Blue Power Racing Developments The home of Blue Power. Website Link |
02-11-2009, 07:59 PM | #1 | ||
HO INTERCEPTOR
Just wanted to post up how bloody fantastic the Main Lube gear oil is that I had done last week. That noisy tremac 6 speed is all but quiet as a mouse. No gear noise at idle and through the gears especially 4th all but gone. For the record I have a Rip shifter with the bushes removed for a solid mounting that gives firmer more direct shifting, which also make things louder (and faster) than the standard set up. now it is FAR quieter than standard and soooooooo smooth. Bit more pricey that ya normal oil change but well worth the extra $$ spent. Thanks a ton Theo for the recomendation and I pass it on to ANYONE with a manual who is thinking about an oil change. There is more to it than your regular oil change and back up for down the track should you require it but I'll let the boys at BPR tell you about that.
Cheers Glenn
Lightning Strike, BF, 6 Speed Manual, XR8 Ute. Stuff to make it GO by BluePower Racing Developments ....Speed is a byproduct! Body and Visual by HO My Business GutterGuardGuyAluminium Guttermesh Supply & Installation. OrsmFordCruisers R.I.P Wayne Draper
02-11-2009, 10:42 PM | #2 | ||
Force Fed Fords
Is that the same sort of oil you mentioned Liberachi using whilst at Theo's last night?
2021 Focus ST-3 Mountune Enhanced |
03-11-2009, 12:57 PM | #3 | |||
HO INTERCEPTOR
Cheers Glenn
03-11-2009, 03:16 PM | #4 | ||
Location: Working, chasing after my daughter and working
Good stuff that Mainlube, amazing how much difference it makes.
04-11-2009, 07:11 PM | #5 | ||
BOSS 5.4L Enthusiast
Might get this done next time mine is at BPR to quieten down the old 5 Speed in her old age :P
