16-10-2016, 01:00 AM | #1 | |||
Exclusive: Carmakers forced back to bigger engines in new emissions era
16-10-2016, 04:07 AM | #2 | ||
Hi,
It's an interesting article about how EU has been measuring emissions in an unrealistic way. So it would be how to meet and perform realistic tests, and no longer do faked tests such as discovered by the VW diesel scandal. The article describes micro motors such as the Fiat Twin Air (2-cylinder) and some of the 3-cylinder engines. (Similar to Ford's Ecoboost 1-litre). The article describes: 'For years, carmakers kept pace with European Union CO2 goals by shrinking engine capacities, while adding turbo chargers to make up lost power. Three-cylinder motors below one liter have become common in cars up to VW Golf-sized compacts; some Fiat models run on twin-cylinders. These mini-motors sailed through official lab tests conducted - until now - on rollers at unrealistically moderate temperatures and speeds. Carmakers, regulators and green groups knew that real-world CO2 and nitrogen oxide (NOx) emissions were much higher, but the discrepancy remained unresolved. All that is about to change. Starting next year, new models will be subjected to realistic on-the-road testing for NOx, with all cars required to comply by 2019. Fuel consumption and CO2 will follow two years later under a new global test standard.' There are not many of these smallest engines in Australia anyway, so in my view there could still be some emission benefit from downsizing a little here. For example many cars in Australia having larger V6 engines could go down one size from 3.5 litres to approx 2 litres engine volume, and still function great at normal road speeds with less emissions. (Keep in mind that maintaining 100km/hour at the freeway takes only about 20kW). Driving around with a 200+ kW engine isn't totally necessary, (but fun of course). Cheers,
'11 FG Turbo '08 Territory SY RWD And some non-fords: E90 M3 build, '07 Rocket III, |
16-10-2016, 03:01 PM | #4 | ||
I think they get more wiggle room with a bigger engine. If they're doing real world testing, then I wonder if having to thrash the crap out of a little engine is actually going to be detrimental to testing.
I regularly switch driving between a small 4 turbo and an NA 6, and there's far less high revving to achieve the same result with the 6 when driving both sedately. (Although the 4 still uses far less fuel) It might also mean we start seeing more hybrids. They'd get away with a bigger engine to keep people happy with performance, but electric motors also taking some of the load off. |
16-10-2016, 06:09 PM | #5 | ||
It would be interesting to hear what the criteria of the real world testing is going to be. For example, drive at 100km/h for 10 mins and measure NOx levels, idle for 2 mins and measure NOx, in hot climates/cold climates etc...
16-10-2016, 06:26 PM | #6 | ||
With car companies spending so much money on R&D for these band aid emissions fixes, I wonder how much time and money it takes out of their research of proper fixes like alternatives to fossil fuels.
I know there have to be restrictions on emissions, but making it tighter every year probably isn't helping the end goal. |
16-10-2016, 07:02 PM | #7 | ||
WLTP cycles are here
https://www.dieselnet.com/standards/cycles/wltp.php |
16-10-2016, 08:27 PM | #8 | ||
Meanwhile in Australia we have known that bigger engines are better all along aka 4.0 I6T.
We are so smart we kept making them up until a week before we were proven right.
2004 Mercury Silver Falcon XR6T - 5 Speed 2017 Platinum White Mustang GT - 6 Speed 2022 Blue Thai-Special for Daily Duties - Auto |
16 users like this post: |
17-10-2016, 12:29 PM | #9 | ||
Peter Car
Thank VW for all this. I'll bet all the other manufacturers must want to destroy them.
5 users like this post: |
17-10-2016, 09:49 PM | #10 | |||
All utes who boast about 3000kg+ towing capacity should have something bigger than a 4cylinder diesel at least as an option. Yes keep the 4 cylinders for the people who want a cheap ute with high fuel economy, but give people the option for something decent. 8 Speed Auto, 0-100kmh 7.9 seconds and Combined fuel consumption of 7.6L/100km. As long as VW aren't twisting the truth, it sounds pretty good to me. Better than the 2L TTD 4 cylinder. |
18-10-2016, 01:52 AM | #11 | |||
Imagine the complexity of writing and implementing the test cycle for "real world conditions". Im going to imagine they are going to use something like what the professors and students from West Virginia University made for the back of a VW. Keep a look out for these contraptions attached to vehicles in your neck of the woods! |
18-10-2016, 08:33 AM | #12 | ||
Balancing act .. to satisfy the European emissions standards and the American CAFE (economy) standards .. and consumer expectations for performance, reliability, value-for-money, etc ..
Internal combustion engine manufacturers have a hard time of it now .. |
18-10-2016, 10:04 AM | #13 | ||
IWCMOGTVM Club Supporter
Im sure they were saying the same thing when cars went to efi and had cats. The better companies will succeed.
Daniel |
18-10-2016, 11:41 AM | #14 | |||
As VW's efforts indicated .. you can satisfy a lot of these criteria, but probably not all. You can have emissions and economy, but not performance. Or you could have performance, emissions and economy .. but not low $$$, etc, etc. |
18-10-2016, 03:05 PM | #15 | |||
Daniel |
18-10-2016, 03:09 PM | #16 | ||
18-10-2016, 03:20 PM | #17 | |||
Render unto Caesar
I'd wait for more information but I suspect what they mean by bigger engines is moving from 1.0 3 cylinder to 1.5 4 cylinder. I'd also hazard a guess that electric hybrid power will be more used too.
"Aliens might be surprised to learn that in a cosmos with limitless starlight, humans kill for energy sources buried in sand." - Neil deGrasse Tyson |
18-10-2016, 04:12 PM | #18 | |||
Former BTIKD
You can have it Good, Fast or Cheap..............Pick two
18-10-2016, 04:22 PM | #19 | |||
Peter Car
18-10-2016, 09:24 PM | #20 | ||
Lost Focus In The Sunset
So they are going to bigger engines to combat emissions, but by using bigger engines they will also be burning more fuel would they not? Which is not better at all.
18-10-2016, 09:50 PM | #21 | ||
You can combat it with more efficient transmissions, saving weight in the car (which will save more fuel then anything).
Daniel |
18-10-2016, 10:05 PM | #22 | ||
18-10-2016, 10:20 PM | #23 | ||
There was a trend that started...briefly...quite some years back in the USA with "mega-big-blocks". Street Machine magazine had a short article on it, hoping it would take off here, but it never did. They were alloy V8's of 8 to 10 liters, with a single four barrel carby that appeared to look like a "normal" large V8.
The point was that these motors were torque monsters, and put out up around 600hp+ in a very under-stressed way, but cruising on the highway they were returning some ridiculous fuel economy like 20mpg or so. The reason was efficiency and never really having to work hard. Sometimes a larger engine can be more efficient than a smaller one. |
19-10-2016, 11:33 AM | #24 | |||
You could not get a 173 in a HX-J or WB because of the ADR27A and some 4 cyl had to go bigger as well. With the 173 loosing it's ability to comply in the Kingswood was that it was to gutless to comply due to the limit's of the testing parameters and the 253 and 308 had to run EGR in automatic form but not in manual form. The same would be true with the newer laws coming that will restrict performance and lead to having going up in size a bit more to pass the ADR testing. It's only like a 1.6L may go up to 1.7L or maybe a 1.8L one may think it will use more fuel being bigger or pollute more because it's bigger but it will not be the case under the strictness of the ADR. So it has to do more about power to weight efficiency, so as to get to the targeted levels. |
20-10-2016, 03:37 PM | #25 | ||
Just recalled the one that was in Street Machine...it was an SLR Torana fitted with an 8 liter alloy V8.
Inevitably enough it was named...and had the graphics on it to suit..."SLR-8000"... Here's a bunch of photos of it. Efficiency through cubic inches.... https://www.google.com.au/search?q=s..._4CtEQ_AUIBigB |
20-10-2016, 03:49 PM | #26 | |||
Our Tickford cars: 2001 Congo Green AU 111 XR8 sedan, manual option 2G body kit but now wears the Rebel kit 1997 EL GT Sparkling Burgundy, sunroof, auto. Our former Tickford cars: 1997 XH11 XR8 1998 AU XR8 manual sedan 1999 AU XR8 manual ute 2002 AU XR8 auto sedan, sunroof |
20-10-2016, 04:04 PM | #27 | ||
Bigger engine doesn't necessarily mean higher fuel consumption . There are many factors that determine fuel consumption and engine size it far from being the most important one.
20-10-2016, 09:17 PM | #28 | |||
I think it would sell well it was similar priced to other top spec model (about 65k). But VW have already said something along the lines of it being better than the rest. To me that suggests it will be more expensive than the rest. |
