Old 16-12-2023, 08:57 PM   #1
car10002
Default brake fluid question
Hi
Have question, what would cause a bit of brake fluid to come out the container on a new master cyl between the container and metal part on master cyl at the o rings or the lid in the ba.
Opened lid on container and it hasn’t lost any and level hasn’t done down.
Had a whole new master cylinder fitted a few weeks ago and everything checked out good.
It doesn’t do it all time, just some.
Is there any chance that it might just be spillage and just a bit full.
Fluid is at max
brakes still work ok
Thanks
car10002 is offline   Reply With Quote Multi-Quote with this Post
Old 16-12-2023, 09:22 PM   #2
Default Re: brake fluid question
Perhaps the lid of the master cylinder was initially not put on correctly or all the way at the rear. I'd just continue to monitor it for a few weeks.
Old 16-12-2023, 09:35 PM   #3
car10002
Would it be worth soaking some fluid up and have it at max/just below
Old 16-12-2023, 09:48 PM   #4
No; that risks contaminating the fluid. Syringing or sucking some out with clean eye dropper, clean syringe or clean basting bulb suction tool would a better idea.
Old 16-12-2023, 10:02 PM   #5
car10002
Ok what about the same thing that is used for sucking battery acid but buy a new one so it’s clean or use a new syringe
The canister is looking to be so full and wondering wether that might be all that’s wrong as it doesn’t seem to have lost much if any and brakes still seem to work good
The front of lid was easier than the back to unclip, would that be one reason
Old 18-12-2023, 11:56 AM   #6
rare ss
rare ss's Avatar
Did the brake pads get replaced after the master cylinder got changed out?
FGII FPV F6 #406
BFII FPV F6 Typhoon R Spec #118
VK HDT Group A/Group 3 #3249
rare ss is offline   Reply With Quote Multi-Quote with this Post
