#31 | |||
i'm baaaack....
try mixing your own fuel. that way you can make, say 500ml at a time to get the mixture how you want, careful not to go too high though because it will start to detonate. we used to mix up 80% nitro and 20% oil for pylon racing. engines never used to last but god damn did they rev. :evil3: ever heard a .46AX spinning at 20,000rpm? need to do some port work to them, but god damn that motor went, needed to do the liner after 15 flights though... still worth it. |
#32 | |||
Is Ford, Is Good
ef futura with fairmont mods. license in less than 2weeks. |
#33 | |||
#34 | |||
Is Ford, Is Good
#35 | |||
i'm baaaack....
#36 | |||
Is Ford, Is Good
#37 | ||
must say i have a few RC's laying around.
Traxxas S-maxx - modded, 4WD, 2 speed, Fantom FR.18 (43000RPM), Fantom Works Tuned pipe etc etc Losi LST 2 - Stock Axial Crawler - Losi Claws, Rooster etc (only got to get me on the rocks while i make...... Custom Clod Crawler - 2 years build so far. incorporating some of the latest tech (at the time), just chasing beadlocks and it should be complete. Dominator Extreme - FULL alloy - sold Twister CP 3D - Kitted - sold. cant fly and value my life. CEN CT4S - fast but crap so it was sacrificed into a wall - R.I.Pieces probably a couple of others over the years i cant think of at the moment. |
#38 | ||
How'd ya make the sprinters mate?
#39 | |||
#40 | |||
![]() ![]() As far as the speedcar goes, there is no class for them. As far as I'm aware this is the first speedcar of this scale, so I'm making my own rules!!!! I'm using measurements from a car in Perth so it will be as close to 100% exact, engine will be a 50cc water cooled Polini replica (read cheaper Chinese copy ![]() |
#41 | ||
Is Ford, Is Good
sounds good, are you going to take some vids when its all running??
#42 | ||
Yeah - was at a BMX track (Park Orchard in Melbourne). A mob of us used to go there every weekend for a bit of bashing and stuff. Theres an off-road track now in sunshine that races (1/8 buggies, 1/8 truggies and 1/8 monster trucks) once a month. I was doing sunshine, bendigo and shepparton but it all got a bit too time consuming so i gave it up during winter last year.
I've seen websites devoted to 1/4 scale sprint cars - those things look amazing!
BLUFGX | 2015 Kinetic FGX XR8 KPM Oil Breathers, Koya SF06 20x9/20x10s, Michel Pilot Sport 4S 245/275, G6E Chrome Front Grille/Foglights/Window Trim, Disabled Bi-Modal - More to come! |
#43 | ||||
1/5 scale cars run at Helles Park in Moorebank, but I'm not sure which Sunday of the month it is. |
#44 | |||
![]() Join Date: Dec 2004
I've got the Truck version (TNX 5.2, .32 engine). After 3 weeks, the crank pin sheared off and the piston and con rod went through the block. Bought a second, brand new motor off ebay to replace, and last tuesday the clutch bell bearings collapsed, causing the pinion to eat up the spur gear (Both steel mind you), destroyimg the whole clutch and flywheel assembly along the way, and snapping the end of the crank shaft off. Two motors in 2 months, each worth $349. Not happy!!! I just bought a crank shaft ($117) which should arrive next Tuesday, and new clutch, flywheel, and spur assemblies. Hopefully I can rebuild the thing to run again. All's good when they're running, I've estimated mine to be doing between 70-80 km/h, and it sounds awesome. Can't wait till I get it up and running again. I'll post up some pics of the car tomorrow and take some pics of the aftermath of tuesday's bearing collapse. I'm running 25% nitro, premixed fuel, called Massive mods HB444, which I've been very happy with. Would like to hear what others are running |
#45 | ||
Is Ford, Is Good
Premixed called cool power 15% nitro going to 20% on next bottle :evil3: .
#46 | ||
Cowboy
My housemate has a Traxxax Revo, the thing can't be killed. First time I drove it went end for end into mates Hilux at about 50km, no damage at all, just bounced off and sat on it's roof idling angrily. Man does it go, going to do some videos soon of it in a drag with my Tornado and his Pursuit.
I wouldn't mind one of the Gigas with the twin engines.
1927 Pontiac tourer 1928 Pontiac tourer 1929 Pontiac sedan 1930 Pontiac Landaulet 1932 Pontiac V8 sedan 1935 Pontiac sedan 1937 Pontiac 8 sedan 1948 Pontiac silver streak 1949 Ford F3 pickup 1953 Pontiac Chieftain 1955 Austin Champ 1957 Dodge Power Wagon 1967 Jeep Gladiator 1975 TD Cortina 1978 F100 4x4 2006 GU Patrol ute |
#47 | ||
I've got an Losi-LST2 that I bash around.
Heres a short vid of when I was bashing around and running it in -> http://au.youtube.com/watch?v=JSgHkNYODV0
74 XB Fairmont (street car) 11.07@123.02mph. 08 LV Ford Focus XR5 (daily). Tuned by Hallam Performance |
#48 | ||
How much would that ute set you back? I wouldn't mind one of them for christmas
#49 | ||
Barra Turbo > V8
OMFG i cant beleive the sizes of some of these cars. Ive had to but sold them both, id love to get another one though they are so much fun
-2011 XR6 Turbo Ute -2022 Hyundai Tucson Highlander Diesel N Line |
#50 | |||
Is Ford, Is Good
![]() .28ci Dirty cause i wiped it with a rag as i had alotttt of fuel in there because it was siezed and i had to put alot of fuel to get it to turn over as it hadnt been run for about 4 months and i didnt even turn it over.. ![]() ![]()
#51 | |||
Is Ford, Is Good
cheersss
#52 | ||
I've always read about the engines siezing if left unused. One thing I don't understand? I had a Novarossi 12R .12cc engine that wasn't run since 1999. I fired it up in 2003 without an issue. I also had and still have a Novarossi 15R .15cc that hadn't been fired since 1999. Fired it up in 2007 without a problem. Both engines were in car I'd raced since 1996. My LST2 hasn't been fired in a few months now but it'll be fine. I'm sure off it.
My question? Do you 100% run them out of fuel before storing them? If not? I believe the issue isn't as prominent in engines that have been run 100% dry of their fuel.
#53 | |||
Is Ford, Is Good
#54 | ||
Hmm. I'm not sure whats going on there then.
#55 | |||
Is Ford, Is Good
#56 | ||||
i'm baaaack....
when i store a motor i NEVER run it dry, why do you ask? BECAUSE THE OIL IS IN THE DAMN FUEL!!! so say your turning a motor over at... 2000rpm, when it runs out of fuel it runs out of oil too. extreme wear on every moving compent on the inside. (end journal(s), main journals, rings/piston, liner etc) now what i do with mine is, i run them close to empty, then leave take the head off, and heat the engine up in the oven to 50*c (thus evaporating all methanol and nitro). i then poor oil over the piston, then i put the head back on, and put oil down the carby and turn the engine over by hand until i can feel the oil working its way in. Last edited by XCSEDAN; 28-01-2008 at 12:35 AM. |
#57 | |||
Is Ford, Is Good
#58 | |||
i'm baaaack....
this engine was STRICTLY for pylon only. and like i said needed a rebuild every 15 flights MAX. was a really touchy engine, was a bit of fun to screw round with though. next time we will do an ervine. i've just pulled up the stock AX page for you to look at ;) http://www.osengines.com/engines/osmg0547.html the website says they do more then 14000rpm but geez... can't see it happening unless you were running a 9x5 or similar. |
#59 | |||
Is Ford, Is Good
#60 | |||
If you know of any websites with the speedway RC's (especially ones for sale), let me know Thanks. Rob. |
