Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Shockworks
Shockworks Ford damper specialist located in Melbourne's S.E suburbs. Website Link
Old 12-09-2014, 01:15 PM   #1
Tock
Tock's Avatar
Default Thanks Shockworks!
Big shout out to Chris and Brett at Shockworks.
I was up at their workshop yesterday having the OE replacement dampers put in the F6. Great guys to have a chat to, efficient install, and boy do they know their stuff!!!
After install, I took the "long way" home and was really happy with the results of such a simple upgrade. The car feels so much better through corners, and handles road changes really well - I was worried about a harsher ride, but this didn't present at all. If anything, so harsher road conditions feel smoother.
The biggest improvement (after only a couple of hours with them so far) is mid-corner wallow and the floating feeling you get off the stock setup - particularly if there are elevation changes, ruts, etc mid-corner. Traction and power down out of a corner also feels improved, although I will need to go back to stock sway bars from their advice to perhaps remove some twitchiness in the rear end.
If people are thinking about Shockworks products, then I can say that you won't be disappointed with their gear, service and knowledge. Thanks again!
2011 FG FPV F6 - Winter White, manual, XForce twin 2.5" cat back, Venom 100CPSI cat, Walbro in-tank pump, S/C Miami CAI by KPM, MW short shifter, Shockworks OE dampers.
TUNED by Pit Lane Performance.
Tock is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2014, 01:34 PM   #2
Dash_XR
Dash_XR's Avatar
Default Re: Thanks Shockworks!
Good review mate. Are you still just at standard height or lowered?
FG XR6 Turbo (Manual) - 301rwkws @ 15psi
Rapid Systems Intercooler & Battery Relocation - ID 1000 Injectors - Process West Surge Tank - Venom 100 Cell Bolt On Cat - XForce 3.5 inch Catback - Plazmaman 4 inch Turboside Intake - Crow HD Valve Springs - Glowshift Gauges (Oil temp, Oil Pressure, Boost, Volt) - Malwood Opt 5 - XR50 Interior - FG2 Limited Ed 19's - Nitto Invo's
Dash_XR is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2014, 02:26 PM   #3
Tock
Tock's Avatar
Cheers Dash - I am sure anyone with more track and car experience than me can provide some more technical wording, but it was an overall feeling of confidence in to rough corners that I got from the car post-install that impressed me the most.
Standard height, no plans to change that at any stage as I have enough dramas with clearance parking at work. Maybe I can convince them to install some ramps....
Old 12-09-2014, 02:27 PM   #4
ratter
ratter's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful. Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs
just this week we fitted the Shockworks OEM replacement shocks in my Wifes G6ET, although not a big a change as their coil overs, the ride quality has improved, all the wallowing over bumps has disappeared, I have not had the chance to try it through any twisty roads yet
20 Rosella St Frankston 03 9783 8122
Authorised Streetfighter, Pcmtec , SCT & HP Tuners Tuning Agent,
ratter is offline   Reply With Quote Multi-Quote with this Post
