#1 | |||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
Just when you think things are going good, I get the phone call from number 2 son,"cars making realy strange noises and it wont steer straight" (AU111SR)
Well have been away all week so haven't had time to scratch myself, so decided it would be easyer to get it towed from Melb. CBD back to Cranny . So finally got home to have a look at it this morning only to find this mess ![]() . ![]() ' ![]() . ![]() it would appear that the lower right ball joint gave up with little or know warning, Lucky it was only in the city at low speed and not on the freeway at 100kph as the wheel locked as it chewed through the rotor ![]() ![]() On another note I am giving the car a full going over and service while its hear and have found a nasty oil leak from around the water pump someware,did a bit of a search but haven't come up with much info on this being a problem or ware it may be leaking from so before I pull half the front off the motor I would check here first. restasured I have checked the usuall rocker cover gaskets ext. but just carn't seem to pin piont ware its coming from.. Thanks In advance Whoosha
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
Smile
woosha.. Get a 10 mm socket ...gently tighten your timing case bolts. Also you may find an alternator bolt actually leaks oil.. Any way start with the timing case and the degrease it
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
#3 | |||
AU DIE HARD
yeah thats no good mate, when my balljoint got really worn it was doin similar, i just got to earlier. pretty rough.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm. |
Thats a serious failure of a ball joint!! Don't you guys have a yearly RWC down in Victoria? Ball joint normally become quite obvious way before they get to that state.
Scary when you thing of the possible out comes of that mate!?!! Dom |
2mny projects 2 lttl time
Mate is there any chance your "oil" leak might be power steering fluid?
Just a thought |
Actually domnicosia we dont have yearly RWC. but i can tell u straight my lower balljoint was still good 2 weeks earlier when we had car on hoist checking everything, and then later that week i was driving, it deleloped a squeak, a couple days later when turning it started grinding on the disc, which i heard, pulled wheel off to find it. When these go like this, there really is very little warning.
#8 | |||
AU DIE HARD
As Matt has said no warning at all realy we had new tyers fitted 2 weeks ago
and all was good then , anyway all done now just came inside got all cleaned up so I can go to work for a rest,Off to Rockhampton in the AM The pesky oil leak turned out to be the timing chain tensioner after numerous hours of pulling things apart I found it behind the power steering bracket .FFS who thawt that one up.Some how it had come loose and undid its self ![]() ![]() ![]() -------------------------------------------------------------------------- its in behind all this ![]() pesky thing ![]() All done ![]() ' ![]() ' ![]()
5 users like this post: |
![]() Join Date: Dec 2004
Good job whoosh, which car do you want next week the wagon
Hmm Project XW VAN !!!!
Im pretty sure the only wagons you have are from the wrong stable........
Just dont think he would stoop that low... Kev
I'd rather be BLOWN than stroked Yella Terra Supercharged Power Output? ![]() ![]() POWERED BY VISA MASTERCARD AND MORE VISA (And now a mortgage extension) Disclaimer : ![]() ![]() |
#12 | ||
Yep ... BOOSTED
Damn, that could of been deadly at high speed.
Im glad I got my Balls fixed earlier. Would hate to drop them at 110 :0 |
#13 | ||
they can fail suddenly. mine was fine for my yearly RWC and the lower right started making a noise and the ball joint failed suddenly making a grinding noise on right turns. I caught it early enough that the rotor wasn't damaged but the guy at the suspension place that fixed it said he sees it a lot
[SIGPIC][/SIGPIC]
#14 | |||
not here much anymore
RAM 1500
#15 | ||
that happened to the wife's wagon, after having new a tire fitted and they said it needed a wheel alignment.
Drove to Ballarat that day, we were lucky. |
#16 | ||
RAGE Engineering
Timely thread.
I have an AUIII and it was making a kind of creaking/grinding noise from the front end only at parking speed and steering load applied. Jacked the car up to take a look, lowered it and noise gone? Symptom of ball joints? Front end feels tight otherwise.
If it doesn't fit, use a BIGGER hammer |
#17 | ||
The V8's do suffer a little from heat soak down the drivers side as the headers are really close to it, which will make it "creak"
http://i56.tinypic.com/23hlk6p.jpg |
