Old 04-11-2023, 08:49 PM   #1
RadioactiveX
Diesel Motor
RadioactiveX's Avatar
Default Bleeding brakes to replace fluid
Hello,
My car is a 2011 Ford Focus TDCi. Does the brakes on this car have to be bled by a diagnostic tool, or is it ok to just use a brake bleeder vacuum pump?
Thanks,
Radioactivex
RadioactiveX is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2023, 09:19 PM   #2
foxtrot3
foxtrot3's Avatar
Default Re: Bleeding brakes to replace fluid
Hi. sucking the brake fluid out is always risky as all the seals in a brake system are designed to hold pressure in. Unless you get air in the system you wont need a diagnostic tool to bleed the brakes. Just do it the old fashioned way and pump out most of the fluid from the master cyl, top it up and repeat a few times for each wheel. Cheers MD
HI
I'M MICHAEL
foxtrot3 is online now   Reply With Quote Multi-Quote with this Post
Old 04-11-2023, 11:35 PM   #3
mad2
Regular...with metamusal
Originally Posted by RadioactiveX View Post
Hello,
Thanks,
Radioactivex
use a say 'horse' syringe [large type] to empty the master cylinder 1st & then top it up with fresh [which is what i did with my BA. got syringe from a place called "pet stock"], then follow what is mentioned below.
