12-06-2017, 11:56 PM | #1 | ||
I have a KQ laser with a problem with the lock not opening. When I insert the key it only turns to about 1 o'clock not 3 o'clock as it is supposed to. I have been able to open the door by wiggling the key while I pull up on the lock knob. When the door is open the key operates normally, including the central locking. But when the door is closed, the key won't turn. I don't think the problem is with the "lock" but where it secures the door to the body. I have removed the door cover but not too sure what to look for.
Any thoughts would be greatly appreciated. I am getting a little tired of climbing in through the passenger door! I am sure one day I'll accidentally kick off some knobs off the radio or heater. Thanks |
13-06-2017, 07:20 AM | #2 | ||
Have a look in our Tech Portal as the KQ Workshop manual is there. Door locks and latches will generally be under the 'Body System' section.
Cheers Russ
15-06-2017, 12:34 AM | #3 | ||
Thanks Russ. I have had a look and wasn't able to find any information regarding doors/latches from the manuals in your link. However, I have attached the door diagram from a Mazda 323 manual I found elsewhere. I am guessing the issue is with the door lock as shown in figure 8.
I am still wondering if I need to replace it, or if there is something I need to look at/fix? Thanks |
18-07-2017, 12:22 AM | #4 | ||
The issue has been resolved and thought I would leave an update in case anyone has a similar problem.
The lock mechanisms come in either 3 wire or 5 wire. 5 wire is for cars with central locking AND remote entry, whereas 3 wire is required for central locking only. I required the 3 wire lock. The part is obsolete and not available new from Ford, and very hard to find from local wreckers. I ended up having to go to a Mazda wrecker and was told that I could use a 5 wire lock afterall. The guys at Allmaz (Clayton Sth, Vic) were very helpful, but I probably could have found one from a local wrecker if I knew I could use 5 wire lock. The new mechanism is in and the door now locks/unlocks properly. Cheers |
