Looking at replacing the right hand front wheel bearing & am concidering doing it myself. Is there any special tooling that I need for the job. Are they taper or roller bearings. Method info would be handy too. Thanks for any help.
There are a couple of special tools required - one to remove the wheel hub, one to remove the wheel bearing outer and one to remove the wheel bearing itself.
They are available in two sets: 49 B026 1A0 Puller Set, Wheel Hub (or universal equivalents) 49 D017 2A0 Remover Set, Wheel bearing Cheers Russ
