Old 05-09-2015, 07:04 AM   #1
EB#
EB#'s Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Constant helpful advice and step by step guides in easy to understand format with pictures.
Default Option for "Edit" function to remain open?
Hi there FF Team,
I'm not sure if this issue has been discussed before, however I note on FF that the edit function for authoring a post is only open for a limited time. I was wondering if it has ever been considered to leave this "edit" function open?
This is a pretty common feature on other car forums and it assists with a few handy functions for the author:
- ability to copy the post code at a later time
- ability to edit or make corrections at a later time
- abilty to edit an opening post of a "build thread" and add some hyperlinks for specific work, in the style of an index or contents list, as the work progresses.
Refer to this page for an example of my third point above:
http://www.subaruforester.org/vbulle...achine-152857/
Cheers.
EB# is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2015, 08:36 AM   #2
STEALTHY
Default Re: Option for "Edit" function to remain open?
Alot of forums are going this way now, aswhen someone has a hissy fit, they go back and delete all the text out of their posts, and threads end up with huge holes in them.
I'm not sure if it can be done in specific areas, but the my ride section would be a good idea to have it open. Rest of the forum, not needed!
STEALTHY is offline   Reply With Quote Multi-Quote with this Post
Old 04-10-2015, 09:45 PM   #3
EB#
EB#'s Avatar
Any comments from a moderator on this one?
Cheers.
Old 05-10-2015, 12:32 AM   #4
Simple6
Simple6's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Tech article on rear bushes.
I seem to remember Russellw answering the same question a few years back.
The issue is (like said above), people going back and changing their posts after other people have given specific responses to the original text. You easily end up with chopped up and out of context threads, which I find really annoying on other forums.
A pet hate of mine is when people sell their item or get an answer to their question and go back and delete their original post with something like "edit: resolved, thanks". That post or question could have helped someone in the future, but now it's turned into a useless thread with no context.
Personally I have no issues with people correcting themselves in further posts (and I've done it).
So yeah point is, I can see the benefits you've listed, but I guess I disagree overall because I think the negatives outweigh the positives.
1976 XB Falcon 500 Wagon - BUILD THREAD
Sherwood Green | 3spd/250CI | Running Whitewalls on a 2.5" Drop
Simple6 is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2015, 06:14 AM   #5
EB#
EB#'s Avatar
Fair comments there Stealthy and Simple.
Old 05-10-2015, 07:19 AM   #6
russellw
russellw's Avatar
That was precisely what I said thanks.
Russ
Old 05-10-2015, 07:47 AM   #7
sbutler
335 kw of goodness
sbutler's Avatar
I think its a good idea, as a thread goes on, you may re visit it when you have more info to add. Or you have solved your problem You can edit a specific detail.
CAUTION!
STILL Contain's opinion's & fact's that may offend !!!
2012 GTP 213 black what was I thinking? NOW FOR SALE>>
http://www.fordforums.com.au/showthread.php?t=11439680
sbutler is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2015, 08:12 AM   #8
Mont5.0
Mont5.0's Avatar
Isnt this one of the roles of a mod?
FGII XR6 IN LIGHTNING STRIKE
R52 SIII IN GUN METALLIC
Mont5.0 is online now   Reply With Quote Multi-Quote with this Post
Old 05-10-2015, 10:30 AM   #9
MAD
Petro-sexual
MAD's Avatar
I've seen some forums have a feature that even disallows replying if a thread has not been active for 12 months.
EL Fairmont Ghia - Manual - Supercharged
- The Story
MAD is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2015, 09:02 AM   #10
sbutler
335 kw of goodness
sbutler's Avatar
Ive been a mod on here, & its very hard keeping up with all the post's. So a permanent edit would be a great idea.
CAUTION!
Old 18-10-2015, 10:31 AM   #11
russellw
russellw's Avatar
The current 30 minute edit period should be enough to cover most situations and failing that a PM to a mod or admin will get the edit done for you so it's hardly a big issue.
Russ
Old 18-10-2015, 04:16 PM   #12
supershifty
Missing a sock...
supershifty's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Dave has been a long time active member on the forums and in particular has been a busy volunteer whenever there are cruises and toys runs etc held in South East Qld. He actively gives up his time and ensures that the events are provided for, be it commun
I totally agree that the current edit period should remain on the AFF.
If I have to add/delete/correct something after the edit period has expired, I quote myself with the original and notate in the new post my correction/s - with apologies.
I think this is helpful in minimising any confusion for members following the thread, especially if my incorrect post is one or more pages back.
Cheers!
Real friends + great times = sheer bliss!
Considering becoming an organ donor? Click here
QLD Events, Cruises and Get Togethers: Click here
Gain success instantly - lower your standards.
It's not government funded - it's taxpayer funded.
supershifty is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2015, 12:31 AM   #13
Crazy Dazz
I often make silly typos or slips. I write XH when I mean ZH which makes the whole post seem silly, or say MAF instead of MAP, etc.
However as long as Mods don't get too annoyed with me requesting fixes, it should never be a huge issue.
A good option, if it were even possible, might be to allow editing to stay open until a reply is posted?
Time to Make the Hippies Cry Again
Old 23-10-2015, 08:57 AM   #14
STEALTHY
Or you could, go over the post before you submit it, and again after it loads into the thread ;)
