Old 23-04-2005, 09:15 AM   #1
Mr Cube
Mr Cube's Avatar
Default Again with the AUI brakes
Got the optunity to buy a front pair of genuine TE calipers and rotors. Mainly just want the 2 spot calipers.
Or I was thinking trying to source a set of BA XR brakes, as mentioned a while back. They are also a 2 spot, but would they be as good as the T3 brakes?
Also should I worry about upgrading the back brakes or is the BA got a single spot aswell?
Any thoughts about the two systems? Also I know that I do need a few more parts to convert from the S1
Have you got an FPV or XR6/8 and live in the ACT or surrounding area? Come and check out the FPV & XR Owners Club of ACT
AUI VCT:
To date - Big brake upgrade, Koni and Kings all round, 2.5 cat back ready for replacing, 19" again ready for replacing.
Planned - Too much now I got the baby back.
Mr Cube is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2005, 12:57 PM   #2
LG
LG's Avatar
Standard AUI:
- Front: Single Piston Caliper to hold a 287mm Disc
- Rear: Single Piston Caliper to hold a 287mm Disc
Standard AUII/III:
- Front: Twin Piston Caliper to hold a 287mm Disc
Tickford/Premium AU Setup:
- Front: Twin Piston Caliper to hold a 330mm Disc
BA (incl XR):
- Front: Twin Piston Caliper to hold a 298mm Disc
- Rear: Single Piston Caliper to hold a 303mm Disc
BA Premium Brakes:
- Front: Twin Piston Caliper to hold a 325mm Disc
FPV:
I think thats mostly correct. As you can see on the BA's they got a larger rear disc, but slightly smaller front disc (than the Tickford setup), unless you get a FPV setup as fitted to the FPVs.
The Tickford Setup, ran exactly the same setup as standard at the rear. But I'd swap over the calipers anyway, for the Tickford wings.
Also just to add...
To further make the conversion to the twin-piston setup, you will need:
- Aftermarket Swaybar
- 16" Wheels or Greater
- Lower Control Arms
- Uprights
(I think thats about right)
AUIII Falcon Forte, with SIX Appeal
LG is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2005, 06:48 PM   #3
Mr Cube
Mr Cube's Avatar
thanks for the info.. Looking at that prolly best to grab the TE50 front brakes and upgrade the back as needed.
And yeah the tickford wings are a bonus, though I want to swap the red for another color.
AUI VCT:
Old 23-04-2005, 10:29 PM   #4
LG
LG's Avatar
There is actually some debate as to whether T3 TE50 brakes were red. T3 TS50 brakes, were definately red. But yes, the wings are a bonus, and you can always upgrade the rears later. But as most of the braking is from the front, you'd want the big puppys up front.
Old 24-04-2005, 06:08 PM   #5
Mr Cube
Mr Cube's Avatar
As fate would have it. I just won an eBay auction for the BA XR setup and got:
2x front calipers 2x rear calipers,
2x front brake hoses, 2x rear brake hoses,
2 front rotors 2x rear rotors and the brake pads
I had the maximum set and if I didn't win I was going to bid on this front set up:
http://cgi.ebay.com.au/ws/eBayISAPI....sPageName=WDVW
AUI VCT:
Old 24-04-2005, 06:14 PM   #6
Duffman
Oh Yeah!
Isn't there a stack more stuff required to convert an au1 to au2 brakes. Brake booster and all that related stuff im sure it would be even harder with abs. If you went through with all that you might as well just be the pbr upgrade kit way better then the stock brakes.
Duffman is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2005, 07:06 PM   #7
Mr Cube
Mr Cube's Avatar
As far as I know the rest that is needed is mentioned in LG's post above.
AUI VCT:
Old 25-04-2005, 08:55 PM   #8
stretch
Krispy Kreme Donut Glazer
stretch's Avatar
Mr Cube let us know how you go with the change over, I also have a set of Tickford brakes to put on my AU1 with all the control arms and everthing else but have been to lazy to do anything about putting them in. They have been sitting in my garage for the last 6months collecting dust, so I should just get off my Butt and put them in
Stretch
YOUR Best friend would bail you out of jail, but MYbest friend would be sat next to me whispering "I think we may have gone a little bit too far"
AU1 XR8 Silhouette lowered 18" wheels, T2 Leather, custom dash and a loud Exhaust. Sold
BA mk1 Gt Acid rush, Untouched, not no more it is lowered and has Black 19" fusions with a polished rim.
And now with some very dark windows.
Shopping car Ford Escape XLT V6 Sold
Shopping car now is a Mitsubishi Outlander
stretch is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2005, 11:40 PM   #9
JC
Miami Pilot
JC's Avatar
stretch - brake lines aside (i have never removed them), the rest of the setup shouldn't take more thna one hour per side.
Cubie - Are you sure BA brakes will fit an AU1?
Ford Performance Club ACT
Old 26-04-2005, 09:42 AM   #10
Mr Cube
Mr Cube's Avatar
JC - Yeah Im pretty sure, I remember thinking about going that way when I first looked at upgrading the brakes. If it all ends in a heap I will just put em back on eBay, there was a fair bit of interest in them.
AUI VCT:
Old 27-04-2005, 12:04 AM   #11
JC
Miami Pilot
JC's Avatar
If it all works out, and I still have the XR, I may even make you an offer for your rear slotteds (assuming you are going to fit the BA ones to the back as well). You will have to keep us all informed, as this could be a really good conversion - especially to GT or GT-P sized brakes.
Old 27-04-2005, 01:52 PM   #12
stiddy
stiddy's Avatar
hey guys,
I spoke to repco and a few other sources about getting a PBR brake upgrade.. i can pick it up for $2,360 although i have a series 1 AU, and i know what i need to upgrade but where can i get a aftermarket swaybar to fit? what brand is it etc etc
stiddy is offline   Reply With Quote Multi-Quote with this Post
Old 27-04-2005, 03:23 PM   #13
sbutler
335 kw of goodness
sbutler's Avatar
I think you'll find they wont fit AU1, as they had different spindels, everything will fit though, you'll have to get a pair of AU2 spindels......
Dont know why you need an other sway bar, or lower control arms??
CAUTION!
STILL Contain's opinion's & fact's that may offend !!!
2012 GTP 213 black what was I thinking? NOW FOR SALE>>
http://www.fordforums.com.au/showthread.php?t=11439680
sbutler is offline   Reply With Quote Multi-Quote with this Post
Old 27-04-2005, 04:22 PM   #14
LG
LG's Avatar
Different sway bar, because the factory one will knock something.
Lower control arms so that the mounting points can line up (with the twin-pot caliper) or something like that.
A whiteline swaybar should do, but i believe you will need the swaybar mounting points off an AU2/3. So that you can get a AU2/3 Spec swaybar.
Best call up Cebco, and speak to a mechanic/designer, and find out from them, about what you need to modify to fit their Cebco kits and other aftermarket brake packages, such as PBR, or to fit a AUII/III type setup.
Old 27-04-2005, 05:41 PM   #15
sbutler
335 kw of goodness
sbutler's Avatar
And what something is it gonna knock??
The calliper is bolted on to the spindle not the lower control arm... :voldar02: ...???
Seems to be a lot of gesswork going on here :evil_laug
CAUTION!
Old 27-04-2005, 06:53 PM   #16
Mr Cube
Mr Cube's Avatar
JC your a bad man, Im already thinking that way now..
AUI VCT:
Old 27-04-2005, 07:04 PM   #17
LG
LG's Avatar
I don't know exactly, as i haven't done it. I have spoken quickly to EvilChief, and read some of his posts, and he's done the whole lot. AU1 -> AU2/3 spec.
Linky: http://www.fordforums.com/showthread.php?t=78966
AU1 - Au2 conversion - parts needed:
1: uprights
2: lower controle arm
3: swaybar
4: swaybar mounting points
5: brake lines
6: calipers
7: rotors
But, people should call a brake specialist and talk to them. I know for a fact though, that AU1 swaybars are different to AU2/3 ones. A AU2/3 swaybar, will not fit on a AU1 (AUSteven can vouch for that).
You need the big rotors because of your huge *** 19s!! ;) :sm_headba
Old 27-04-2005, 09:32 PM   #18
Mr Cube
Mr Cube's Avatar
Damn straight!
looks a bit wrong ATM :lookedat:
AUI VCT:
Old 28-04-2005, 12:36 PM   #19
JC
Miami Pilot
JC's Avatar
The sway bars on the AU1s mount the same way they do on EA-ELs - ie they have a link at the front of the lower A arm. The AU2s mount in a different position, and the sway bar itself is a totally different shape. I have one of each (AU1 & 2), and have done a lot of suspension work on both. To remove the shock spring assembly on an AU1, you need to remove the sway bar links (or at least loosen one of the linkage points), but you don't need to when doing an AU2/3.
So, a new sway bar is definitely required when changing to an AU2/3 upright and lower A-arm/control arm.
