03-12-2009, 02:01 PM | #1 | ||
G'day all,
I got a mate with a KC laser with the 1.6 carby enigine, which is running bit rough, I want to check the timing but am unsure of where it is meant to be set, it also idles up a bit high i feel on the choke, (higher than i think it should) is there an adjustment for the auto choke on it Cheers |
03-12-2009, 05:16 PM | #2 | ||
Timing according to my Relim chart is 2 degrees BTDC +/- 1 Deg with the vacuum hose disconnected. Idle speed should be 800-900 for the manual and 900-1050 for the auto.
Cheers Russ
