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2008, 07:04 PM   #6
poolkeeper
Its Resonating!
poolkeeper's Avatar
It should, just that one bolt and a gently tug and it should come off.
Old 26-01-2008, 07:19 PM   #7
LPGUTE
LPGUTE's Avatar
got the nut out but it just wouldnt let go and i was pulling so hard even my car was moving...
Many Thanks
High series bonnet
K&N Air Filter
BAXR6T Snorkle
Old 27-01-2008, 12:32 AM   #8
blackers10
blackers10's Avatar
ok with that write up..
whats the BEST product to use to remove all that buildup of gunk??
i dont want to be hosing in there LOL
mine has a heap of gooy grimey dirt on the join of the outter and inner door skin on the BOTTOM of the door..
being such thick gunk i dont know what to hit it with so it doesnt scratch the hell out of my car (a scraper would be the easiest tool but the worst for possibly making more spots for rust to form via scratches)
cheers
Old 27-01-2008, 08:31 AM   #9
poolkeeper
Its Resonating!
poolkeeper's Avatar
Well I just wiped it down, then polished it up with some cut and polish wax.
Old 27-01-2008, 10:08 AM   #10
LPGUTE
LPGUTE's Avatar
i finally got the wipers off and i found the place where my car is leaking water into the car aswell. two birds with one stone!
Many Thanks
High series bonnet
K&N Air Filter
BAXR6T Snorkle
Old 27-01-2008, 12:14 PM   #11
chief
FTF Club Moderator
chief's Avatar
cheers
I just used a moist shammy. Also if you use a cleaner wax such as Megs NXT Wax it should help remove any dirt left on there. If it is particularly hard to come off, wrap the shammy around a flat head screw driver. Be very careful though.
Albert Einstein:
Old 27-01-2008, 11:09 PM   #12
lostdude
lostdude's Avatar
Hi chief, i have a spot on my roof where the paint first started to crack, then it started to bubble up around the crack.
am i up for a respray?
Prev: 98 Au forte :
Now: 05 Wrx
lostdude is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2008, 01:10 AM   #13
chief
FTF Club Moderator
chief's Avatar
I am not a rust expert, but more than likely. The only proper way to get rid of rust is to cut it out. I am going to find out Tuesday about cost for getting my rust cut out and repainted.
Albert Einstein:
Old 18-02-2009, 10:59 AM   #14
blackers10
blackers10's Avatar
oh bugger....
i found another piece of rust on my car AARRRGGHH!!
its the rear right IRS mount plate
the piece of steel thats welded to the body that the rear left corner of the IRS cradle bolts to... it is just falling apart with rust... not good
Old 18-02-2009, 11:45 AM   #15
Rob
Living the dream
Between the bootlid and rear quarter panel, near the rear windscreen is another rust-prone area on sedans. Good idea to flush that regularly and coat with WD-40/wax/fish oil.
I'll check my other locations tonight. My AU seems to be fairly rust free, but it's a late 02 build, maybe the quality improved. I've seen some shockers though.
Rob is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2009, 12:08 PM   #16
ten[A]cio[U]s
ten[A]cio[U]s's Avatar
Nice write up chief. I have been wanting to take these off for a while. I went for a drive on some very dusty roads and wanted to remove them to clean them. Looks like there will be two reasons to do this.
Daily: AU Forte Wagon
Project: AU Fairmont - Wants to be turbo
The Family Car: 2009 G6E Turbo
Future fun: 1968 Ford Galaxie 500
ten[A]cio[U]s is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2009, 12:19 PM   #17
blackers10
blackers10's Avatar
found rust in debs car today.. in 1 of the seams under the rear right tail light assembly
Old 18-02-2009, 01:09 PM   #18
GK
Walking with God
GK's Avatar
Thumbs up
Great write up Chief. Perhaps submit this to Russ to be included in the Technical Documents section.
Cheers,
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 19-02-2009, 01:45 AM   #19
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Helpful and detailed posts on car care.
Cheers,
GK
Seconded.
No longer an 'active' detailer.
Dave_Obsession is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2009, 05:29 PM   #20
randel
randel's Avatar
Agreed, good write up..
Is there an easy way to clean out any leaves and gunk that may have gotten through the cowel and down into the lower inside part of the front guards?
Randel
Daily Driver - FG GS Ute
Toys - 351 XY Falcon and FG GT
randel is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2009, 12:01 PM   #21
ten[A]cio[U]s
How much would new seals be? My rear ones are stuffed..
New seals all road then clean the gunk out when there off
Old 20-02-2009, 12:03 PM   #22
ten[A]cio[U]s
lol just noticed. Why no strocker!?
Old 21-02-2009, 09:56 AM   #23
ebxr82nv
Top corners of the windscreen under the rubber door seal and behind the mirrors are bad for it to.
9/98 AU1 XR6hp-about to retire from the road and be reborn on the race track.
86 ZL mint grandpa spec with premo sound and 150000km
07 TTG XForce, PLAZMAMAN, IDYNO TUNED, 349KW@all 4!
97 el futura MOCKed up with a 2500 stall, heaps of fun!
ebxr82nv is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2009, 10:11 AM   #24
LUXO_8
windsor user
er....maybe because with the post with that picture in it was done 26-01-08
Old 15-10-2016, 06:00 PM   #25
xr8cam
Default Re: AU's and rust + How To's (56k beware)
Randel
Did you get an answer regarding debris inside lowerf front guard.
xr8cam is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2016, 06:22 PM   #26
Rallye Sport
RS The Faster Fords
Rallye Sport's Avatar
Bootlid spoilers seem to be a problem, either the mounting holes go or they leak into the cavity and rust the bottom of the bootlid out. When I removed mine the build up of grime was staggering. Cleaned then waxed and reassembled but it still bothers me...
Trying an electronic rust control module, I hear good things, they use them in commercial air con systems and steel structures aswell with good results...
Mk1 GT Cortina Project.
FG XR50 Daily.
Old 15-10-2016, 06:48 PM   #27
xr8cam
Do you rub candle sticks over the area like you might on timber draw runners etc
