21-08-2006, 04:34 PM | #1 | ||
Tuned @ Pitlane Frankston
Hi guys
Just wondering if anyone has done this? I know about the Sump cutting required, but wondering what other mods need to be done for the Serpentine, etc? Do all of the EF accessories bolt upto the AU engine ok? Regards |
21-08-2006, 04:40 PM | #2 | ||
XRSVO
apart from sump everything else should be pretty straight forward
pretty much all accessories are interchangable ,the aircon may need work and check ignition setup on both is same design ,trigger ,sensors etc just use a AU block and head with your ef gear |
21-08-2006, 04:41 PM | #3 | ||
Last warning
bell housing doesn't bolt up 100%, but a few ppl just leave it anyway.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
21-08-2006, 04:58 PM | #4 | |||
do you know the best way to modify the sump to fit? I know you have to cut and weld, but is there any tutorial on exact measurements? When you say check ignition, do you mean coil pack, etc? It's an EF XR6, so should i put the XR6 head into the AU block, or leave the AU head on there? |
21-08-2006, 05:11 PM | #5 | |||||
XRSVO
21-08-2006, 05:21 PM | #6 | ||
Insurance ? :P
21-08-2006, 05:34 PM | #7 | ||
Insurance for what? Why would insurance matter?
21-08-2006, 06:54 PM | #8 | ||
FPV GT Owner!!!
You will need an AU alternator. And an AU drive Belt.
I modded my k-frame and its still going strong 5 months later. I found you will also need to run premium as all i got was pinging when running NA with just the AU motor and an exhaust. IMO, it is better to mod the k frame as the AU sump is designed to transfer strength in the bottom end.
Cars: - Ford Ranger Wildtrak - XY GT Replica - XB Coupe Project |
21-08-2006, 09:26 PM | #9 | ||
Aspiring mr efxr
and if u hate petrol co$t$ just so u know AU heads [I]hate[I] gas
EF Wagon Project: Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA |
21-08-2006, 11:29 PM | #10 | ||||
Burnin Rubber
2001 AUII Forte (LPG) K&N Air Filter Tickford Air Intake ***Coming Soon: Clear Side Repeaters*** Quote:
21-08-2006, 11:47 PM | #11 | |||
AU Taxi's run methanol because LPG wrecks the head.. : |
