05-07-2021, 05:58 PM | #1 | |||
If I buy Focus units, are they a straight fit onto the Fiesta? Or can I graft Focus mirrors onto the Fiesta base? |
06-07-2021, 09:50 AM | #2 | ||
Lukeyson
A few people are reporting, and I myself have had the same experrience, that when you buy the powerfold mirrors from an aftermarket supplier for a Fiesta, they already come with the mouldings for the LS Focus indicator and puddle lamps in the body shell of the mirror, and you just need to grab the LS Focus scalps, and some LS lenses off the interwebs - all of which can be found on Aliexpress.
The trick will be in the wiring. The Fiesta comes with an 8 pin connector. With the powerfold in use, 7 of those are required, so you only have one pin free - for indicator or puddle, but not both. The solution would be to acquire the 10 pin versions of the connector shell from the same connector family - which is easy enough to do if you know the parts. I think I posted those parts in anoher thread somewhere which we could dig out. The bigger struggle comes from getting the wiring off the body loom and through the A-Pillar junction. There are 3 or so pins in the A-Pillar junction connector - but I do not yet know the part numbers for the pins that could be inserted into those vacant positions. Getting separate wires routed through there is the fallback - but they'd always be vulnerable and it would look a bit messy. The mirror position switch needs to be replaced as well, so you can powerfold the mirrors manually. But if you want the mirrors to auto-close and open when you stop and start the car, you need to reprogram your car using Forscan and a cheap switchable ELM tool from eBay - which is actually very easy to do. Lukeyson
If the human brain was simple enough to understand, we'd be too simple to understand it. |
07-07-2021, 08:39 PM | #3 | ||
Yeah, I guess I was hoping for a short-cut. Buy some Focus mirrors from a wreck, and graft them onto my car.
I'm always a little trepidatious buy after-market parts like mirrors, as I have found in the past that sometimes they are a less-than-perfect fit, and/or the plastic is poor quality and loses it's blackness. And knowing my luck I'd find the ones without the cut-outs. And yes, the connectors. I guess my first preference would be to upgrade the car to the Focus 10-pin. But I suppose I could just as easily upgrade both sides. Or even just add a separate plug for the lights. What source would you connect the puddle-lamps to? |
07-07-2021, 11:38 PM | #4 | ||
Lukeyson
The A-Pillar plastic trim on the Focus and Fiesta are different. So the Focus won't just bolt on to the Fiesta. The Focus Body/Shells, however, since they are otherwise identical, should be swappable onto the base. In fact you can even buy just the MkII Focus shells from Aliexpress - there's 3 or 4 screws that would let you swap them.
The powerfold motor, however, is part of the base.....and getting a base apart with it's spring-loaded bits is not for those of us without custom tools. The puddle lamps would be ideally patched to the courtesy lamp circuit - which is triggered when you open the doors and stays on for the little while after you close the doors and then fade out. Lukeyson
15-07-2021, 07:04 PM | #5 | ||
Thanks Luke
Do you know who made your aftermarket mirrors? Seems like ordering them is the place to start. |
16-07-2021, 11:11 PM | #6 | ||
Lukeyson
I bought Abakus Mirrors from www.onlinecarparts.co.uk - the 1213M05 for the LH and the 1213M06 for the RH. I think when I ordered them I got 20% discount as well - might have been the removal of VAT for overseas orders but not sure. (And to think we complain about 10% GST eh?). Shipping would have been a bitch, except I had a friend in the UK at the time coming back and he put them in his luggage. 2019 - when travel was a thing.
I then bought Focus MKII mirror scalps from AliExpress with the indicator cutout, as well as the Indicator lenses and the puddle lamp lenses. AliExpress also has the mirror controller with the 'manual fold' central position. Assembly not yet complete since they're destined for the 'project' car and not the road car. Luke
