Adapt or perish...
As stated in the thread title, what is the wheel offset for an AUII?
Thanks in advance. EDIT - Nevermind. I found out. 5 stud. 114.3mm PCD +35 offset
Carless
Miami Pilot
![]() Join Date: Jan 2005
Yep that's it - you can go +/- 5mm on the offset without too many dramas.
Adapt or perish...
So I can go in between +30 and +40 and it should still be OK?
Anyone know what the wheel offset on a EL was?
Carless
EL was 0 offset
'09 SYII TTG | Mystic '06 BF XR6 | Mercury Silver
Adapt or perish...
Oh sh*t.
Ummm, how much damage can a 0 offset do to an AU?
Carless
Miami Pilot
It should just about be rubbing on your guards. I know my old AU XR6 did when I fitted 17X8s on the back. Don't think I actually managed to fit them to the front as they hit the guard anyway. But if you have EL 16 x 7s, then you may be OK - would look funny though, as the rims would be sitting outside the guards.
Adapt or perish...
The rims do sit outside the guards. If you look at it head-on, it looks real aggressive. I'm still gonna need to replace them otherwise, cause it isn't helping steering, and I've had them re-aligned.
I'm still not happy with the guy who sold it to me though, lying scumbag.
Carless
Silhouette AU1 TS50.
Just remeber that as part of RWC requirements, it state that your rims/tyres have to be inside, or level with the guard edge. These rims would make your car unroadworthy.
"People can have the Model T in any colour.. so long as it's black." HENRY FORD (30/07/1863 - 07/04/1947) PIC'S OF MY T1 TS50.
Adapt or perish...
Yeah, but how different is roadworthy requirements in VIC compared to QLD?
Carless
can anyone tell me quickly if +45 offset will fit AUII without dramas?
It's 9mm over the listed offset |
Stay Classy ™
+45 means it will go further inside the guard. Hit and miss whether it will cause you issues because of brake caliper thickness. I wouldn't have gone any bigger than +35 to be honest
#12 | ||
hmm, these are 20' rims & new tyres REALLY cheap under half price but they are off a Mitsubishi 380.
a tyre site i cooked up has AUII offset at 36 & the 380 at 45, i was thinking it'll be close, was more concerned about the clearance for the suspension, but i guess +45 means it sits further out. |
#13 | ||
looked up*
#14 | |||
Stay Classy ™
#15 | ||
T-Series Club Member Vic
Mitsubishi 380 will have the same stud pattern and offset, but I'm pretty sure that the centre hole will be too small so you'd need to get them modified to fit onto the AU's larger hub centre.
#16 | |||
Miami Pilot
It will also depend on what width the rims are, since the offset and width will dictate how close the inner part of the rims will be to the suspension. For a 45P offset, if it's a 6" rim, then no problems; an 8" may also be OK, but a 9" or more will probably hit. With 35P offset and 8" wide rim, there's about 15mm gap between inside of tyre and the suspension on my BF, which is pretty much the same setup as an AU. So, like Ride said, fit them up before paying, and if they fit, pay, if not, walk (or drive on standard wheels) away.....
#17 | ||
45 offset probably would be illegal in some states. It will reduce your track width by 20mm. Whilst some states allow 25-26mm increase or decrease, some states it's illegal for any decrease.
