20-04-2007, 06:37 PM | #1 | ||
Flying high...
Last night I got a call from a mate, who somehow managed to get himself bogged on a main road shoulder.
Anyways I get some thick rope out of my shed and drive down to him. After looking at the car and laughing at my mate I back my car up to his. Then I had a look under my car and couldnt find anything like a tow point or think loop of metal I normally see under other cars. I also had a look under the front and couldnt see any. Ive heard people hooking it up to the watts link/panard bar and bending them, so I wasnt going to use that. Im not sure if it was just too dark (no lamp posts around plus my phone doesnt have a torch on it) but is there any tow points on an AU? Front and back? If so, where abouts are they? Cheers...
AU1 Forte - 17'' AU2 Tickford rims on all corners, Super low springs,
KYB shock absorbs + camber castor kit and a 3.45 LSD, Tickford snorkel, 3" mandrel intake, K&N pod in the box, Polished Rocker Cover. |
20-04-2007, 06:58 PM | #2 | |||
Blown 5L coming
watts link?: nah, you wouldnt do that, as you said, they bend them. if you have live axel, around the diff housing works (obviously to one side on the thinner side where the axels are) but there are tow points front and rear, check you owners manual fro the points as im not really sure where they are on the sedan (i have a wagon), but they should be on the drivers side corners. the front one is behind the spliter and sits level with it. basically just a 3mm piece of steel hanging down with the oval hole for a hook.
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;) NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com Quote:
20-04-2007, 08:02 PM | #3 | |||
Flying high...
Ok, I'll have a look tomorrow under the car for next time. Yea I do have live axle and thought about the idea of using it as a tow point but since Ive lowered it, its a c*** to get under the rear and I had a full tank of petrol so it sat about 10mm lower then normal. I even have trouble pumping up the jack when Im trying to lift the rear.
30-10-2020, 01:55 PM | #4 | ||
i cant find a tow hook,or any tow point on my au's either
30-10-2020, 03:11 PM | #5 | ||
The owner's handbook will nominate the emergency towing points; often the tie down and at the rear a tow bar, if fitted, with notes that they should only be used in an emergency and then only for "light towing" on flat smooth surfaces.
regards Blue |
30-10-2020, 05:02 PM | #6 | ||
64 Deluxe 4 door
AU's dont break down so they never need towing.
or so they say..
XM Deluxe FG XR50 BA Pursuit Ute |
