Old 21-02-2008, 07:36 PM   #31
ratter
ratter's Avatar
you have dirty injectors
Pit Lane Performance
Old 21-02-2008, 07:39 PM   #32
ubuxkl
ubuxkl's Avatar
Originally Posted by Uncle_Ken
Are you using a high flow air filter?
UK
No I'm not UK.
Originally Posted by INJECTED_250
manifold gaskets tend to crack and split.. this causes a leak at idle giving a rough idle... Use some CRC / water hell anything and spray it over the manifold where its bolted to the head.. if u hear a loud hissing or it runs differntly then thats ya prob.. i
Thanks Injected_250. I'll give it a try - or get my mechanic to. I'm searching for things for them to try I guess.
Cheers,
Jeff
http://www.aufalcon.com/ubuxkl
ubuxkl is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2008, 07:42 PM   #33
ubuxkl
ubuxkl's Avatar
They gave them a "purge" last August during a service. You think it would be that Ratter?
At the service they did in January, they hooked up the computer and it didn't return any faults.
What a pain. The damn thing drives beautifully but I hate having things like this : :
Cheers,
Jeff
Old 21-02-2008, 07:43 PM   #34
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Originally Posted by ubuxkl
No I'm not UK.
OK thats me out. I found that a stock filter gives a better idea at times
UK
Old 21-02-2008, 09:42 PM   #35
ratter
ratter's Avatar
If the car is ok on gas, the only difference is the fuel system, so the problem points to petrol, as it is only an idle problem I would say it is injectors as fuel pump or supply problems get worse as revs increase when the demand for fuel flow is greater.
Dirty or leaking injectors do not show up any codes.
Old 21-02-2008, 10:52 PM   #36
mattp
mattp's Avatar
AU's tend to get loosening of the inlet manifold bolts, which gives the same sort of symptoms as a buggered inlet gasket, so it's worth getting a size 10 spanner and giving the ones you can get to a good tightening.
mattp is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2008, 10:44 AM   #37
ratter
ratter's Avatar
and that problem would show on both fuels
Old 22-02-2008, 04:57 PM   #38
TwistedEL
TwistedEL's Avatar
Mine starting doing this when I got an aftermarket exhaust. Haven't been able to work it out yet. I've replaced the coil pack, oxy sensor, plugs and leads so I know they aren't involved.
Old 23-11-2020, 02:09 PM   #39
nitro
Nitro
Default Re: I give up!! Au missing at idle drives ok.
Originally Posted by bellagirl67 View Post
Well got my dad to clean the throttle body but it made no difference. Then he put the idles up so it idles in park at 750-800rpm. Now in gear with my foot on the brake it idles at 650rpms. Now it doesnt stall when I come to a stop at lights etc. Hooray!! Still has a slight miss intermittently when idling in gear but I suppose I will have to live with that. At least it doesnt stall now!!
I was about to say adjust the throttle body stop screw like I did and for me it stopped the rev hang when stopping and all the hesitation disappeared just from a little turn of a screw....after all the new components I replaced ISC TPS coil packs leads plugs hahaha for me it was just a 1/4 turn of the stop screw and she idles and drives beautifully now..
Anyway going to go and check myself into a mental institution now my brain is fried.
nitro is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2020, 07:27 PM   #40
That's not really a fix it is just masking the issue and will cause increased fuel consumption and accelerated engine wear (washed bored from over-fueling at idle). It is very likely, as others have said, a vacuum leak in the inlet manifold gasket. Check for vacuum leaks particularly at the inlet manifold the bottom of number 1 and 6 where the inlet manifold mates with the head both when the engine is hot and cold. Use a length of windscreen washer sized hose with one end in the ear to listen for the telltale sucking noise of a vacuum leak while poking around under the manifold at idle. Note the pre fuel injection trick of using engine start sprays etc will often not work to find these leaks as the ECU rapidly adjust for the change in air in the mixture and it's hard to pick up any change in the engine noise or rpms. Just tightening the manifold fasteners usually won't fix it as a small piece of the gasket at the lower part of the inlet port usually burns through once the nuts have become loose.
Old 21-01-2024, 07:22 AM   #41
david lee
my au xr6 hesitates at idle and runs perfect i squirted soapy water around the rear of engine between the gap in the inlet manifold and it instantly ran on 5 cyclinders. whats going on ?
david lee is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2024, 10:18 AM   #42
Blue Dog
Looks like you've found a vacuum leak.
If you weren't looking for a vacuum leak.
Why would you be squirting soapy water on the engine?
What did you expect to happen?
Blue Dog is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2024, 09:45 PM   #43
david lee
someone mentioned inlet manifold leak and said to use soapy water in a squirt bottle im hoping its an leaking injector.at least i can tell the mech what i did when he comes to pick the car up once before ive degreased the engine and hosed it off with no problems
Old 22-01-2024, 06:51 AM   #44
PG2
#neuteredlyfe
PG2's Avatar
Why would you be hoping it is a leaking injector when everything points to a broken inlet manifold gasket?
An inlet manifold gasket is a lot cheaper and easier to fix being a $25 job and takes about an hour to replace if you don't know what you are doing.
PG2 is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2024, 10:28 AM   #45
david lee
thanks. thats great news i thought it was the other way around i drove it today and it was good. no problem but i know it will re surface iread that the gasket is a common fault
