Old 13-11-2011, 06:35 PM   #1
xf1101
cast iron is real steel!
Default footbraking brake pads
G,day all,
In a footbrake application, only concerned with maximum holding power on the start line, so relatively cold brakes, what is the best type and brand of disc pads?
Thanks!
Paul
xf1101 is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2011, 06:55 PM   #2
Giant
Giant's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Organising Nulon to sponsor AFF.
Default Re: footbraking brake pads
I am not sure on the best pads I just use a Race brake pad from Race Brakes Sydney he is a site sponsor and know his brakes. Also I found braided brakelines a great upgrade for holding consistent pressure and a good superdot 4 or 5 brake fluid.
Giant is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2011, 09:50 PM   #3
xf1101
G,day,
Thanks very much for the reply!
Paul
Old 28-11-2011, 10:36 PM   #4
dieseltrain79
You dont want to use too low grade a pad thats going to fade super quick if breaking from 120+mph ( unsure of the application your requiring ) .
1 Reason i went soltted rotors up front ... Can stop from 200km/h without and issue . Just using a Lucas Pad supplied with myy RDA slotted rotors .
1998 AU VCT Ghia - Stock as a rock - Wifes car
1991 Toyota Soarer TT - 11.72 @ 116.7mph
2004 Ford Escape XLT V6 - Family Ride .
dieseltrain79 is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2011, 07:53 AM   #5
GTP owner
GTP owner's Avatar
Cold braking - you want stock pads. Hot braking you want racing pads. Take your pick
XA coupe 8.8sec @ 150mph http://www.fordforums.com.au/showthr...coupe+drag+car
BA GT-P for the shed
Mustang GT for the other half
E3 chubsport - fully fat (and slow), sitting there waiting for me to get sick of it and sell it.
BA XR6T for a daily
NT Pajero for the bush
XB 4 door project- swallows a BF xr6 turbo
My dad is a generous bloke. He gave away his dead car batteries free of charge....
GTP owner is offline   Reply With Quote Multi-Quote with this Post
Old 01-12-2011, 02:18 AM   #6
Parfrey
Parfrey's Avatar
Don't forget the rear pads probably warm up pretty quick on the burnout...
FG XR6T
GU Patrol Duramax
Parfrey is offline   Reply With Quote Multi-Quote with this Post
Old 01-12-2011, 02:13 PM   #7
Giant
Giant's Avatar
I am using DBA Slotted Rotors on all 4.
Old 03-12-2011, 07:20 PM   #8
xf1101
G,day,
Thanks for the replies, stopping at the other end is no probs, am going to go with some std trw pads, supposedly good in this application?
Stopping from 130+ mph, going to rebuild rear calipers as well.
Old 11-01-2012, 07:50 PM   #9
JG33RD
JG33RD's Avatar
Hey Paul did you find much difference using other pads?
JG33RD is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2012, 07:56 PM   #10
foxtrot3
foxtrot3's Avatar
Hi. When I last engineered a car the engineer advised standard type pads as metal king type pads would fail the first 2 or 3 stops while cold but the drop off in performance on the 5th test with standard pads would still pass. Cheers MD
HI
I'M MICHAEL
