Old 24-03-2024, 10:45 AM   #1
Luka
Default Missing connector pin for my alb relay for my 1997 el ford falcon
The relay box in the engine bay is missing the alb relay. When I looked at it closer I noticed that one of the pins is missing. I was wondering if this relay box is something I can replace myself (like does it plug in?) or would I have to pay an auto electrician to do it? I attached some photos of what it looks like. Thanks
Luka is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2024, 11:49 AM   #2
Default Re: Missing connector pin for my alb relay for my 1997 el ford falcon
That would suggest that you have the base model, that ABS was an option and it was not fitted to your vehicle. See https://fordforums.com.au/wsmpub//eflwx/2-8.html and check if it has a ABS modulator and tone wheels fitted and the ABS ground pin in the diagnostic connector. I suspect you will find none of these. Is it a sedan or a ute? Base model utes, being mainly sold as commercial vehicles in a more price sensitive market often had no ABS fitted. Similarly poverty pack taxis often came sans ABS.
This thread would also probably better fit in either this https://fordforums.com.au/forumdisplay.php?f=20 or https://fordforums.com.au/forumdisplay.php?f=29 this part of the forum. If you want it moved to where it might get more responses just ask.
Old 25-03-2024, 09:36 AM   #3
Luka
Thanks for the reply. Just checked and it turns out i have the povo spec gli model with no abs. Better for skids
Old 25-03-2024, 08:47 PM   #4
ToryMikey
Was just about to comment this was the case! My povvo spec XH ute is the same. No ABS on GLi sedan, wagon or ute (unless it was optioned up as such).
1996 XH Falcon GLi manual - Dynamic White
1998 EL Falcon Futura auto - Dynamic White
2023 SKODA Octavia RS - Moon White
1997 BMW E36 318i manual - Alpine White
ToryMikey is offline   Reply With Quote Multi-Quote with this Post
