15-03-2014, 08:52 PM | #31 | ||
About 225kg with iron heads.
15-03-2014, 09:00 PM | #32 | ||
Is that with everything still connected
phat ltd in the making very lowly |
16-03-2014, 12:09 PM | #33 | ||
and would a 560kg super cheap auto stand be enough to hold it?
28-04-2014, 01:52 PM | #34 | ||
Barra motor weight without boltons please Can someone give me a straight answer.
G6ET In Velvet & cashmere daily every option available dealer fit sunroof 1 of 2 built in this combination only 1 with sunroof =288rwkw 660nm. FPV BF F6 TYPHOON in TOXIC green BUILT ENGINE & MT built ZF, FORCED PERFORMANCE turbo HTA 37r Turbo e85 26psi= 525 rwkw 1162nm its DMENTD . BUILT & TUNED by ( PROFILE AUTOSPORTS ) first time on dyno after run in = Pacific Ford and FPV Carshow - DMENTD Dyno Run base 22psi on 98 : https://youtu.be/PoONpkk7qJE |
28-04-2014, 02:39 PM | #35 | ||
Missing a sock...
I've got the SC stand (t-base) and it handled my iron headed 302W no worries. Had a dressed 302 Clevo on it also. I didn't have much confidence in it with the Clevo but she took it no worries.
Cheers!
Real friends + great times = sheer bliss! Considering becoming an organ donor? Click here QLD Events, Cruises and Get Togethers: Click here Gain success instantly - lower your standards. It's not government funded - it's taxpayer funded.
28-04-2014, 05:10 PM | #36 | ||
VFII SS UTE
depends on which LS1 they measured, cant see the iron windsor the same as alloy LSX.
I don't often hear the sound of a screaming LSX. But when I do, So do the neighbours.. GO SOUTHS
21-12-2017, 10:51 PM | #37 | ||
XB,XF,ZL,EA,EL,BA,SY,SZII
The XC workshop manual specifies 317 kg dry and 326 kg wet. These things are way heavier than the 250 kg that folks commonly suggest. Try picking one up with only two strong guys. It's a real struggle with four guys.
22-12-2017, 05:08 PM | #38 | ||
GIMME FUEL, GIMME FIRE, GIMME THAT WHICH I DESIRE. ---------------------------------------------------------------- BA falcon XT mkII, 5.4lt, 5sp, Y-code, xy windowless pano, 3 on the tree manual. re-shelled xy falcon GT, manual. 1980 honda CX500 scrambler/dirt tracker |
10-01-2020, 11:29 AM | #39 | ||
Been diggin!
Just incase anyone came across this thread and was ever wondering. Ford EA-EL 4.0 SOHC head with valvetrain but minus cover, intake and exhaust is 27kg.
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery! Insta@mooneye_ghia White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly |
