12-03-2010, 12:05 PM | #31 | |||
Pity the fool
Fords I own or have owned: 1970 XW Falcon GT replica | 1970 XW Falcon | 1971 XY Fairmont | 1973 ZG Fairlane | 1986 XF Falcon panel van | 1987 XFII Falcon S-Pack | 1988 XF Falcon GLS ute | 1993 EBII Fairmont V8 | 1996 XG Falcon ute | 2000 AU Falcon wagon | 2004 BA Falcon XT | 2012 SZ Territory Titanium AWD Proud to buy Australian and support Ford Australia through thick and thin |
12-03-2010, 12:23 PM | #32 | |||
So what's a VR6 engine? It's a very, very narrow angled V6 engine. On a normal V6 you have two separate cylinder heads. Now imagine a normal "V" angle is 90 degrees. What happens when you start reducing this angle? At 45 degree, say, you'd still have two separate cylinder heads but if you reduce the angle further the cylinder heads will eventually touch. So VW basically just made a very, very narrow V6 engine that had both its cylinder heads connected into one. Hope that made sense... Otherwise: VR6 Engine and W12 Engines |
12-03-2010, 12:25 PM | #33 | ||
Broken eBay Starter Motor
The conrods come in at slightly shallower angles for the lower banks of cylinders and IIRC the two cylinders that are paired together fire at different points in the firing cycle. It's a neat piece of engineering to get it to run as well as they have, but it's still bound to be less smooth than the Barra, or a Jag V12, or etc.
I don't know what the firing order is though. I'd hate to have to put a new dizzy in, as everything would be in Italian. If it came from VW in German, I might be safe. |
12-03-2010, 06:55 PM | #34 | |||
Ich bin ein auslander
Its german for a start, and as if it is going to have a dizzy.
Growing old is compulsory, growing up is optional! |
12-03-2010, 07:19 PM | #35 | ||
12-03-2010, 07:29 PM | #36 | |||
Figure of speech. |
12-03-2010, 07:32 PM | #37 | ||
Ford Fanatic
Probably a bit late in the thread for this, but anyway.
The car that Duston Hoffman was rabbiting on about in "rainman" was a straight 8 1949 Buick Roadmaster. Straight 8. Fireball 8.
Everyone is entitled to my Opinion 2007 Territory TX SY RWD Ego |
12-03-2010, 08:41 PM | #38 | ||
My Grandfather used to work on them years ago and were common for breaking cranks as they were so long.
12-03-2010, 08:44 PM | #39 | ||
Thailand Specials
With the breaking crank issues, couldn't you just make them out of a stronger material? I'd imagine it'd be a similar issue the 20B rotory engine has, they have problems with snapping their eccentric shaft when you start hitting certain power/torque figures which can be resolved by spending up on better quality stuff.
12-03-2010, 09:04 PM | #40 | |||
XP Coupe
12-03-2010, 09:14 PM | #41 | |||
Pity the fool
12-03-2010, 09:44 PM | #42 | |||
I-6, V12 and horizontally opposed engines are the best balanced engines. |
13-03-2010, 06:36 AM | #43 | |||
thats not entierly true, braking cranks isnt a real issue this can be adressed with adding extra main bearings but the reason was simply real estate, to get cubic inches you need bore size X stroke so to get the size engine you eaither had a really long bonnet or went wit ha V configuration theres still plenty of healthy straight 8's arround in the nostalgia seen pitty classics.com are such tools about posting images on other forums perhaps if they did more people would see the image and follow it through to find more and they would get more traffic :
Pariahs C.C. What could possibly go wrong I post images with postimg.cc (so I don’t forget) |
13-03-2010, 03:19 PM | #44 | |||
[BU66OS]
FG XR6 Turbo Nitro BA XR8 Manual
15-03-2010, 11:46 AM | #45 | |||
Lucky, lucky bastard!
2015 Mondeo Trend 2.0T Diesel, Deep Impact Blue 2012 FPV GT-P 6spd Auto, Lightning Strike |
15-03-2010, 12:13 PM | #46 | |||
as for straight 8's, it helps when you have a bonnet longer than half the car's length, like a Cord or Dusenburg. :
My ride: 2007 Falcon Ute BF XR8 Orange, MTO. |
15-03-2010, 06:50 PM | #47 | ||
who cares about a straight 8, how bout barra v12 with 2 turbos
15-03-2010, 07:11 PM | #48 | |||
and no counter weights required on the crank... Sounds like two four cylinders, check out the Ferrari:...LINK |
15-03-2010, 07:12 PM | #49 | ||||
Nutty Professor
Should have about 700kw (960hp) when done but its a loooong way off.
15-03-2010, 07:16 PM | #50 | |||
Current Blueprint 03 xr8 5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives 256rwkw BA manual Typhoon Fully optioned, 340rwkw@16psi (thanks Bluepower)! The old ride.... AU Fairmont, cammed beast, R.I.P you made my p plate years bearable! 150.8rwkw courtesy BPR |
15-03-2010, 09:40 PM | #51 | |||
Nutty Professor
Nah mate serious but suffering from a severe lack of funds. I need to spend more time at work and less time in the shed.
15-03-2010, 10:21 PM | #52 | |||
16-03-2010, 06:06 AM | #53 | ||
a mate of mine owns Pauls Old Skool Only, he's currently doign a hart transplant on an old Buick
theres plenty more here if you are interested http://www.facebook.com/?ref=home#!/album.php?aid=197364&id=334269315675 http://oldskoolonly.com/default1.htm%20index1.htm
16-03-2010, 11:54 AM | #54 | |||
Rusticating
Territory SYII RWD, BFII RTV tray |
16-03-2010, 11:58 AM | #55 | |||
Rusticating
