Old 11-06-2013, 02:42 AM   #1
johncle
Default KE laser no start
I have a KE laser 1.6 carb. I have replaced coil & distributor & still have no spark at plugs. I am completely lost, can anybody help please.
Thank you for any response.
johncle is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2013, 05:15 PM   #2
Peter B - CV8
Default Re: KE laser no start
Is the new coil properly grounded. You usually need to scratch off some paint on the coil (where the retaining bracket touches/fits).
Peter B - CV8 is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2013, 02:26 AM   #3
johncle
It is not the std round coil, it is module type coil, I cleaned body where coil mounts and I have replaced engine control module on fire wall, still no spark, dist came off a running vehicle.
Old 14-06-2013, 09:25 AM   #4
Peter B - CV8
Ok - understood. Still got the old coil & dissy ?? maybe try changing them back (separately) to isolate the problem.
Old 14-06-2013, 10:08 AM   #5
LordFordNZ
From memory, there is a black module inside the distributor called an ignitor....about the size of a matchbox, that can pack up. Easy to replace, needs to have thermal paste under it though. If this packs up, no spark.
Something like this:
http://www.ebay.com.au/itm/IGNITION-...-/121066909830
LV MKII Focus XR5 - no mods yet!
LordFordNZ is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2013, 11:11 AM   #6
johncle
I have tried all the swap with old & new, I have put both units on a friends laser & they work ok.
Old 14-06-2013, 11:13 AM   #7
johncle
Old 15-06-2013, 12:29 PM   #8
Peter B - CV8
Geez that's weird. Might be time to get a auto elec to look at it ???
Maybe also check all your fuses & relays - to make sure one hasn't blown.
Engine is cranking over - just no spark ????
Old 15-06-2013, 12:40 PM   #9
johncle
Thanks Peter, I think it is time to send to wreckers not worth spending more money, its had a good life.
