10-11-2022, 09:32 PM | #1 | ||
Trying to fit LED high an low beam globes, Navra H 7 and H 1 JW Speaker.
The orignal globes lock into the groves in the head light unit Backing Plate, you remove this backing plate to relace the globes, when you refit the backing plate the gloges are already locked into postion. These LED's have a round rear end that cannot lock into the backing plate. It there some sort of adapter ? Have I got the wrong brand of LED's Anyone know how to make this work ? All coments welcome |
11-11-2022, 09:14 AM | #2 | ||
Your 2010 Focus is likely an LV so you are right in choosing H7 and H1 so they should fit as those fittings are what determines the globe type. In other words any H7 bulb should fit into an H7 socket but it's possible that the backing plate is what is stopping the bulk from fitting as most of the ones I've seen are flexible (like the projector headlight Falcons).
A quick Google tells me that pre 2015 you have to cut a small hole in the backing plate so the rear of the LED can project out of it and if the car has the headlamp warning system then you'll need LED's with a resistor fitted or CAN Bus error free LED's. I won't bother you with the usual points about legality and beam pattern but you need to be aware of them.
