What Wheelspin?
hey guys.
discovered last weekend that i have a bent axel on the rear passenger side. i have no idea how it happened but i now need it fixed. does anyone know a good price for a second hand axel? would anyone be willing to lend a hand doin it? i have never done the job before. i live in lara. 15 km's out of geelong....... :Reverend:
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw) 2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned) |
What Wheelspin?
im willing to pay with beer or money, im easy.....
![]() Join Date: Dec 2004
sechs?
What Wheelspin?
sorry?, lol
nah forget it :P (I'll wait for others to read and laugh (at me?))
No idea about axles on their own but I'm sure you could pick up a 2nd hand diff (make sure it has 28 spline axles) for very cheap and pluck the axle from that. |
What Wheelspin?
im assuming u meant s e x?
#7 | |||
don't worry, unlike your axle (and jjM) I'm straight
just bored at work |
#9 | |||
Parts bin special
Weekender 1964 US Falcon Futura convertible - Rangoon Red 260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels https://fordforums.com.au/showthread.php?t=11470868 Daily 2014 SZII Territory diesel - basic runabout Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more 2000 AUII Fairmont - XR wheels, Ghia interior 2010 FG XR50T ute - XR8 bonnet, Streetfighter intake |
What Wheelspin?
so can anyone actually help with my axel??
V8 Ute V8 Boat
i can run you throught it
jack car remove wheel on the disk there is a phileps head screw, undo it take the breaks off pull the rotor off there are 4 bolts that hold the diff and the axel berings on undo them, pull the axel out put new axel in then do it all up together its not overly hard takes around 2 houres if you havent done it before, but its not difficult
VE SS Ute manual 09 AU XR8 UTE 200KW manual 02 Challanger Ski boat V8 01 125 Thumpster 2010 Swag All set for the weekend |
#12 | ||
i had a bent axle (and just about every arm underneath as well) i picked up a single spinner diff out of a ef with 140k's for $80 disc to disc. its a fairly easy job as everything just falls out once u undo all the bolts.
V8 Ute V8 Boat
i think the place in vic is called pick a part, go there and pull the axel out from a ED and u will know how to do yours when u go to do it and u dont brake your car and u learn somthing,
do i get the beer now
#14 | |||
Back to Le Frenchy
It's easy to do, I have an EL diff here for $50 if you want it. Just so happens that I thought I had a bent axle in it (passenger side) so I got it all checked out and cleaned up good as new with a new bearing, it's done about 5,000k since that was done. Let me know. Also you will need a big phillips head screw driver as the screw tends to be a right ***** to get undone if it hasn't been taken out for a long time.
#15 | ||
V8 Ute V8 Boat
for the screw driver i put mine on a grinder to fit probely so i could get it undone also rp7 helps if you spray it and leave it for a few mins
#16 | ||
What Wheelspin?
ok guys. i'll have a go myself. hopefully i havent bent anything other than the axel.
REDXR8220, i mite need to buy that diff from ya. ill pm ya if i do. thanks guys
#17 | ||
V8 Ute V8 Boat
if you fly me to you and home again i will do it for you and colect my beer,
#18 | |||
What's green is gold
EF XR8 - Koni's - Cam and Headwork -3.9s - Ex VIC TMU - 1982 Nissan Patrol - 460 ci Big Block soon - Semi Gloss Black - Dark Tint - 4x 6" Infinity Kappa Perfect Splits - 5" Kappa 2 ways - Kappa 6x9's - 2x12" Kappa perfect subs - 2x4 Channel and 2x Mono Kappa amps- |
#19 | ||
need more boost
When I bent my RH axle, I had quite alot of trouble getting it out (this is pre-spool btw) once everything was undone, and had to use a slide-hammer to get the bugger out. It took alot of effort, along with the bearing.
'94 ED Falcon GLi Suspended by: kings, koni, pedders Rolls on: 17" AJR Director's Stops due to: bendix, DBA Shifter connected to: T5 manual Power from: ??? Interior: velour and woodgrain Cost: stuff all :P |
#20 | ||
- BOOYEH -
Clear your inbox John!!!
1993 EBII Fairmont Turbo T04e 7 psi
#21 | ||
FirstOnRaceDay
I bent the same one I paid $40 bucks for One on the EA...
MY BRAND NEW RIDE NC Fairlane GHIA Series II I6. Mods. 2.5" cat back Clarion HU Soundstream speakers amp and subs Lowered DL LTD rims ![]() For the moment... ![]() |
#22 | ||
I build your wish list...
Soooooooo many things going wrong with your car John ..
Burn it ---- hahahahaha narr doing a axle is easy .. take you all of 90min if your slow...... |
#23 | ||
What Wheelspin?
hahaha, i swear i should just up my insurance cover and burn it, lol
#24 | ||
took me and my old man, both without any experience 3 hours to change the diff, arms, bushes, discs, basically everything on the rear end except springs and shocks. all for a cost of $310. incl diff. god i love cost price.
good luck with it all |
