Old 08-09-2011, 05:02 PM   #1
V8XTasy
Default Xcal SCT tunes
I was thinking, when you buy one of these tuners, you either get a generic tune sent with it or get a tune done on a dyno and use the Xcal to programme your ECU or get a tune 'emailed' to you. Presumably this means the tunes are just a file. There must be lots of people out there with a tune file, either generic or custom for their cars.
Is their any scope in sharing or trading these tunes so others can try them and building up a list of what tunes people have found to work well on their Fords with details of the vehicle and mods?
I know in a perfect world we need to go and have our cars tuned on a dyno, but there's lots of talk about generic tunes and email tunes making an improvement over a factory tune, particularly when people have the same mods. eg. running LPG, or catback or CAI.
What are people's thoughts on this?
Falcon BA XT 5.4 V8 3v
V8XTasy is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2011, 05:15 PM   #2
Russ
Russ's Avatar
Contributor: For members who make a contribution worthy of recognition. - Issue reason: Very helpful and gracious with photoshop work to help others..
Default Re: Xcal SCT tunes
I'm not 100% sure but I think you will find that as flash tunes are based on a vehicles individual original ECU map read, they are only suited to the vehicle that the original ECU read is taken from and are not transferrable among others whether they be the same make and model or not.
Russ is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2011, 05:23 PM   #3
Tobey
BF Ute...
Tobey's Avatar
Tunes are locked to the vehicle.
And without testing the tunes on the dyno who knows what could happen to your car...
Tobey is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2011, 05:41 PM   #4
V8XTasy
but how about these tunes that are sent to you by email. How would these be locked to the vehicle? Wouldn't they just be a file?
Old 08-09-2011, 05:48 PM   #5
Russ
Russ's Avatar
The tunes sent to you by email are a modification of the original ECU file. I'm not aware of any other way of doing it other than using the original factory ECU file and modifying it to suit the vehicle and adjusted further where necessary to allow for any mods which have been done.
Old 08-09-2011, 05:53 PM   #6
V8XTasy
that would explain it, how about the generic tunes which are often sent with the Xcal?
Old 08-09-2011, 07:59 PM   #7
Russ
Russ's Avatar
The generic tunes will still work OK with minor mods such as exhaust and intake upgrades but are only a very basic tune. A custom tune not only gives you the maximum performance and economy from your vehicle, but is specifically designed to all your modifications, it also allows you the option of further tuning capabilities should you wish to do further performance upgrades in the future (ie injectors, turbos etc....) it should just be a case of emailing the tuner, telling them what upgrades have been done and they can then make the required changes to the tuning file
Old 08-09-2011, 08:16 PM   #8
Herrod Motorsport
www.sctflashtuning.com
Herrod Motorsport's Avatar
When we email a tune to be loaded by the end user it is sent in a special format with the seriel number of X3 that the tune is going to be loaded into, via our special live load software. There is now way that you can share tunes.A tuner can send a tune to another tuner and this can be opened and modified if needed via the sct advantage software.
Hope this answers the question
Australia's No1 Ford Enhancement Specialist
103 Northgate Drive
Thomastown
VIC 3074
Phone: 03 9464 5100
Fax: 03 9464 5166
Herrod Motorsport is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2011, 09:20 AM   #9
V8XTasy
Thanks for all the information.
