#2071 | ||
Hi, are SX/SY Territory front diff bushes still available including the bush on the drivers side?
#2072 | |||
SX SY Front Cross member.pdf SX SY Front Drive Shaft Housing.png |
#2073 | ||
Have a look at the images below, in the first do you mean bushes labelled 3B177 and 3A443 in the second?
sx sy front cross member .png |
#2074 | |||
Regular...with metamusal
![]() Join Date: Oct 2009
![]() 5R29 17D927 AA and the other side is a 'bit' hard to read .. so i'm guessing- ![]() what i believe is - 5R29 17D926 AA these numbers are for the black/white eggcrate with the shaped top. so i have no idea what year they correlate too. |
#2075 | |||
#2076 | ||
Hi Gtlegend, are FGX XR headlights obsolete or is there new stock coming? Showing sold out on Jefferson ford.
#2077 | ||
#2078 | |||
The 5 in 5R29 means 2005 model year designation. |
#2079 | ||
#2080 | |||
So further more, from those engineering part numbers you mention, they cross reference to: 5R29 17D927 AA = BAF 17D927 A 5R29 17D926 AA = BAF 17D926 A |
#2081 | ||
So the 3B177 has part number SX4B424A, obsolete but are some around:
https://www.ebay.com.au/itm/32596601...Bk9SR_SDgJydZA The 3A443 has part number SX3A443A, obsolete and nothing I can find at this point. |
#2082 | |||
#2083 | ||
Hi Legend
![]() ![]() ![]() it's BA 15W204 AA - has ford BA cornering kit on the packet but i have NO idea what is meant. i'm presuming some sort of wiring loom?. Thanks ![]() |
#2084 | ||
BA 15W204 AA is the wiring that goes from the cornering lamp to the loom on Fairlane/LTD.
#2085 | ||
ok?. i don't remember any when i stripped the BA Fairylane RHS loom i have here, just the wiring loom going straight to the cornering lamp socket plug. i'm intrigued now lol.
#2086 | ||||
understand your reply now. have seen what we are talking about in the flesh. Thanks ![]() |
#2087 | ||
[QUOTE=mad2;6910269]ok. what is BAF13411A ?.
BAF13411A is "Position Lamp" bulb socket |
#2088 | ||
#2089 | ||
#2090 | ||
Air filter to suit the Miami, I believe it's AR3Z9601A.
Is the going rate around $150? And is the part in short supply? It had only limit use in the US, so I wonder if it will become NLA.
#2091 | ||
Part number is correct. price more like around $180. Plenty of supply from what I can tell..
#2092 | ||
Just wondering if its possible to buy any FG Falcon Airbag to replace my current one.
Airbag hasn't blown but the Horn Pad Cover has a split down the middle and wanting to replace it. Is it a direct insert onto the steering wheel or do i need to do more? |
#2093 | |||
They are held in by 4 bolts at the rear of the steering wheel. You must ensure you depower the system by disconnecting the battery and waiting time for the power to de-energise. How ever I would not recommend replacing anything airbag unless you are really qualified and know what your doing. Could end in disaster. |
#2094 | |||
sorry GT but the FG/SZ airbags are not held in with 4 bolts. it clips in and a 'spring' holds the lower part in. to remove power down the cars systems (or at least the airbag systems) then i used a small torx allen key inserted in the hole at the base of the steering wheel airbag to release the clip so airbag 'pops' free. this is what i do to remove my FG airbag fitted to my BA - as per Gothefalcons instructions ( ![]() just make sure the airbag connections are correct as i found the SZ connector is differant (one of em to bag). cheers |
#2095 | |||
#2096 | ||
Hey Legend
Any idea what places in Western Australia stock the Genuine Ford Motorcraft Battery 560CCA and the retail price? Looking to get one for the FGX |
#2097 | ||
#2098 | ||
Giddy up.
What is the correct OEM Engine Air Filter element to suit 2016 SZII I6 Territory Petrol ?.
I have two different examples at home, one being AFA101 Genuine Motorcraft Air Filter. the other, Ford Care, Air Filter Element BG9601C. Cheers. |
#2099 | ||
BG9601C is the correct OEM one, AFA101 is the Motorcraft Cheaper Alternate. Both will do the job.
#2100 | |||
Mmm, sounds like a scammer script. Post real info if you have it. Sent from my iPhone using Tapatalk
-15 Ford Falcon FGX XR8 Auto -14 FPV Pursuit Ute #47 Auto -12 FPV Pursuit Rspec #44 Manual -11 FPV GS Ute #225 Manual -10 FG XR8 Ute Manual Sold -06 BF XR8 Ute -75 XB Falcon Coupe 351 GT replica -73 Ford Mustang convertible 351 -20 Ford Mustang GT Convertible |
