Project Builds (non Car) Here is an area where you can show / discuss other non car builds be they bikes, caravans, boats, BBQ's or whatever. |
17-05-2020, 10:30 PM | #1 | ||
Looking for clues...
I'm partway through this project, I started it over a year ago, then put it away for a year while thinking of ideas.
This is what I bought. It's styled on a Fender Starcaster, which was Fender's foray into hollow bodied guitars to compete with Gibson way back then. I bought the kit from a WA company who has them made with enough differences that they don't infringe on copyrite. and the raw bits and pieces sort of pieced together... I've stained and started applying clear to the face I've now joined the neck to the body, and trying to work out a logo, and playing with a 3d printer to make this work. Stay tuned...
2016 Ford Falcon FG/X XR6 Turbo you beaut ute 1985 XR4Ti Sierra - Build Thread 1971 Fairlane 500 and... a collection of Jeep Towpigs and... two collections of rust and some new plastic bits roughly shaped like an F-Truck and.... some spare metal bits with holes in them |
17-05-2020, 10:50 PM | #2 | ||
Last weekend I flattened and dressed the fretboard.
5 users like this post: |
18-05-2020, 01:56 AM | #3 | ||
nice work
18-05-2020, 01:04 PM | #4 | ||
AU3 ute EL futura
Gee I never thought I'd see a starcaster kit. I remember seeing them in the 70's. No one wanted them, or the other hollow body fender made, can't remember the name.
18-05-2020, 01:28 PM | #5 | ||
The Coronado, with its cheesy-tinny-awful DeArmond budget pickups? As used by Hunters and Collectors in Wildwood variant?
19-05-2020, 07:21 AM | #6 | ||||
GuitarFetish
19-05-2020, 07:52 AM | #7 | ||
Cool project. Never knew about these, so checked out the pit bull site and was keen on the bc1 shredder until I realized it's not as simple as bolting together. I assume there's heaps of modifying & correcting flaws to make it playable?
19-05-2020, 08:08 AM | #8 | ||
Surprisingly, they go together really well. This is my fourth build, I built a Mockingbird style for my son, who loves his shredding, that one involved routing a cavity for a 9v battery for active pickups. The factory generally have their jugs set up well.
19-05-2020, 12:24 PM | #9 | ||
AU3 ute EL futura
Fender wide range humbuckers are no longer available. The originals used an alloy which is basically unobtainable now. The repros all use common alloys now and don't sound exactly the same. They are a different size to paf copies, bigger, and won't fit in gibson routes. They are basically 2 fender single coils in a bucker package.
The GFs are about the cheapest copies you will find anywhere. I've not heard any comparisons that are good enough to tell what they sound like. GF have a generally ok reputation though... I notice the kit pic has a stop tail and yours has a jazz style tail ? Was that a special order or have they changed the kit ? |
19-05-2020, 12:44 PM | #10 | ||
Was it one of those alloys rumoured to have uranium in it, or something?
19-05-2020, 07:11 PM | #11 | |||
I see on the new picture, the output jack has moved as well.
20-05-2020, 01:06 PM | #12 | |||
AU3 ute EL futura
Those sort of details are really for cork sniffers anyway, I'm sure the gfs pups will sound great, but if they don't, and you haven't cut the wires too short I might take them off your hands anyway. |
20-05-2020, 02:01 PM | #13 | |||
04-06-2020, 07:42 PM | #14 | ||
I decided to start fitting some hardware on the guitar this afternoon. First I had to fit the bridge mounts, which meant taking a hammer to pound them in. I fitted a couple of strings, and lined up the tail piece and screwed it in.
I'll head around to Jaycar tomorrow to see what types of shielded cable they have, and make up a wiring harness. I grabbed a piece of cardboard and mapped out where the volume and tone pots, pickup switch and output jack are located. Then I'll install it through an F-hole.
05-06-2020, 06:16 PM | #15 | ||
Well, once the end is near, it’s full steam ahead!All the knobs, pickups and switch all connected and installed. I threw on a cheap set of strings to set it up, I had to raise the nut by about 1mm to get rid of a bit of fret buzz, but first play and it went alright!
06-06-2020, 09:37 PM | #16 | ||
You don't need to hit the knurled inserts in - do you have a drill press?
Set the body on a soft cloth, on the press table, and wind the chuck fully open. Use a small "pad" of hardwood between the chuck and insert as you turn the handwheel and bring the (non-turning) chuck down directly above it. Where did you run the earth wire - to the bridge studs or tailpiece bracket? Good to see a less ordinary guitar build, especially coming to fruition. |
06-06-2020, 10:42 PM | #17 | |||
Good tip about the drill press, the body wouldn't have fit in the frame of the hydraulic press though I ran the earth to one of the bridge studs, and was very careful. On my last build, the earth didn't stay in place, so I ran it to the tailpiece instead. Both work well, though. I had my sons visit this morning, and one of them has taken up axe-wielding, and tried it out. He started falling in love with it. I played with the bridge height settings today, and wore out my fingertips, thoroughly enjoyed it! This was my last build, with the unseen tailpiece earth
06-06-2020, 11:18 PM | #18 | ||
That one looks fun, like a White Falcon dallied with a 6120.
06-06-2020, 11:30 PM | #19 | |||
2016 Ford Falcon FG/X XR6 Turbo you beaut ute 1985 XR4Ti Sierra - Build Thread 1971 Fairlane 500 and... a collection of Jeep Towpigs and... two collections of rust and some new plastic bits roughly shaped like an F-Truck and.... some spare metal bits with holes in them Last edited by Captain Stubing; 06-06-2020 at 11:38 PM. |
10-06-2020, 02:52 PM | #20 | ||
Have you been tempted by any pickups like the T-Armonds? That sort of thing is right up on my wish list. Really like the dynamic range of the originals, got that early twang like Duane Eddy or Chet Atkins, even George Harrison’s Duo-Jet stood out tonally.
10-06-2020, 03:04 PM | #21 | ||
The pickups in the red beast are nothing fancy, I don't get the chance to plug it in very often, but I've heard of these from a mate who plays in a rockabilly band. I'd also like to try out the P90.
10-06-2020, 04:12 PM | #22 | ||
They’re alright IMO but quite removed from the DeArmond sound. You wouldn’t feel you simply doubled up if you had both.
Heaps of fat bobbin single coils to try; toaster-tops, DeArmonds, P90, Jazzmaster, even the loosely wound early Höfner single coils. Many of these require narrow string spacing, though. |
10-06-2020, 06:53 PM | #23 | |||
I'll have to see what he has spare lying around for me to try, in return for me designing and 3d printing him some dog-eared P90 to humbucker adapter mounts
10-06-2020, 10:40 PM | #24 | ||
Can we hear you playing one of these Captain???
10-06-2020, 10:54 PM | #25 | ||
I'm not much of a player, not being in a band, or having a goal to practice for, I've not really progressed. But it's thoroughly enjoying making these guitars, and selling off my Taiwanese made ones. I'll keep the classic guitar I got when I was 10, the Hoffner I got when I was 11, my Magnum I bought in the 80's and the Maton accoustic. Anything else will be home assembled.
Though I could try record something, to show what a kit guitar sounds like...
10-06-2020, 11:00 PM | #26 | ||
I would love to hear its tones...
10-06-2020, 11:30 PM | #27 | ||
I'll see what I can do when I have my next days off... I better get practicing!
10-06-2020, 11:31 PM | #28 | ||
Don’t be shy, you must be better than me.
13-08-2020, 10:05 PM | #29 | ||
Rather than practicing, I've embarked on another build... this time a bass guitar. Never having played bass guitar before, I can only imagine it's not that hard.
I haven't decided on a colour scheme yet, whether to exploit the grain of the timber, or go for a solid colour. Here's the opened kit after I opened it...
4 users like this post: |
16-08-2020, 10:36 PM | #30 | ||
Is that a medium scale, or did the camera shorten it?
You might enjoy a bajo sexto build, they’re a niche thing and not everyone likes the tonal range. |
