Thumbs up for fossil fuel
G'day,
Well it started as a usual morning for me, woke up at 5:30am, had a shower, had some breakfast and headed off for work at around 6:15am. Got to the work car park at around 6:23am and parked the car in the usual spot..... Turned the ignition off, the climate control fan starts up and I begin to get out of the car. WHAT!!!! The climate control fan???? I dont ever even turn the fan on, I usually wind the windows down to get air flow, and what the hell is it doing starting up as soon as I turned the key off???? OFF!!!! not ACC, but OFF!!!! Where the hell is it getting power from??? It had me stumped, in fact it still has me stumped. After pulling the glovebox out and disconnecting all the white plugs linked to the fan system, the bloody thing kept going!!!!! It wasnt till I located the brown plug that is connected directly to the motor that I was able to stop it!!!! What the hell happened??? I know there could be a whole heap of reasons, but seriously, its just plain weird if you ask me!!!! And so random. And it wasnt even blowing at full speed, it was like half speed or something, so it wasnt even getting a full 12 volts (which you would expect if it arced out somewhere)!!!! I mean, yeah it could be the loom that I made, but I didnt touch the looms behind the dash, and I have been driving for 6 months without a problem!!! Mike ![]() ![]() ![]() ![]() ![]() ![]()
God created F-trucks so that you could put their engines into E series. 1992 EB Fairmont 351cu in Windsor Roller Cam Valve Body "Shift Kitted" BTR 4spd Auto Hi Tek Headers Tri Y Twin 2.25 into Single 2.5in 17in x 8in BA XR8 Copies 235x45x17 Nankang NSII Ultra Low King springs Whiteline 30mm Swaybar Nolathane box section trailing arms Slotted DBA front rotors Yella Terra roller rockers |
Now XR8TickfordBoy
Its getting revenge on u from not using it!!! (sorry for the useless reply!)
EF XR8- Respray in Monza Red with Clear Coat, Custom Rear Bar, AU V8, EL GT MAF, Rebuilt and Strengthened Auto with Stage 2 Shift Kit, 2,500RPM Stallie and tranny cooler, Rebuilt Diff with 4.11 Gears, Custom Radiator, King Ultra Lows, Pedders Shocks, NL Concorde Rims. |
Last warning
any changable relays for the climate system?
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
Call in the exorcist
Hmmmm, another "Ghost in the Glovebox" thread lol.
XR6 Turbo FTW
Could it be shorting out or something?
02 BA XR6 T U R B O - 232rwkw @ 6psi Blueprint, 19" FG2 XR6 Luxo Rims, Momo Steering Wheel, XR8 Bonnet Buldge, Full Leather, 3.7 Typhoon Diff Gears, Force Lip Spoiler, De-badged, Ghia Boot Garnish, Pedders Adjustable Coil- Overs And Camber Kit 96 EL XR6 - (Daily) Gunmetal Grey, 19" Typhoon Copies, Tickford Body Kit, Pedders Sports Ryders With Shortened Shocks And Camber Kit, Full S/S Difilipo Exhaust With Matching Extractors |
i second the ghost posts :P
Faulty fan speed controller?
Current Rides: 2012 KK Jeep Cherokee Limited CRD - Still going strong 2019 MG ZS Essence 1988 RD Mitsubishi Colt GL - 59kW of Fury 2022 Kia Stinger GT |
ORSM Ford Cruisers
that is completly wierd. i would say it shorted out and did not blow a fuse for some reason.
ORSM Ford Cruisers < click here
1993 EB2 Gli---->Build Thread 2008 FG XR8 SEDAN 300RWKW N/A 2008 FG XR6 TURBO-UTE>>> SOLD 2002 AU3 XLS UTE>>>SOLD |
this is true
its a ghost lol should start a poll ghost or an electric problem
EF Fairmont, stage 2 crow cam, 18" apache rims,xr air intake,full Lukey exhaust system, supalow springs, green dash mod,last dyno 145rwkw,stereo :gren: |
Just a spectator
I'l second fan speed resister.Common problem.
Hey Scoop hows things?
Cya Lukey. |
#12 | ||||
windsor user
i have heard of this before.........cant remember where its located though:S |
#13 | |||
Just a spectator
Cya Lukey. |
#14 | ||
![]() Join Date: Oct 2006
Unlike standard air climate control on premium models doesn't use a resistor pack for the fan speed controller. What happens is that there is a transistor in a T0-3 package that sits on the firewall side of the case and which doubles as a heat sink that sits in the air inlet duct to keep it cool. The trouble is that moisture and leaves and crud collect in this duct on the transistor casing and it rusts out until it shorts.
You can get replacement transistor for less than $15 from Worldwide electronics http://members.iinet.net.au/~worcom/ The transistor in question is a Motorola 2N5686. When you replace it buy and fit a T0-3 cover kit from Disk Smith, Altronics or Jaycar and also spray the outside of the case with electronic spray resin. Easy to replace if you can solder and desolder. Unscrew case from firewall (shiny cast alloy near glove box), take case apart, desolder transistor and solder in new one. Clean out the duct with the vac cleaner while fan speed controller is out. Make sure you note the orientation of the transistor when you remove its so you don't reverse connect the replacement. See http://www.altronics.com.au/index.a...a=item&id=H7290 or better http://www1.jaycar.com.au/productVi...eMax=&SUBCATID= for the transistor cover. You will also need new insulation washers http://www.altronics.com.au/index.a...a=item&id=H7200 or http://www1.jaycar.com.au/productVi...eMax=&SUBCATID= and some Unick or similar thermal grease http://www1.jaycar.com.au/productVi...eMax=&SUBCATID= (as used with your TFI module)
regards Blue |
#15 | ||
What Wheelspin?
limp mode will do this i believe.
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw) 2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned) |
#16 | ||
Posts: n/a
Ghost or stuck relay/short.
Technically the first will be easier to deal with... |
#17 | ||
It will take 5 minutes to undo the two screws that hold the shiny metal box on the firewall (the fan speed controller) behind the glove box and I bet you will find a rusted transistor casing. This is an extremely common problem - the other symptom of this is frequently a fan that will only work on high speed.
regards Blue |
#18 | ||
rofl copter
i got 10 bucks on the transistor!
GQ patrol.
.... thats all |
#19 | ||
Instal a cat, sounds like mice to me.
#20 | ||
Parts bin special
I've got the same problem. Later on, EA2BA is bringing a new fan speed controller over, and we'll put it in. It'll cost $15. At the same time, we're putting in EBII Climate Control and Trip Computer.
Weekender 1964 US Falcon Futura convertible - Rangoon Red 260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels https://fordforums.com.au/showthread.php?t=11470868 Daily 2014 SZII Territory diesel - basic runabout Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more 2000 AUII Fairmont - XR wheels, Ghia interior 2010 FG XR50T ute - XR8 bonnet, Streetfighter intake |
