I took my wifes car (not a Ford) in for a 30K service today. Car had 4 full of air tyres when I dropped it off in the morning. Got a call about 1 hr later from the dealer advising my Right Hand Front Tyre was punctured. I straight away assumed that I must have picked up a screw in the tyre on the way there and since the cost of the repair was only $30 I gave the dealer the okay to repair.
After picking the car up and getting it home I had a close look at the RHF Tyre to see if there was any evidence of the tyre being removed for repair or evidence of a plug in the tread or a white crayon circle from the tyre repairer. I am not a tyre expert but I could not see any evidence of a puncture repair It may be 100% legitimate and that the dealer has done nothing wrong which is why I have not name the brand, but after reading so many stories on this forum on bad dealers practices. I am ultra careful in checking out for myself every thing I am told by a Service Manager. My cynical side tells me that this is a perfect dealer scam as the low cost would not raise alarm bells to most customers and it is impossible to prove that no repair was done without removing the tye and checking from inside. I am interest if any other memeber have had ever had a puncture repair requested during service or if this an isloated case. |
I've had that done years ago, but was only $15. I didn't think to check for the repair. But I have repaired many times. And it's hard to find the repair after it's been driven on. Maybe washing the tyre will make it easier to find/prove you've been scammed.
it may be legit, but I'd probably just ask them to chuck the spare on instead of fixing.
![]() Join Date: Jun 2007
one of my tyres is plugged from a screw, it's super hard to see where it was repaired. Only reason i could find it is because it was in there for a few months before i got around to taking it in.
I had a tyre plugged not long ago (6 weeks maybe) and the repair is clearly visable even since the top of the plug has worn down to the same level. A couple of years back a had a tyre patched internally and it wasn't as obvious from the outside but if you looked hard enough you could see where the screw was, it looked like a small (3mm maybe less) cut in the tread, and the tyre was put back on the rim with the white marks about 10mm misaligned. Made highway driving awsome with the new anti fatigue vibrations above 70. Old mate worked hard enough on the $20 internal patch on a 38 degree day so I didn't complain and got new tyres shortly after as I was just about due anyway. Maybe it was repaired but not with a plug. Did they give the car back washed, or atleast with tyre black on it?
$30 is a bit much for a plug, as it is only a 5 minute repair not requiring the tyre removal. I had one done a few months ago for $10, but then I don't live in Melbourne.
Where to next??
I would be removing the wheel and looking for the plug. If it has been recently done it shouldn't be hard to find, even old plugs can be easily found as they cause an irregularity to the tread pattern.
If you can't find it pop it back on, take it back for a please explain...
Where to next??
I believe the old fashioned plugs are no longer legal and they now need to remove the tyre and use a mushroom plug that is pushed out the hole from the inside.
8 users like this post: |
I just had a look at the plug in my front left and it looks like a cigarette burn in the tyre. Still holds 43 psi but it's not hard to miss compared to the internal patch done on the fairmont
Thanks for the replies guys. Sounds like it is not a scam but maybe me getting more cynical in my old age.
This non Ford dealer who I have only been to twice did put tyre black on all 4 tyres and this was something that made more suspicious that he doing something to make it look like work was done on the tyres. Our Fords through the years have been serviced at the the same dealer for over 15 years and they have never put tyre black on the tyres. |
Maybe just for piece of mind just ask them what the repair entailed. When I was in my early teens I used to scam mum for Pocket money by claiming to have washed her white car (provided it wasn't too dirty and had no marks in the dirt) and just cleaned the wheels and blacked the tyres. 10 minutes work for $10. Worked for years.
#12 | |||
![]() ![]() Join Date: Jun 2006
4 users like this post: |
#13 | ||
born to be mild
Ive plugged plenty of tyres myself on my bikes & car using a slime repair kit, supposed to be temporary , but have had no problem with the plugs, easy to do. Tyre dealer recently told me they wont repair, they strongly advise to buy a new tyre. Thats why they offer insurance when purchasing new tyres.
PXII XLT RANGER 2012 focus st , gone now lv focus triumph Daytona 1200 the black beast busa gsx1300r |
#14 | |||
Proper plug repair does require tyre removal, bush repair with spaghetti plug doesn't. I know which one I'd like the dealer to do in town.
2017 Mustang GT (Magnetic) |
#15 | |||
Where to next??
I got a plug type repair kit from SCA with 5 or 6 plugs for $10 and used each and every one of them and they were a permanent repair. Not one failed. If I had a flat I will swap with the spare and buy another kit without hesitation. Last ford I bought included customer after service support that included free puncture repairs. Thought, you beaut, will just take the Focus there with the flat tyre in the boot... Nup, "tyre is 50% worn so technically it is not allowed to be repaired" (for free).. I wonder if that would have been the case If I walked in off the street and wanted to pay for it to be done?? Oh, and when they serviced the car 2 weeks prior the tyres were absolutely fine...
#17 | |||
You can always take it to a tyre shop later to get the "professional repair" if you feel the need
______________________________ 2015 Territory Titanium RWD Diesel - SOLD 2016 BMW X5 xdrive 30D Msport Seadoo Challenger 210SE 310HP |
#18 | ||
NTF6 is correct, to repair a puncture properly requires the removal of the tyre.
The plug kits that are used externally are designed to get you out of trouble, until you can have the tyre fixed. $30.00 for a puncture repair is the going rate in Sydney. Silver Ghia also raises a valid question concerning the possibility of tyre rotation. If the tyres have indeed been rotated, you have a decent Service Centre. |
#19 | |||
The good, bad and fugly
![]() Join Date: Feb 2016
Time was on my side! |
#20 | ||
So what did they touch on your car that is now missing a screw?
#21 | ||
Twas Kmart tyre and auto.
Tried to scam me with the old found a puncture during a wheel alignment. I was only 50 Metres away enjoying a coffee watching their every move when I got the call. Walked into the workshop whilst still chatting to the person who called me to see all 4 tyres on my car without any problems and was told that they accidentally called the wrong customer. They got really defensive and was told in no uncertain terms that I wasn't allowed to be in the workshop area. Told them that I wanted my car brought outside immediately with the wheel alignment not done at this stage. I left and never went back. Took the car to a local tyre place that is owned by the operator and they confirmed that no puncture existed. They did the wheel alignment and it cost $5 less than the scammers were going to change me. If I didn't have time off work that day and got the call call, probably would have given the go ahead for the puncture repair. Lesson learned.
