02-05-2007, 11:09 AM | #61 | |||
They keep pumping out bigger and bigger engines when the world wants smaller more efficient engines that still make good power. This is why Toyota is now number 1 (among other factors), because GM and Ford are considered dinosaurs - it needs to change if they are going to stay in business.
1966 Ford Mustang coupe. 347 stroker, PA reverse manual C4, TCE high stall converter, B&M Pro Ratchet, Edelbrock alum heads, Edelbrock intake manifold, MSD ignition, Holley Street HP 750 CFM carb, gilmer drive, wrapped Hooker Super Comp Headers, dual 3" straight through exhaust, Bilstein shocks, custom springs, full poly suspension, American Racing rims, Open Tracker roller spring saddles and shelby drop. Still to go - Holley Sniper EFI with integrated fuel cell. |
02-05-2007, 11:26 AM | #62 | |||
LPG > You
Also Toyota's being number one has nothing to do with performance car engines. If it did, they'd be at the bottom. They haven't got any.
LPG Lovers Association President & Member #1. : |
02-05-2007, 12:51 PM | #63 | |||
405rwhp LS1, FG XR6T Ute manual, VE series 2 Omega LPG. |
02-05-2007, 01:45 PM | #64 | |||
Before Chrysler re-introduced the 426 Hemi crate-motor in the Nineties(?), a few companies were selling Hemi-head conversions for RB-block Mopars (440s). Try the same conversion to SOHC on a 427 side-oiler and see how simple that is? |
02-05-2007, 01:52 PM | #65 | |||
02-05-2007, 02:10 PM | #66 | |||
Toyota is number 1 due to their percieved (wether valid or not - this is not the thread to debate this) reliability, fuel efficiency, resale ect. Maybe GM/Ford need to concentrate on this more than worrying about who has the biggest 28 litre V8.
02-05-2007, 02:25 PM | #67 | ||
1999 Ford Fairmont Ghia
I meant the 427 SOHC is simpler as it is much easier to have a hemispherical head in a OHC motor than in an OHV motor also when you start to use VCT it is obviously easier to have different valve timing for intake and exaust.
I think its clear that Ford will stick with the modular design and hopefully improve power output. Does anyone know if there are any plans to fit VCT to the motors and what would be the likely gains?? When Ford fitted VCT to the SOHC intech power jumped from 157 to 172 kw and when they fiited DIVCT to the DOHC Barra power jumped from 182 to 190kw. Im sure we can easily get an extra 20-30 kilowatts out of the BOSS with VCT and possibly more through the fitment of forged parts so we can run it at higher rpm. Or Ford could go in a different direction and fit a alloy block and make an efficient SOHC head like Mercedes does. DJR make 320kw out of a few mods does anyone know if the DJR320 is ADR legal? The point is that the Falcon is stuck with a les than ideal motor but Im sure there is still a few more tricks up the BOSS's sleeve to keep it competitive. |
02-05-2007, 03:40 PM | #68 | |||
I seem to remember the Chrysler 215 245 265 HEMIs having overhead valves but no over head cam as these sixes were also pushrod design. My mate had a Centurion with a 245 HEMI and it was damn street quick for what it was back then. The 265 HEMI with the 3x2 barrel Webers was a formidable weapon in its day, but sucked juice like there was no tomorrow after all, they didn’t call it "the HEMI six pack" for nothing! (joke) It's not just the V8 that uses the hemispherical head nor do you need over head cams to make use of this design. I think some people just waste a lot of time arguing about nothing. |
02-05-2007, 03:54 PM | #69 | |||
5.4L 3V V8
24 valve has VCT, 32 valve does not. |
02-05-2007, 05:20 PM | #70 | |||
Professional Mouse Jockey
I didn't have a clue about the quad cam engine.
Isuzu MUX for towing horses - currently no Fords in the stable Time flies like an arrow; fruit flies like a banana. Groucho Marx
02-05-2007, 05:26 PM | #71 | |||
5.4L 3V V8
Yep,its stamp on the engine cover, and your engine isnt quad cam, only the boss motors are double over head cam,our 3V's are single over head cams. |
02-05-2007, 05:37 PM | #72 | |||
02-05-2007, 05:50 PM | #73 | ||
5.4L 3V V8
Brilliant engine mate, id drive a modded 3V any day over a modded 4V, they are tough as, i own craig@ace's old 3V, you should give him a call, once you unleash a 3V's potential they are unbelievable to drive
02-05-2007, 06:22 PM | #74 | ||
Im a big fan of Fairmont Ghias and currently own two an XE Fairmont Ghia and an AU Fairmont Ghia both of them sixes (as well as a Ford Laser Ghia) and am very interested in the BF Fairmont Ghia SOHC V8 version.
Does anyone here own one and would be able to tell me how they go? I've heard rumours that they are actually a better motor than the BOSS and respond well to modifications. Is their a significant weight and handling difference compared to the XR8 and has anyone had theirs on the track or strip? |
02-05-2007, 06:33 PM | #75 | |||
5.4L 3V V8
I have never driven a stocky, but i own craig@ace's old car and once these cars have a good cold air intake(bluepower) good exhaust(di fillipo) and a good custom tune they are unbelievable, mine has around 235rwkw's and when craig was racing it ran a best time of 12.7 at 109mph, and they sound so much tougher than the boss motor, i wouldnt hesitate to buy and mod one mate, you wont regrete it, check out aussie car enhancements on the forums they are a sponsor,craig is the bloke to talk to in regards to these motors.check out his website and pics of my car at aussiecar.com. |
02-05-2007, 06:45 PM | #76 | |||
Its actually the unions who have crippled Ford and GM. Both of whom pay more out per year to ex-employees than to current ones. Decades ago the unions forced Ford and GM to offer employees life time medical care (and even to family members) Since Toyota only recently started manufacturing heavily in the US and are not restricted by those union laws, they can make a shitload more profit than Ford and Gm could hope to.
02-05-2007, 06:46 PM | #77 | |||
02-05-2007, 07:07 PM | #78 | |||
5.4L 3V V8
Have you ever driven a modded 3V? I like the 4V's aswell but i love the bottom end torque of the 3V's, slower you say?its hard to argue with 12 second times :jab: You own a GT right? what times has it run? faster than 12.7 i hope |
02-05-2007, 07:13 PM | #79 | ||
Falcon obsessed
I have learnt so much in this thread,cheers everyone LOL
02-05-2007, 07:42 PM | #80 | |||
but yeh i have driven a stock and a mildly modded 3v(although not as modded as yours) no i havent run a 12.7 but only a couple of tenths off that.. without slicks, without stall, with stock wheels and tyres and with standard exhaust, can you drive your car to the track like that and do those times..N..O ...but im not comparing my 4v to your 3v....if 3v's arent slower craigs xr8 went more than half a second quicker than the his 3v... 3v's are a good torquey motor but sorry to say inferior to the 4Vboss motors. They are slower AND less powerful full stop : |
02-05-2007, 07:53 PM | #81 | ||
I dont think the 3v would be slower than the 4v they are the same block just different heads and mercedes benz swears by the 3v V8's.
This is just my opinion but I think the Ghias look better than the XR6/8 interior wise. I drive a BF XR6 Turbo at work with the Six speed auto and I still prefer driving my AU I reckon the chrome the woodgrain and all those luxurious little touches make all the difference I reckon the B series XRs just look too plasticky. And another thing is it just me or does any else feel that for a car with 245kw the xr6 turbo feels slow. The car that I've driven that actually felt the fastest was my dads 1968 Fairmont with a 302 Windsor which I think only had 250hp. I guess what some might say "lack of refinement" I call part of the driving experience. Are the B series V8's this quiet. Has fitting an aftermarket exaust become a necessity? |
02-05-2007, 07:56 PM | #82 | |||
02-05-2007, 08:04 PM | #83 | |||
02-05-2007, 08:31 PM | #84 | ||
Peter Car
[QUOTE=sleekism]I dont think the 3v would be slower than the 4v they are the same block just different heads and mercedes benz swears by the 3v V8's.
[QUOTE] Is that why Mercedes has started ditching the 3 valve V8's for the new 4 valve versions? |
02-05-2007, 08:38 PM | #85 | ||
On a completely different topic has anyone else read the latest issue of street fords?
Apparently there was meant to be a super roo decal on the 40th anniversary gt but FPV is holding it over for another vehicle. Also Wayne Draper the designer of XD, XE, Laser and EA is quoted as saying "mate they've got a GTHO just sitting there, why they havent released it, I dont know? |
02-05-2007, 08:57 PM | #86 | |||
And so does every person wanting more power and getting it from a stock Holden :
I got Whoosha to do it e |
03-05-2007, 09:28 AM | #87 | |||
5.4L 3V V8
03-05-2007, 01:59 PM | #88 | |||
stop kidding yourself! i havent seen any record holding 3V's come close to record holding 4v's arent there are unopened boss's even doing 11's.... and if you havent seen any xr8's run consistent 12's you should open you eyes cos there are a lot more than there are 3V's. boss motors are doey down low in stock form i agree but when modded that dissapears..and even in stock form they still ***** on stock 3V's. could your 3V run 12's in pure street trim and tyres...uh uh. which might i add there are boss's doing. as well as that 3V's are in a base xt falcon which is lighter than an xr.... but they are still slower. If 3V's werent inferior wouldn ford have put them in the Xr's and fpv's instead after millions of dollars put into research and development. |
03-05-2007, 03:57 PM | #89 | |||
5.4L 3V V8
My point is i like 3V's more, you seem to have issue's with that? probly because like many GT owners youv spent the big dollars on a badge and a car that is no better than a modded V8 XT, iv have never said the 3V is superior you have just canned them and said they are inferior even though and you have never driven a modded one? In my opinion the 3V and 4V's are fairly sad in stock form, you say there are alot more fast 4V's out there,im shocked.... look at the aftermarket development that has gone into the boss motor by various company's compared to the 3V and they still keep up, if the same amount of companys had invested as much time into the 3V it would be a differant story, the boss motor is more commercialy viable thats why alot more development has gone into it, get over yourself and realise that everyone has differant tastes.Flat 13 in street trim by the way |
03-05-2007, 04:46 PM | #90 | ||
This is like the debate that goes on when insecure GS owners try to say their GS's are "nearly" GT's...
335 S/C GT: The new KING of Australian made performance cars.. |
