Old 24-07-2016, 02:50 PM   #1
kenludlow
Default au continually beeping noise
Hi
I have a 2002 au ute, done 270km. It has started to continually beep from the dash when the ignition is turned on. The odometer displays normal for 5 seconds then turns too displays 5 and 20 which turns to "off". This beeping is continues when moving. Also when the car goes above 20km another beeping occurs. The speed indicator also flashes. I have tried disconnecting the battery for 12 hours, checked oil and water levels, fuses. No lights are flashing.
Any ideas. Ken
kenludlow is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2016, 02:57 PM   #2
hales231271
hales231271's Avatar
Default Re: au continually beeping noise
Over speed warning is set too low??
AU XR8 Pursuit 250 , Monsoon Blue
AU XR8 Rebel , Monsoon Blue
hales231271 is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2016, 04:10 PM   #3
kenludlow
Thanks for responding. My ute does not have a speed alert.
Old 24-07-2016, 04:21 PM   #4
JAJH
JAJH's Avatar
Check if you have a tail light out or your washer level is low.
FROZEN WHITE XR5 TURBO & MOONDUST SILVER XR5 TURBO
PREVIOUS RIDES
AU3 VENOM RED XR8, 19" SILVER ARGENTS, REBEL BODY KIT & 6/4 BREMBOS
MARS RED FG MK2 XR6 ECOLPI, SILVER ARGENT 19" RIMS & TINT
BLOOD ORANGE BA GTP, QUAD EXHAUST, SUNROOF, CHIPPED, SS CAI, 320KW
NAROOMA BLUE AU3 HERROD XR8- SS CAI, TS RIMS, 6/4 BREMBOS, TWIN SPOILER, REBEL BODY KIT & TUNED BY ELITE
VENOM GTP, HERROD EXHAUST, DVD PLAYER, WINDOW TINT, SS CAI, STEALTH
VENOM AU11 TE50, HERROD LOWERED, HEADERS AND EXHAUST
[SIGPIC][/SIGPIC]
JAJH is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2016, 10:57 PM   #5
needaXYGT
AU II XR8
needaXYGT's Avatar
Mine beeps if the window washer is low, even though it doesn't display on the instrument cluster.
AU XR8 II ute
XD FAIRMONT GHIA 302
XA FAIRMONT 302 TOPLOADER
needaXYGT is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2016, 07:52 AM   #6
kenludlow
Thanks for responding, checked tail lights, washer bottle. The car is a ute so it has only the basic accessories.
The beeping noise starts 10 seconds after the key is turned be fore the engine is started.
Old 25-07-2016, 08:26 AM   #7
Really or is that 270,000 km? Have a read of this http://fordforums.com.au/wsmpub/augx/Part%2015-3.html from http://www.fordforums.com.au/vbporta...hp?moduleid=82 and then your owners handbook ; the low series does have a basic overspeed mode and a button is probably stuck.
Old 25-07-2016, 01:36 PM   #8
Maka
Au Falcon = Mr Reliable
Maka's Avatar
A ecu scan may be needed to see if the bem or dash cluster is faulty. Try what I suggest if all else fails to fix the problem. Good luck!
cheer's, Maka
Old 25-07-2016, 02:48 PM   #9
Hmm maybe the low series Ute being a 1/2 carry over from the E series does miss out on speed control.
Old 26-07-2016, 09:47 AM   #10
Fyrestorm
Spanner Thrower
Is it one long beep or a series? If series count them (and any pauses) and let us know.
1999 AU Futura Wagon (Nickname Betsie the Barge-***)
Current Mods: Fairmont Cluster, LED's Changed to Purple, Lukey Competition Extractors, 2.5" Hi flow Cat, Hi-Stall Converter, ED Box with FG internals, AUIII VCT Fuel Rail + Injectors, F6 Fuel Regulator, Stereo upgrade, Aftermarket LPG.
Awaiting Wife Approval Mods:
TE50 Front Bar, AU Tickford/SR Interior, Roof Racks, Slimline Weathershields, 2.5" Cat Back Exhaust, 27mm Front Sway Bar, Other Shiny things!
Fyrestorm is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2016, 02:58 PM   #11
kenludlow
My ute has done 270,000km.
The beeps are continuous, as soon as the key is turned on. Also the other beeping comes in when the car is doing 20km/hr. The airbag light is always on.
The seek and + & - buttons don't work the radio. The Ecom button does not work even the Ecom symbol is on.
I,m starting to think I have a instrument cluster problem, getting a scan done in the next couple of day.
Old 26-07-2016, 08:07 PM   #12
superroo
You can't stop the signal
superroo's Avatar
Does the horn work?
Some symptoms there point to clock spring being faulty.
Also, does the beeping change if you turn the headlights on? Either with car running or not?
Old 26-07-2016, 08:43 PM   #13
The overspeed alert is also controlled by the seek button on the steering wheel (hence the circled 'S" on the button). It should work thus: To turn off the speed alert press the seek button for at least 2 seconds. Once the S symbol is displayed on the dash, press mode button and the word OFF will appear where the speed was once displayed. The display will return to normal after a few seconds, or to adjust the overspeed km/hr setting hit the plus or minus volume buttons. Check the harness below the steering wheel has not come fully or partially unplugged.
Old 26-07-2016, 08:45 PM   #14
Is it a bench seat with a column shift or a floor shift? If it's a column shift the non working economy button also suggests a column wiring harness issue. In any event also take the plastic shroud off the column and check all the wiring is intact, undamaged and has never had a aftermarket alarm or similar grafted into the wiring (the may have tried to splice the wrong wire and bodged the rejoin repair).
Old 26-07-2016, 09:41 PM   #15
The steering wheel switches can stick down so also try cleaning them (vacuum cleaner and then contact cleaner lubricant) and simply pulling them towards you to unstick them.
Old 27-07-2016, 11:59 AM   #16
kenludlow
Thank you for getting back to me.
My car is a 3 seat ute with auto on the steering column, base model.
Tried cleaning the seek switch, no difference.
Replaced the instrument cluster from another vehicle, no difference.
Disconnected the 2 wiring terminals that go to the steering wheel (horn, seek switch and airbag) and the 2 beeping noises have gone. No horn and the airbag.
Looks like it has something to do with the airbag system and speed alert (if fitted)
Old 27-07-2016, 01:27 PM   #17
The airbag and radio/overspeed controls do share a common ground (black wire) in the column so check that it is intact and shows no signs of damage or past repairs.
Old 27-07-2016, 06:55 PM   #18
If that is OK then check the cowl earth bolt is tight; inside cabin near base of window - top dash panel has to come off.
Old 23-08-2016, 02:40 PM   #19
kenludlow
Thank you those people who responded.
Problem fix, replaced the clock spring under the steering wheel.
Also fixed the metal bridge in the connector on the left seat belt wiring. (my vehicle does not have a left hand air bag).
Old 23-08-2016, 09:25 PM   #20
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Good to hear, well done
UK
Old 20-01-2020, 05:40 PM   #21
Henry AU
My basic Ford AU 2002 Ute has a beeping problem too. It beeps 5 times with a pause and repeats this 5 times (Beeps 25 times in all). Then approximately every 1/2 hour to 1 hour later the same thing happens again. Any ideas.
Henry AU is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2020, 05:47 PM   #22
raceteam
Failed airbag warning globe? Does it light up with key on?
raceteam is offline   Reply With Quote Multi-Quote with this Post
