Old 11-02-2012, 04:17 PM   #1
phantom_87
phantom_87's Avatar
Default whirring noise from kenne bell
Hi guys i got a kennebell kit installed in my falcon about 2 weeks ago and it has now started to give a whirring sound after the first week.
When i first picked the car up it never made the sound it has now. It happens when the rpm is just lifted above idle and when driving it happens when the car is on a steady rpm and on down revs.
when i lift the throttle i am ever so slightly touching the accerator.
We took the belt of the car to eliminate that the noise was coming from the engine. Then i also put the standard belt on to bypass the blower and the noise was also not there.
We then put the normal belt back on and the whirring noise was back.
Is this meant to be normal or do you think i should take it back to the shop to have it looked at.
Only reason i am asking is because it wasnt happening for the first week and a half of having the kit fitted.
I know these blowers are meant to give a whinding noise when under abit of acceleration.
Thanks
Daniel
445RWKW of kennebell goodness
phantom_87 is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2012, 04:36 PM   #2
tex
Broken
tex's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: With the exception of maybe HSE2, nobody writes a review like Texy.
Default Re: whirring noise from kenne bell
Hi mate, speak to the shop that fitted it asap. I do recall who fitted it btw.
Have you tried a fresh blower belt?
Send Agro a pm and seek his advice as well.
http://fordforums.com.au/member.php?u=1501
My belt squeaks a bit when it's cold, but runs quiet when it's warm. These head units will make a whining sound under load, but that's not what your describing I don't think.
In the mean time, try not to use the car until you've spoken with the shop / Agro.
tex
The Scud GT
11.4 @ 128, 1.88 60ft.
tex is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2012, 04:47 PM   #3
phantom_87
phantom_87's Avatar
No i havent tried fitting a new belt as i am still yet to get myself a spare belt.
Ill give the guys a call on monday to see what they.
The things is the noise happens when its not underload. its very similar to the sound it makes when under load but its there as soon as the rpm is off idle. Even happens when its warm as soon as the car starts up but then when it comes back down to idle its gone.
Ill will park it up until i get ahold of the shop just to play it on the safe side.
Ive also sent Agro a pm
Thanks tex
Old 11-02-2012, 04:52 PM   #4
tex
Broken
tex's Avatar
It could be just the bypass, or the belt, so don't panic yet!
But play it safe and get some advice first.
Agro lives and breaths these Kenne Bells, he knows his sh%t and will give you the good oil and talk you through it.
The Scud GT
Old 11-02-2012, 06:14 PM   #5
phantom_87
phantom_87's Avatar
hopefully it is something simple and nothing to worry about.
Old 11-02-2012, 09:43 PM   #6
Bluepower
KenneBell Australia
Bluepower's Avatar
Hi mate,
the obvious first one is CHECK OIL!!! Oil should be between the two marks on the dipstick (not level with the top line as you would look for in a sump oil check)
The not so obvious one is when you remove the belt, check the idler that is supplied with the kit on the bracket that picks up on the alternator mount, could be a bearing not seated correctly.
If you find something, give us a yell and we shall airbag one up to you monday morning, your kit is under warranty so if anythings amiss, rest assured you are covered.
Chris
Bluepower Racing Developments
Proud Australian Distributors of Kenne Bell superchargers
The Quickest, The Fastest, The Baddest Boss Blower of all.
www.bluepower.com.au
Bluepower is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2012, 07:36 PM   #7
phantom_87
phantom_87's Avatar
well i checked the oil and that was fine. I also put a stethoscope on the 2 idler pulleys as well the front bolts on the head unit of the kb and i couldnt hear anything unusual, but if listening to it with the bonnet open it sounds like it is coming from the kb
Old 12-02-2012, 08:01 PM   #8
burnz
VFII SS UTE
burnz's Avatar
i think he means does the blower have oil?? unless i read your post wrong..
I don't often hear the sound of a screaming LSX.
But when I do, So do the neighbours..
GO SOUTHS
burnz is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2012, 08:26 PM   #9
phantom_87
phantom_87's Avatar
I meant i did check the oil in the blower and that was fine
Old 12-02-2012, 08:32 PM   #10
burnz
VFII SS UTE
burnz's Avatar
are the pullies misaligned?
is it you power steer?
i dont want to sound like a dick,,just asking to remove all options.
GO SOUTHS
Old 12-02-2012, 08:38 PM   #11
phantom_87
phantom_87's Avatar
well the thing is that i put the standard belt on to bypass the blower.
not unless the blower could be putting extra strain on the power steering as there is a small oil leak around the pump.
At first i thought it was the power steering pump until i put the standard belt on and the sound wasnt happening.
who knows it might not even be the kb it could be something else around it
Either which way i still love the kennebell setup and have no regrets buying it.
Old 12-02-2012, 09:13 PM   #12
burnz
VFII SS UTE
burnz's Avatar
you have me stumped,, be shure to inform other whom may have this problem, that will help..
an audio may help other veiwers diagnose your problem!!
GO SOUTHS
Old 13-02-2012, 09:32 AM   #13
phantom_87
phantom_87's Avatar
Well after a pm from Agro explaining a few things I don't think there Is a problem with the unit. As I wasn't the only person thought there might have Been a problem.
Thought I'd try and play it safe and ask the question.
Thanks again
Daniel
Old 13-02-2012, 09:38 AM   #14
tex
Broken
tex's Avatar
Cool, better to be cautious with your new blower than ignore a concern!
Glad it's been resolved.
The Scud GT
Old 16-02-2012, 05:15 PM   #15
phantom_87
phantom_87's Avatar
Good news it was just me worrying as the noise wasn't there when I first got it buy was told its just the blower has worn in and I also took it back to the shop who installed it and they said it was nothing to worry about as it was normal.
Thanks
Daniel
