30-04-2007, 11:24 PM | #1 | ||
My 90 kf Laser didnt have a tacho instrument cluster. I tried to find a tx3 for a straight swap but had trouble finding one anywhere.
Anyways, since mazda 323 is practically same car, i bought a 91 323 tacho cluster hoping for staight swap. It works and is ok except now the dash lights are on in the car constantly and dont turn off even when the key is not in the ignition, and the gear shift lights dont work. The only time the lights go off is when i take the room fuse out. Obviously the wiring isnt right. Is there a way to fix this????? Thanks. |
01-05-2007, 09:45 AM | #2 | ||
What a performer!
No idea on how to fix your problem, but as you found out they can definately be swapped over.
I've got a 323 SS cluster in my TX3.
1981 Ford Laser KA :: E5 :: 2002-2003 1989 Ford Laser KE TX3 :: BP :: 2003-2007 75fwkW 1990 Ford Laser KF TX3 :: BP :: 2010-2011 1991 Ford Laser KF TX3 :: BP-T :: 2011-2015 109fwkW 2007 Ford Falcon BF XR6 Turbo Ute :: Barra 245T :: 2014-2019 324rwkW 1998 Ford Falcon AU XR8 Ute :: Windsor V8 :: 2019-2020 2008 Ford Fiesta XR4 :: Duratec 150 :: 2021-* 1998 Ford Falcon AU XR6 :: HP Intech :: 2021-* |
03-05-2007, 12:13 AM | #3 | ||
Problem SOLVED!
Found some live wires contacting from where original stereo used to be. I assume the original stereo was powered up from original cluster unit causing the thing to play up. Anyway, its all perfect now. 323 cluster looks much nicer than original. Was lucky, its got pretty low k's too! THanks. |
