Old 19-05-2018, 04:43 PM   #1
wasim
Exclamation water leak
I have coolant leaking at the back of the AU2 XR8 - any clues?
Thanks, Wasim
wasim is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2018, 05:39 PM   #2
falconhell74
falconhell74's Avatar
Default Re: water leak
possible welch plug behind the trans on back of engine block
XC GS OLD SCHOOL MUSCLE
Audi A4 S-line quttro
Xc falcon
Previous fords-
xc falcon 500 ,250 x flow 3 speed
xc gs worked 250 x flow 4 speed
xa Fairmont 302 auto wagon
xb falcon 250 log auto 4 door
xb falcon 200 log auto ute
xc gs project - had to sell :-(
xc gs 302 4 speed 4 door
xc gs 351 auto 4 door
zf fairlane 302 auto
zk fairlane 250 x flow carb auto
zl fairlane 250 x flow EFI auto
xg ute , BA falcon dedicated gas
xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5
falconhell74 is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2018, 06:32 PM   #3
wasim
That means the removal of the motor to fix or is there a couple of tricks I could try first?
Thanks
Old 19-05-2018, 07:14 PM   #4
undertow
Technical Contributor: For members who share their technical expertise. - Issue reason: AU Aux input HOW TO.
Heater tap, they are plastic and go brittle
Coolant leaks from the water pump/timing cover area can also run along the sump rails and show up at the back
undertow is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2018, 07:20 PM   #5
falconhell74
Get your hands on a pressure tester this way you will be able to find it easier.
If it is the welch plug behind the trans then its a trans removal.
Xc falcon
Previous fords-
Old 19-05-2018, 08:16 PM   #6
wasim
Thanks for the replies - water pump and heater tap has already been replaced - so I guess its a trans out job now.
Old 19-05-2018, 08:26 PM   #7
falconhell74
Like I said previously I would pressure test the system first as you dont want to drop the trans if you dont have to. its possibly a back welch plug on side of block running back then dripping , unless you can see the coolant coming out between bell housing and block ?
Good luck they are a pain to drop in a drive way.
Xc falcon
Previous fords-
Old 20-05-2018, 10:12 AM   #8
XC50077
Drive'n Cruise'n Live'n
XC50077's Avatar
There is no welsh plug in behind the bell housing area of a Windsor excluding the camshaft bore rear plug which seals oil only. I would check the heater valve and hoses, rear end of inlet manifold as well as any welsh plug if fitted to rear of heads. Hoses can have a tendency to leak at the onset of colder weather as the rubber contracts and loses a little flexibility.
XC50077 is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2018, 10:08 PM   #9
Edxr6
XC50077,
I have the same problem, coolant leaking from between the block and bellhousing, there is conflicting information about the 220 Windsor’s having the welsh plug at the rear of the block. Recently Ford had confirmed there is a welsh plug at the rear, however some members on the forum aren’t convinced. Can someone please confirm and provide some type of factual evidence.
Regardss
Edxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2018, 10:33 PM   #10
Sar4890
Sar4890's Avatar
Gents,
I wandered out into the shed to look at a 5.0 efi windsor out of i believe a f truck sitting on an engine stand and it apears to have a large brass plug of the same construction as the plugs on the sides of the block but larger. It is surrounded by screw in plugs could this be your culprit?
Sar4890 is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2018, 03:48 AM   #11
XC50077
XC50077's Avatar
The large welch plug in the rear, centre of the block seals the camshaft bore, the other screw in plugs are the oil gallery plugs.
Coolant running down rear between cyl head and block could be a small leak from the intake manifold.
Old 21-05-2018, 08:07 PM   #12
undertow
I've always had good luck finding coolant leaks with my hands. Feel around any suspect areas (especially botton of hoses near connections) then look for coolant on your fingers. A bright LED flashlight is good too as it makes the green dye stick out like dogs balls.
Old 05-07-2021, 08:21 PM   #13
Edxr6
Originally Posted by Edxr6 View Post
XC50077,
Regardss
Finally found my water leak, I know it’s been a while. It was slowly seeping from inside the timing chain case running along the top of the sump where it bolts up to the block then dripped down the front of the bell housing thinking I had the leak between the gear box and engine. I was baffled because there was no welsh plug at the rear of the engine. So I just put up with leak, even after I had it pressure tested, they didn’t pick it up. It wasn’t until my mechanic said he located a water leak when changing my valve springs, after recently one had cracked on my 220, which I believe is a common problem with 220’s.
