24-01-2021, 12:44 PM | #1 | ||
I’ve read a little across the ‘net on this. Plenty of (no surprise) under-informed commentary.
What I want to know, is - for the softer vinyl used on B series Falcons and corresponding Territory door trim uppers/arm rests - what exactly is going on.
The reason I want to know, is in order to possibly glue microfibre “suede” over these materials. |
24-01-2021, 02:18 PM | #2 | ||
Cabover nut
I guess dust, UV and sweat doesn't help vinyl age.
24-01-2021, 02:18 PM | #3 | ||
I think it's from oils.
The top of my BA door trim has gone all sticky where I rest my elbow. It's actually gotten worse since cleaned it.
24-01-2021, 10:23 PM | #4 | ||
Our Territory interior has suffered due to the missus using hand sanitiser...steering wheel and door trim
24-01-2021, 10:31 PM | #5 | ||
Has anyone arrested the process, found a way to remove the sticky vinyl feeling, without “over-coating”?
I’m worried if I clean it with thinner and glue on the fabric, it may release quickly. |
24-01-2021, 11:06 PM | #6 | ||
praek tih kl jo kr
The same happens in Mercedes, I had a S class that had the problem on the non leather parts, I found after trial and error that Metho gets the goo off, you have to give it a couple of liberal wipe overs but it removed the sticky crap
25-01-2021, 12:12 AM | #7 | ||
All Bran = Regular Member
For some reason I can't quote prev post to reply to what may be done about the "sticky" feeling on surfaces.
I had success a few years ago by rubbing talcum powder onto a "sticky" laptop case. Lasted for at least a couple of years until I sold the laptop. Might be worth a try. It certainly won't damage anything.
25-01-2021, 12:44 AM | #8 | ||
My theory is that the cleaning products we use do long term damage to the plastics/rubbers/vinyls.
25-01-2021, 11:15 AM | #9 | ||
White spirits is the best to remove most sticky stuff from trims. That or Prepsol, used to use in dealerships all the time.
25-01-2021, 11:26 AM | #10 | ||
just thinking, at the supermarket you can get "Planet Ark Orange Power Sticky Spot and Goo Dissolver" in a small orange bottle in the cleaning section, for only a few dollars. Try a small inconspicuous spot first to see what happens, then rinse or wipe off with warm soapy water. I found it far more effective than metho or wax and grease remover (prepsol), when they were only marginally effective in removing old contact adhesive residue.
25-01-2021, 01:56 PM | #11 | ||
That might work; at this stage I’m quite open to suggestions.
I’ve observed some details, the sticky tactile coated items (eg door grips) are a different kettle of fish and not really what I’m fussed with here - got a method for them already. The upper part of the door card is vinyl with a thin PE or PET foam backing. Stickiness on these parts, seems to come from the outside and therefore has a good prospect of being cleaned up. The armrests are vinyl type skin that’s bonded to a medium firm, foam rubber type underlay of about 5mm thickness. Not spray glued or vacuumed but a much stronger, moulded and formed bond. I believe the foam rubber underneath is breaking down, either the stickiness starts here or with a reaction to the vinyl overlaid. I don’t feel these are “saveable” but should be replaced/re-trimmed. |
25-01-2021, 04:04 PM | #12 | |||
It is the oil (plasticizer) coming out, this is what is used to make the vinyl soft. It can't be stopped, it will keep leaching untill there is none left, then your vinyl will be dry and cracked. The only way to stop this happening is to make the vinyl with a different plasticizer to begin with, but this is a lot more expensive. It can be slowed by keeping heat and sunlight to a minimum. All you can do now is keep it clean by wiping the plasticizer away when required, I would use metho, but always check on a small spot first. The foggy looking residue on the inside of the windscreen (when you haven't cleaned it for a while ) is the same or similar oil coming from every thing plastic in your car. |
25-01-2021, 08:47 PM | #13 | ||
Same thing happens with some old cameras. I have 2 Canon cameras exactly the same and roughly the same age. One covered with a sticky residue and the other perfectly clean. One has been handled more than the other so it's probably some reaction between the rubber and sweat. I can't remember what the fix was last time I googled it.
26-01-2021, 11:24 PM | #14 | ||
I had a 2009 Rio, where the control knobs did the same. They were still that way when we sold it.
Ya don't slow down as you get older ... you just enjoy taking longer to do it ... better! |
