02-01-2007, 11:59 PM | #1 | ||
EBII XR6
New Years Eve my mate offered me a sub box he had made for free, obviously i'm not going to say no to this!
i dont have any photos as of yet as my parents took the camera away with them but heres the description: Box: 60cm x 39cm Perspex window: 35cm x 22cm Now he hasnt cut the hole for the sub yet which is good so it gives me options! I'm not sure if I should put 1 12" sub in the main wall opposite the window or put 2 12" subs at either end of the box. Now my question is does it matter which way subs face in the boot? Next question, is it better to have the inside of the box insulated? I'm wondering is white carpet would be suitable? remember I'm trying to make it look nice inside as well as it's got a window. Ok if I end up going with 2 subs either end, I'm wondering if I should mount the amp inside the box or if this is a bad idea? Otherwise it could go on the back of the box, which would be kinda messy looking. Otherwise I'm not too sure where to put them! The plan is to finish carpeting the box, black on the outside and proberly white on the inside, there will be either a black, blue or white neon stick hidden inside to light it up and hopefully it'll fit under the parcel shelf once I take out the carpet! I think it's only just off at the moment, but I'm hoping the carpet will take off some room! Ok enough rambling! I'll keep this updated. Cheers Braden
DEVLXR
03-01-2007, 12:00 AM | #2 | |||
www.TUFFCARPARTS.com
03-01-2007, 12:18 AM | #3 | |||
AU II XR8
has anyone tried mounting their amps in the boot side wall behind the triming (if any). in my dads AU, this is where he his amp is. Just a suggestion braden, as it might leave you with wires all over the place though.
AU XR8 II ute XD FAIRMONT GHIA 302 XA FAIRMONT 302 TOPLOADER |
03-01-2007, 12:31 AM | #4 | |||
EBII XR6
Also another question, am I best to have the box ported or sealed?
DEVLXR
03-01-2007, 12:42 AM | #5 | ||
DFDFDF
Hey mate.. to have a box you need 3 axis..
so you have a flat panel which is 60 x 39.. wat is the third dimension?? to make it a box.. Cheers, Nik
The Daily : 2012 Ford Territory The Restorer : 1994 Polynesian Green ED XR6 T5 - Completely stock, put away for a few years The Project : 1994 Velocity Blue ED Ford Futura - AU3 220kw XR8 5L V8 5-Speed in progress The Toys : 2003 GasGas EC250 & 2001 Yamaha DT230 |
03-01-2007, 12:51 AM | #6 | |||
If i recall, these suit the same volume/freq. that 306C's like, which is 2.2cu. ft tuned to 35hz. |
03-01-2007, 01:27 AM | #7 | ||||
EBII XR6
DEVLXR
03-01-2007, 08:43 AM | #8 | ||
The one and only
You need to fit sub(s) to suit the volume of the box. Not just what physically fitted.
Also how thick is the perspex? It should be at least 15mm but closer to 20mm.
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
03-01-2007, 11:11 AM | #9 | |||
EBII XR6
My mate thought the box was around 60 litres but that could be wrong. Whats the volume that a 12" sub needs approx? Also can anyone suggest whether I should port the box or not?
DEVLXR
03-01-2007, 11:47 AM | #10 | ||
The one and only
I used 18mm. 5 mm will flex alot, it's be difficult to get a good seal and you will loose some of the tightness of your bass. 5mm is good for windows for amps, cap, fuses, etc
Each 12" sub is designed for a cu2. So once you have calculated the size (I don't have my calculator at work) then you can work out the subs. Also what size MDF is the box made of? You will need to know this before calculating the box volume.
03-01-2007, 12:31 PM | #11 | ||
EBII XR6
oh god i just went out and measured the perspex properly then and its only 3 - 4 mm thick!! I guess I cant complain too much, I did get it for free after all! Is it worth using 2 layers of perspex or would I be better of going out and getting thicker perspex?
The box, which actually looks like to be made out of chipboard or similar!, is about 20 mm thick.
DEVLXR
03-01-2007, 12:49 PM | #12 | ||
XR6 Turbo FTW
Congrats Braden. See you at Winton
02 BA XR6 T U R B O - 232rwkw @ 6psi Blueprint, 19" FG2 XR6 Luxo Rims, Momo Steering Wheel, XR8 Bonnet Buldge, Full Leather, 3.7 Typhoon Diff Gears, Force Lip Spoiler, De-badged, Ghia Boot Garnish, Pedders Adjustable Coil- Overs And Camber Kit 96 EL XR6 - (Daily) Gunmetal Grey, 19" Typhoon Copies, Tickford Body Kit, Pedders Sports Ryders With Shortened Shocks And Camber Kit, Full S/S Difilipo Exhaust With Matching Extractors |
03-01-2007, 12:58 PM | #13 | ||
The one and only
Branden, sorry man but I now know why you got it fro free.
If you want good bass, buy the subs of your choice and build box to suit out of MDF. Then you can fit the window of correct thickness also.
03-01-2007, 01:08 PM | #14 | ||
EBII XR6
lol, nah i got it for free because he works at bunnings and got all the materials for free! I'll play around with it and get it good! thanks for your help mate. cheers
DEVLXR
03-01-2007, 01:13 PM | #15 | ||
The one and only
GET MDF free then!
Chipboard is useless!!
03-01-2007, 01:20 PM | #16 | ||
EBII XR6
lol, how come chipboard is no good? just out of curiosity?
DEVLXR
03-01-2007, 01:50 PM | #17 | ||
rofl copter
because it falls apart easy
GQ patrol.
.... thats all |
03-01-2007, 02:22 PM | #18 | ||
People who also use perspex usually use 20-25mm perspex which costs around $100 so it's quite expensive to do it properly! You'd get much better sounding bass if you just get rid of the window, and use it in a false floor or something to go over the amps. Or if you really wanted the window, use 6-10mm toughened glass. It's much cheaper than perspex.
MDF is better than chipboard cos its much more dense. |
03-01-2007, 03:46 PM | #19 | ||
EBII XR6
just found out the box i'm using now, which was also made by another mate, is made out of chipboard and it's been fine and sounds good. I think i'll just see how it goes, its not like its putting me out of pocket.
DEVLXR
05-01-2007, 12:09 AM | #20 | ||
DFDFDF
Hey dude..
i calculate the box to be around the 98 Litre mark.. should be perfect for 2 12"s depending on the specs of the subs ofcourse.. You will not need to strengthen the perspex if you port the box but if you gonna run sealed then the perspex will flex and bend till something breaks.. As for the particle board (chipboard) vs MDF.. I have always used mdf but that being said almost all the pre-fab autobarn type boxs are made out of particle board cos it costs half the price of MDF and sounds almost the same in most situations.. I say give the box a try and see how it goes.. i mean wat you got to lose??? Cheers, Nik
05-01-2007, 09:32 AM | #21 | |||
EBII XR6
Now is insulation required for the inside of the box? Would carpet achive the same affect?
DEVLXR
05-01-2007, 09:59 AM | #22 | ||
The one and only
Silicone the gaps.
05-01-2007, 10:46 AM | #23 | |||
EBII XR6
DEVLXR
05-01-2007, 11:08 AM | #24 | ||
EBII XR6
Finally got the camera back, heres the box:
Sub cutout Window cutout
DEVLXR
05-01-2007, 06:10 PM | #25 | ||
ORSM FORD CRUSIERS
nice? could do with a clean hehe
BLUEPOWER RACING DEVELOPMENTS Strive for perfection in everything we do. Take the best that exists and make it better. When it does not exist, design it. Accept nothing nearly right or good enough. -[BLKPHN] (VIC) PLATES FOR SALE $495.00-
06-01-2007, 11:10 AM | #26 | ||
EBII XR6
yeah i know, the shed is filthy, theres sawdust all over it because I had just cut out the sub hole and didnt bother getting rid of the dust from the floor! it'll come up good tho.
DEVLXR
06-01-2007, 11:23 AM | #27 | ||
ORSM FORD CRUSIERS
when she is finished post up the pics in UR mods thread.
06-01-2007, 01:21 PM | #28 | ||
EBII XR6
will do. anyone have white carpet?
DEVLXR
